Joined Jan 2007
Boundary layer ingestion can be a good thing for propulsion efficiency, because you get to accelerate the slower moving air more:
"They also moved the engines from the usual wing-mounted locations to the rear of the fuselage. Unlike the engines on most transport aircraft that take in the high-speed, undisturbed air flow, the D-series engines take in slower moving air that is present in the wake of the fuselage. Known as the Boundary Layer Ingestion (BLI), this technique allows the engines to use less fuel for the same amount of thrust, although the design has several practical drawbacks, such as creating more engine stress." http://web.mit.edu/newsoffice/2010/nplus3-0517.html Dr. Drela headed the design study. I'm not clear enough on exactly what makes an EDF most efficient to say whether the boundary layer would hurt of help in this case. Kevin |
| Thread Tools | |
| Question Holes in wings for boundary layer blowing? | JaRaMW | Modeling Science | 13 | Feb 17, 2011 07:12 PM |
| Discussion Boundary layer drag | Curare | Hand Launch | 2 | Apr 10, 2008 01:07 AM |
| Gallery Dynamic Soaring in the ground boundary layer | MSelig | Dynamic Soaring | 12 | Jan 23, 2007 03:09 AM |
| difference between 1 layer wing versus 2 layers? | micron | Foamies (Kits) | 3 | Feb 18, 2003 11:06 PM |
