Old Sep 29, 2012, 05:10 PM
Mecky is offline
Find More Posts by Mecky
Joined Mar 2010
Using two ESC with two batteries on one motor!
I have two brushed speed controllers, each can only take a 3s lipo max, and 3s lipos go as far as 7V or 11V but I want to use 14V on the brushed motor so can I use two 7V 3s batteries with those two speed controllers to give the motor 14V?
My diagram,
Does it look good?
Also when I merge two ESCs in one RX do I have to cut one of the red wires and not use it from one ESC?
Mecky is offline Find More Posts by Mecky
Old Sep 29, 2012, 05:18 PM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Lol NO even if it would work your motor is still only seeing 3s in parallel, you need to wire your batteries in series to get 6s.
aeromaniac is offline Find More Posts by aeromaniac
Old Sep 29, 2012, 05:31 PM
Mecky is offline
Joined Mar 2010
Are you sure it wouldn't give the motor 14V? Which is what I want.
Old Sep 29, 2012, 06:22 PM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
No, it absolutely will not give you 14V, only 7V
What is the voltage rating on the motor? 4S will probably kill the motor in short order.
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Sep 29, 2012, 07:30 PM
Doug Bartley is online now
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
A 3S battery is 12.6 volts fully charged. If you attach them together in parallel, meaning pos to pos and neg to neg, it will still be 12.6volts.
If you join one pos from one battery to one neg from the other, then use the remaining pos and neg to the esc, you will have your batteries in series, now the two together deliver 25.4v.
As stated, you'll likely destroy your motor on 14v, but it should handle 3S ok.
Be careful, have fun. Doug Bartley
Doug Bartley is online now Find More Posts by Doug Bartley
Old Sep 30, 2012, 03:08 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
No. Don't try it - something is bound to fry!
No. There is a back-feed through the throttle cables which are joined at the receiver. Therefore both battery negatives are connected together, and the total voltage is still only 7.4V.
Next problem is that the + output of one controller is connected to the - output of the other. When the ESCs turn on there will be a dead short between the two outputs. You risk blowing up an ESC and/or smoking the wiring.
You need a single controller which handles 4S, or stick with 3S and use a higher revving motor, bigger prop etc.
What is your current setup (motor, battery, prop) and what model is it powering? Why did you want to go to 4S?
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Sep 30, 2012, 08:34 AM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
It doesn't matter if it is 7 volts, 12 volts or 14 volts. You cannot hook up the output of two ESCs in series or in parllel. If you do all you will have is major smoke from both ESCs.
Larry
Lnagel is online now Find More Posts by Lnagel
Old Sep 30, 2012, 05:23 PM
Mecky is offline
Joined Mar 2010
I see, I won't try it then, thanks guys!
Question Two ESC's on One brushless motor. Sad Sack Power Systems 2 Jul 12, 2012 01:07 PM
Discussion Using two batteries for two motors? electricrc68 Batteries and Chargers 4 Jul 07, 2012 11:26 AM
Idea Using One battery per ESC/Motor Bearsa LLC Multirotor Talk 2 Jun 16, 2012 01:27 AM
Discussion Two motors, Two ESCs, Two batteries, But only one set of servos jophish Electric Plane Talk 11 Jul 03, 2010 02:50 AM
Discussion Two ESCs with BEC on one battery Razor_Racer Power Systems 8 Dec 25, 2007 09:49 AM
