Old Sep 29, 2012, 09:31 AM
c131frdave is offline
Find More Posts by c131frdave
Too many numbers
United States, IL, Lake in the Hills
Joined Oct 2010
Laser cutter??
I'm looking to purchase a laser cutter for cutting model plywood. I noticed you can get 40W cutters fairly inexpensively, though they need to be upgraded with different controllers if you want to use Mach 3. Is 40W enough to cut through plywood and thin foam? Thanks.
c131frdave is offline Find More Posts by c131frdave
Old Sep 29, 2012, 10:13 AM
anton-anton is offline
Find More Posts by anton-anton
Danmark, Hovedstaden, Ølstykke
Joined Jul 2010
It's difficult to say. Its debens of the glue the plywood have be made of.
I have a 50 watt laser. Somtime can i cut 2 mm and sometime 5 mm.
Balsa have no problems
anton-anton is offline Find More Posts by anton-anton
Old Oct 01, 2012, 06:23 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Laser cut Ply Edges are a fair resemblance of a Charcoal Briquette. Black and dirty.
A Rotary tool makes a far nicer cut product.
Bare is offline Find More Posts by Bare
Old Oct 02, 2012, 02:53 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
do you guys know what is needed to cut the wood ...can the cutter be set up using a template of the part or does it have to be drawn in cad?
AIR SALLY is online now Find More Posts by AIR SALLY
Old Oct 02, 2012, 04:31 AM
p901P901 is offline
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Cad drawings are exported to G code usually. The G-code translates to the controller card and the controller card tells the stepper motors the x y coordinates. I know someone locally that can cut the parts using a template with a water jet. He works with us and has a private business..
Or if you want, have your son give me the drawings to convert to CAD to send of to LDS or any other laser cutting companies.
p901P901 is offline Find More Posts by p901P901
Old Oct 02, 2012, 01:22 PM
Dizz is offline
Find More Posts by Dizz
Dizz's Avatar
Brixham, Devon, England
Joined Jun 2004
That method is true for the CNC router I have access to, but the laser cutter PC drivers mean it is treated like a vector printer and will cut directly from Coreldraw- no need for the intermediate step of generating G code (still need a line drawing though, can't "print" a .jpg or the like).
Pete
Dizz is offline Find More Posts by Dizz
Old Oct 02, 2012, 10:00 PM
Bare is offline
Canada
Joined Nov 2000
Profili Cad etc has the capability to output as G code.
Easy and cheap for the package
Old Oct 04, 2012, 03:35 PM
Alien_Tech is online now
Find More Posts by Alien_Tech
Pile-it
Alien_Tech's Avatar
United States, CA, Palmdale
Joined Nov 2007
You obviously haven't seen properly cut laser cut plywood. Done correctly, it's a nice light brown and no char whatsoever.
Alien_Tech is online now Find More Posts by Alien_Tech
Old Oct 04, 2012, 07:33 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
what does a water jet do to plywood ? would'nt the water ruin it ?
Old Oct 04, 2012, 08:18 PM
p901P901 is offline
p901P901's Avatar
Joined Jan 2009
I wood think it would also.But the operator claims that they regularly cut wood. He claims they weight it down after cutting until it dries.
He has recently cut 12 kits of 6mm depron for foamy planes.
Discussion Laser Cutters bigdad1975 The Builders Workshop 13 May 08, 2014 09:06 AM
Laser cutter worldraft Aircraft - General - Miscellaneous (FS/W) 9 Oct 05, 2012 07:59 PM
How much does a laser cutter cost? totalboss Electric Plane Talk 30 Feb 14, 2012 11:57 PM
Discussion Die cutter/laser cutter? Tram The Builders Workshop 7 Apr 08, 2008 07:22 PM
Did you get your laser cutter Doug? Scomis Parkflyers 3 Nov 07, 2001 04:02 PM
