Old Sep 29, 2012, 02:01 PM
Gene Genie is offline
Find More Posts by Gene Genie
United Kingdom, Leeds
Joined Jun 2011
Gas engine - how much oil
Hi,
Just got a nice DLE 55 but no instructions, I have synthetic oil but how much oil per litre of gas ?
My friend says 30 ml per 1litre of gas
Is that about right for running in the motor
Thank you
Gene
Gene Genie is offline Find More Posts by Gene Genie
Old Sep 29, 2012, 06:46 PM
Evan03 is offline
Find More Posts by Evan03
Mtn Home, Idaho
Joined Feb 2010
I don't know the specs but you need to precisely measure it. Google ratio rite. It makes mixing very easy and accurate.
Your probly looking for a mix in the 30/1 to 40-1 ballpark but just guessing since I've never looked at the engine specs
Good luck
Evan03 is offline Find More Posts by Evan03
Old Sep 29, 2012, 08:11 PM
alan0899 is offline
Find More Posts by alan0899
Australia, NSW, Attunga
Joined Dec 2006
Originally Posted by Gene Genie View Post
Hi,
Thank you
Gene
G'day Gene
Have a look at this http://www.dlenginesaustralia.com/do...-55-manual.pdf
It states 30:1, or 33.3 Mls /litre.
Cheers
Allan
alan0899 is offline Find More Posts by alan0899
Old Sep 29, 2012, 08:43 PM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
I base it on the actual oil used. They usually have instructions on the bottle. I also skip the synthetic until its broken in. Some go straight to the synthetic, but I don't.
Roto Rob is online now Find More Posts by Roto Rob
Old Sep 29, 2012, 09:02 PM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
Most people I know break in using a good ashless oil at 32:1 then after a couple of gallons break in go to sythetic at 40:1 stay there...you'll see some go 50 to 100 to 1 but you'll never hurt your engine at 40:1
jetmech05 is offline Find More Posts by jetmech05
Old Oct 01, 2012, 12:36 AM
Gray Beard is offline
Find More Posts by Gray Beard
Joined May 2012
Originally Posted by jetmech05 View Post
Most people I know break in using a good ashless oil at 32:1 then after a couple of gallons break in go to synthetic at 40:1 stay there...you'll see some go 50 to 100 to 1 but you'll never hurt your engine at 40:1
Agree, it takes forever and a day to break in an engine with full synthetic. By about the second gallon I switch over. You can give Valley View a call to get the correct mix for the DLE engines. Most everyone I know is using Red Line oil from there local motor cycle shop.I like the Klotz blended oil. To each there own though. When I run out of Klotz I will probably be buying the Red Line too. It's just easier to come by.
Gray Beard is offline Find More Posts by Gray Beard
Old Oct 01, 2012, 11:12 AM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
About synthetic oil and ashless oil
Hello Gray Beard,
I am posting because it may help others that may have been wondering as I did.
If it takes that long to break in an engine using synthetic oil, I would think that it means the synthetic is a very good lubricant.
When an engine is being broken (a stupid expression as the engine is not being broken) the process is to polish the ring(s) and cylinder wall that results in a better seal by diminishing the surfaces roughness that remain from the machining of parts.
My understanding of the lubricating ability of oils is to create a gap betwenn the parts being lubricated. That gap is occupied by the oil and one of the oil property is that its molecules have little opposition to roll around each other. We could think that the oil is a very large amount of extemely small balls (the oil molecules) that have affinity to not run away and leave the parts to be abrasive to eah other.
A note about the English language being sometime confusing. I have wondered what is "ashless oil". Some oil that does not contain ashes?
What would ashes do in oil?
Why would ashes ever be included in producing lubricating oil?
What kind of ashes?
I found out that "ashless oil" is actually oil that does not leave ashes (residues) from its use.
It is like "a big horse show".
What is big? _ _ _ the horse or the show?
Concerning the main topic here, I have asked why should engines using glow fuel would need 17% and 20% oil while engines using gasoline get along well wih as little as 2%.
I did not see any response to my question.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Oct 01, 2012, 12:23 PM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Hi,
Here's the manual:
http://manuals.hobbico.com/dle/dleg0055-manual.pdf
Hope this helps.
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Oct 01, 2012, 03:00 PM
Joined May 2012
Originally Posted by Zor View Post
Hello Gray Beard,
What kind of ashes?
Zor
Was there a question here?
Old Oct 01, 2012, 05:31 PM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
I brought up the question in another thread discussing nitro and oil content (%) quite a while ago.
My question did not bring any answer.
Zor
Old Oct 02, 2012, 03:12 PM
rmsingh is offline
Find More Posts by rmsingh
RC Addict
rmsingh's Avatar
Ontario, Canada
Joined Mar 2010
Why should engines using glow fuel would need 17% and 20% oil while engines using gasoline get along well with as little as 2%.
Zor
Good question.
rmsingh is offline Find More Posts by rmsingh
Old Oct 02, 2012, 03:22 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
A good friend of mine, Hap Mulvaney, unfortunately no longer with us was a very competent 2 cycle gas engine guru. He always said, "Use as much oil as you can without carboning up the engine". It is hard to use to much oil and no damage if you do; however, to little and you replace the engine. I['ve always taken his advice and have had good success with mine. Type or brand of oil is pretty inconsequential, any good oil will work as well as any other. Most described differences are in the mind of the user only.
Rodney is offline Find More Posts by Rodney
Old Oct 02, 2012, 05:35 PM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
rmsingh and Rodney,
Yes, I thought it was a worth while question.
The piston(s), ring(s) and cylinder walls do not know how much oil is in the original mix. They only see what happens to be between them.
I have a 25 HP outboard that use 50:1 .
50 fuel by volume for one (1) part oil and that is the recommendation of Mercury engines. That engine has hundreds of hours of operation. I recently opened the heads to look at the cylinders. They are like mirrors and without any signs of scratches.
After reassembling the heads I checked the compression and read between 130 and 140 on both cylinders using the electric starter to rotate the crankshaft.
I cannot see much difference with an engine using glow fuel else perhaps than the metal alloys in use.
So the question remains _ _ _ unanswered.
Zor
Old Oct 02, 2012, 09:10 PM
Jacksonville Fla.
Joined Mar 2007
I suppose one of the reasons glow needs more oil is the operating RPM of the engine...10 grand or more at full throtlle... while a gasser is at 8000 tops.
Perhaps heat is another reason...One of oils function is to carry away heat
Old Oct 02, 2012, 09:25 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
A couple of possible reasons
- Gasoline has better lubricant properties than alcohol
- Many gas engines use roller bearings on the big end of the rod.
It is also worth noting that vintage gas engines used high oil concentrations, about the same as modern glow.
(10K is for babies - I have glow engines that turn over 30K )
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Discussion Whats a good mix oil for a gas engine? DMHIGHFLYER Engines 11 Aug 26, 2012 09:59 PM
Discussion What engine and servos would be best for Wot 4? Also how much fuel is needed? absandams Beginner Training Area (Fuel) 5 Jun 13, 2012 06:44 PM
Help! How much should I offset the engine mount mchandrayan The Builders Workshop 16 May 18, 2012 01:38 PM
Discussion So how much is gas going to cost by the time SEFF gets here? FiremanBill SEFF 2012 254 May 04, 2012 12:11 PM
Discussion how much oil for a ST 90 gas with stock rod? grant31781 Engines 4 Feb 18, 2009 06:25 PM
