Old Dec 13, 2012, 04:03 PM
Ken Lapointe is offline
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
Wow, looks great. Much larger than I thought it would be
Ken Lapointe is offline Find More Posts by Ken Lapointe
Old Dec 13, 2012, 07:13 PM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Hey Pekos have you checked the weight of the empty fuselage yet? Just curious about what's the weight of a ply and balsa plane this size. My 1/6 L-39 empty fuselage was 3000 grams and is way smaller than yours.
Gamalier is offline Find More Posts by Gamalier
Old Dec 14, 2012, 04:13 AM
pekos is online now
Find More Posts by pekos
pekos's Avatar
Czech Republic, Hlavní město Praha, Prague
Joined Sep 2012
hi, empty fuselage 2700gr. and wings 1000gr.
pekos is online now Find More Posts by pekos
Old Dec 14, 2012, 07:23 AM
Gamalier is offline
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
For a plane that big that's awesome!! Should weight around 20-22 pounds with 14s and a 120 fan easily if not less. With its size it should float really nice.
Old Dec 14, 2012, 07:56 AM
pekos is online now
pekos's Avatar
Joined Sep 2012
I hope that it will be up to 9 kg.
Old Dec 14, 2012, 07:58 AM
pekos is online now
pekos's Avatar
Joined Sep 2012
landing gear
Old Dec 14, 2012, 10:13 AM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Originally Posted by SergeyK View Post
I would still like to hear a little bit about your Sketchup workflow.
I guess my question got buried under well-deserved raves.
Sergey.
I second that - c'mon, throw us a bone!
BillO is offline Find More Posts by BillO
Old Dec 14, 2012, 01:47 PM
pekos is online now
pekos's Avatar
Joined Sep 2012
for Sergey K. : my knowledge of English isn´t at a high level, I will answer you, but I have to prepare for it, ok?
for Billo to.. :-)
precisely, we consider the plane and all the accessories:
fuselage 2582gr.
wings 1027gr.
EDF with motor. 850gr.
landing gears 890gr.
servos, esc,cables 850gr.
2x6s 6000mAh. 1800gr.
altogether : 7149gr.
+ vynil covering and cabin cockpit = 7500 - 7800 gr.
it looks good so far
Old Dec 14, 2012, 10:38 PM
BillO is offline
Firecracker!
BillO's Avatar
Thanks in advance for taking the time to explain even a little bit. Clearly your Sketchup skills are at a very high level!
Old Dec 15, 2012, 03:10 PM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Pekos, outstanding work!
@ Billo,SergeyK
Im trying come to grasp more with this style of building, Here is a simple vid of how im gonna approach it.
Create Skin/3dmodel
Create formers/Stations
Create Splines
Create Stingers/spine
Create knockouts/lightening holes
example_workflow (4 min 45 sec)
D_FAST is offline Find More Posts by D_FAST
Old Dec 15, 2012, 05:09 PM
pekos is online now
pekos's Avatar
Joined Sep 2012
wow, very interesting work, I am a beginner and I draw everything by hand. I draw without thickness, because the complicated image saving up computer performance.
Old Dec 15, 2012, 05:19 PM
pekos is online now
pekos's Avatar
Joined Sep 2012
For example, this
Old Dec 15, 2012, 05:35 PM
BillO is offline
Firecracker!
BillO's Avatar
Dan, that looks great, I see where you're going.
Pekos, that is such a beautiful drawing. But when you cut the parts on the laser cutter, how does the machine know how wide to cut the slots where the parts intersect if there is no thickness?
Old Dec 15, 2012, 06:42 PM
SergeyK is offline
Find More Posts by SergeyK
SergeyK's Avatar
United States, NY, Kings
Joined Feb 2006
I am a beginner too, and I had to discover things as I went along, that's why I'm interested what others came up with.
I drew with the thickness as it helped me visualize the complete model
http://www.rcgroups.com/forums/showthread.php?t=1442267
And I had to manually clone each part and drag it to a separate area and arrange on a flat plane to print out.
Did you manually draw the lightening holes on each rib separately or used tome kind of shortcut ?
SergeyK is offline Find More Posts by SergeyK
Old Dec 15, 2012, 07:12 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
It was just one way and was done on the most simplest of geometry, but like billo said you get the workflow.. The biggest is getting your wing loading,fsa, etc... All calculated then build your model. Then begin your RC conversion using slices and such. Placing electronics, etc along the way.
And yes use mirror and array to speed up work flow.
For Sale 39" Classic Top Flite Scoolmaster II R/C Model Airplane Kit LCS Aircraft - Electric - Airplanes (FS/W) 2 Jul 30, 2012 05:37 AM
For Sale 39" Classic Top Flite Scoolmaster II R/C Model Airplane Kit LCS Aircraft - Fuel - Airplanes (FS/W) 0 Jul 29, 2012 06:05 PM
Discussion HET L-39 VS Jet Teng L-39 skydve76 Electric Ducted Fan Jet Talk 48 Jan 23, 2012 03:46 AM
scratch build fiberglass l-39 reinhoud Electric Ducted Fan Jet Talk 2 Apr 29, 2005 06:31 AM
L-39 build thread ashdec87 Electric Ducted Fan Jet Talk 60 Apr 11, 2004 05:09 PM
