Old Oct 02, 2012, 09:09 PM
AMBeck is offline
Find More Posts by AMBeck
AMBeck's Avatar
Charleston, SC
Joined Nov 2007
Here you go. This is an xfoil run at a flight ReNo of 100K, which should be pretty close for a floater style sailplane like the Sagitta. You'll notice that the S3014 has a big advantage between Cl=0.5 and Cl=1.0. This is where thermal sailplanes live. If you build accurately, and use a D box LE, you'll see a performance increase. If you don't build accurately, or if you build open bay, all bets are off. Good luck!
AMBeck is offline Find More Posts by AMBeck
Old Oct 03, 2012, 02:00 PM
kzimmerm is offline
Find More Posts by kzimmerm
Kurt Zimmerman ≡LSF 4461≡
kzimmerm's Avatar
Montrose, NY
Joined May 2003
Thanks AMBeck... now what would be a good open source CAD program to redraw my ribs?
Kurt
kzimmerm is offline Find More Posts by kzimmerm
Old Oct 07, 2012, 01:06 AM
SkySergio09 is offline
Find More Posts by SkySergio09
Planes > Time
United States, WA, Olympia
Joined Dec 2011
Thank you all, for the info, I might build a second wing with a different airfoil, to fit the body but maybe not.
Wouldn't you know it, I ask some questions here and start a listing on Ebay, then my primary computer went out. I am trying to get my old one to work now, but wow is it slow.
SkySergio09 is offline Find More Posts by SkySergio09
Old Oct 07, 2012, 11:42 AM
jcpatrick is online now
Find More Posts by jcpatrick
Jim C Patrick
jcpatrick's Avatar
Shenandoah County
Not open source, but Draftsight is absolutely free and a great AutocadŽ knockoff.
jcpatrick is online now Find More Posts by jcpatrick
Old Oct 10, 2012, 12:42 AM
HIR/Cer is offline
Find More Posts by HIR/Cer
HIR/Cer's Avatar
Joined Apr 2005
Originally Posted by Larry Jolly View Post
Dave,
Many of Lees's designs could wobble with over zealous inputs to the counter balanced rudder. I was trained on the Hobie Hawk and never noticed the wobble or shimmy, I just flew the airplane. The Sagitta is a little short in tail moment as Lees's designs were designed to go in a 42" box. But if it were me, I wouldn't change a thing except...
Get rid of the pine wing joiner box and instead use a 1/16" plywood front web joining the spars at the wing root. Make sure you do a good job of getting a smooth radius on the cable elevator pushrod, or replace it with a bellcrank drive system. Other wise leave the Sagitta stock and enjoy it. LJ
A friend built the Sagitta 900, stock, when the kits were first available, had no problems with the build, and was very satisfied with it flying in moderate to light lift. One of the wing joiner boxes did eventually fail, however, and he never did rebuild it.
Looking over an Airtronics Sagitta 900 kit I had purchased a couple of years ago from a fellow RCG member, the quality of the kit is excellent with clean machine cut parts, well selected balsa, sturdy air ply fuselage sides, and easy to follow instructions and plans.
Back then, built the Sagitta 600 myself following my friend's satisfaction with his 900 and it was also a great kit. Followed the instructions to add ailerons (my first 4 channel) and it was also a great flyer, more manuverable but needing more lift than his 900 as is to be expected.
Am hoping that Aerosphere will one day have the Sagitta kits available.
HIR/Cer is offline Find More Posts by HIR/Cer
Old Oct 10, 2012, 06:27 AM
rouge flyr is offline
Find More Posts by rouge flyr
Joined Apr 2012
Aerosphere WHAT A JOKE, has to be the BIGGEST blunder in model aviation history. Takes over a great product line and holds it hostage for 5+ years with not even a peep from its owner other than "were closed for renovations and will open after the New Year", Wonder what century he was talking about. I wish there was a "you don't use it you lose it" rule. That way crap like this couldn'happen
rouge flyr is offline Find More Posts by rouge flyr
Old Oct 13, 2012, 01:30 PM
electroboy is offline
Find More Posts by electroboy
can ya do that??...
electroboy's Avatar
California
Joined Jan 2004
Im curious what folks are using for spars nowadays as I can't find any spruce.
I was putting together a parts supply to build one and found no spruce.
Confounded, I gave up.
I have considered using basswood/ CF laminated on the bottom surface of the bottom spar as I reckon upward flex (tension) is probably the primary structural concern.
I also considered 1/8x3/8 CF pultrusion spars throughout.
still considering...doing nothing.
What methods have recent builder's used?
electroboy is offline Find More Posts by electroboy
Old Oct 13, 2012, 07:20 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Compression is probably somewhat more of.a problem, actually, because you can get buckling.
1/8 x 3/8 carbon would be total overkill. Go to chalesriverrc and look up drawings for Allegro Lite and Bubble Dancer for construction that can take brutal winch.launches. Or you can cap wood spar caps with....014" carbon on a two meter if you can tap.
lincoln is offline Find More Posts by lincoln
Old Oct 13, 2012, 07:23 PM
lincoln is offline
Joined Dec 2001
If you search for west coast Pietenpol you will fimd a guide to wood.for.aircrsft building. Many kinds are good for aircraft, including Douglas For.
Last edited by lincoln; Oct 14, 2012 at 12:43 AM. Reason: it's Pietenpol, not Pietenpole
Old Oct 13, 2012, 07:24 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
FWIW, there are some details for building a winch proof woody spar system over on Ray Hayes SkyBench site:
http://www.skybench.com/index.html?h....com/home.html
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Oct 14, 2012, 01:08 AM
lincoln is offline
Joined Dec 2001
More stuff on spars:
http://charlesriverrc.org/articles/d...mproofwing.htm
This guy talks about some tropical wood that's stronger. Even sugar maple is a lot stronger, though also heavier. However, compared to spruce you could probaby use half as much and still have a stronger spar that might even weigh less. This is because, since it's stronger, you can use a thinner cap and have more of it near the top (or the bottom) of the spar. The closer the material is to the top or bottom, the more it contributes to the strength and stiffness.
http://www.rcgroups.com/forums/showa...mentid=3981474
This one's about adding carbon to spars. I tend to think that the amount recommended may be overkill unless you wrap the spar with carbon and perhaps leave out the wood caps and use end grain shear webs that go from one carbon cap to the other. But certainly adding the carbon will make the wing stronger if you do it well. Whatever adhesive you use, test some samples to make sure it won't let the carbon peel off easily.
Old Oct 14, 2012, 02:17 AM
lincoln is offline
Joined Dec 2001
Ok, I got curious and did some web surfing. Maybe you'd need 2/3 as much for the maple. But black locust is supposed to be 80 percent stronger than sitka spruce, more or less. You'd want to inspect the grain on individual pieces of wood, though.
You can also make the spars wider near the center, or taper them, since there's a whole lot more stress in the center than there is further out.
Old Oct 14, 2012, 06:39 AM
whacker is online now
Find More Posts by whacker
whacker's Avatar
Canada, NS, Tatamagouche
Joined May 2005
I built the Elio
I built the Elio with s3021, wing profile...
Not a problem with 1/8 x 3/8 basswood, top and bottom, over 100 tows with a hi start stretched to 18lbs
No pine block for wing tube carrier.
reinforced front and back with 1/16 ply...
Of course every ones experience is different..
google 'elio sailplane', there's lots of pictures..
whacker
whacker is online now Find More Posts by whacker
Old Oct 14, 2012, 02:22 PM
lincoln is offline
Joined Dec 2001
1/8 X 3/8 spars in a normal 100 inch glider, assembled with good craftsmanship, is just fine for a hi start or a winch tapped with a modicum of skill. With a heavy foot, it's another story.
I didn't find all that many pictures of the assembled glider, but I liked what I saw.
Old Oct 17, 2012, 09:27 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
No picture of finished glider? Hint - look left....
And some of us built standoff "Sagitta's" with 115" wing and oh say MH32 airfoils...
(and winch in the nose)...
ScottSails is offline Find More Posts by ScottSails
Sold Sagitta 600, sagitta 900, spirit 100, sharpwind Mauihiflyer Aircraft - Sailplanes (FS/W) 3 Jul 31, 2013 10:38 AM
Discussion Sagitta 900 Build barracudahockey Sailplane Talk 17 Nov 02, 2012 05:24 PM
Sold Sagitta 900 kit NIB 250.00 radman615 Aircraft - Sailplanes (FS/W) 1 Mar 10, 2012 11:13 PM
Rave Sagitta 900 kit on sale on E-Bay for those that are interested Sackie Thermal 0 Dec 17, 2004 08:12 AM
Rave Sagitta 900 kit on sale on E-Bay for those that are interested Sackie Sailplane Talk 0 Dec 17, 2004 08:02 AM
