Joined Apr 2012
Hi, Charles. I'm glad you finally talked them into sending you the plane. I would have given up in disgust!
I've been trying to decide between these from HobbyKing: http://www.hobbyking.com/hobbyking/s...12sec_28g.html And these from Esprit Models: http://www.espritmodel.com/mks-ds450...tal-servo.aspx I haven't used either so I'm not making a recommendation, just a suggestion. Let us know what you decided on and give your impressions because I'm going to be in the market soon. Also, it seems like a lot of planes call for "slim" servo, which are generally 10mm, when a 12mm servo will fit. That would open you up for anything in the 14-23 gram range and probably save you a couple more bucks. Cheers! |
![]() http://www.alofthobbies.com/hd-1711mg.html If you want a SLIM digital with pretty good power: http://www.alofthobbies.com/dsm44.html That DSM44 is a really nice little servo. Digital, coreless and metal gears all in a tiny little package. -Wayne |
Latest blog entry: FrSky at the Toledo R/C Model Expo -...
S.F. Bay Area
Joined Aug 2002
Bought some for a Cularis project that hasn't materialized.Took an 1810 apart and was quite pleased. I would say the DSM44 @ 1.2 Kg/Cm would be pretty light for a 3.4m e-sailplane.Prolly better to go with the 1711 or 1810. Skies Jay. P.S. Wayne,you mention on your website... Quote:
I just got a servo torture tester, and I plan to abuse the heck out of some servos. I'm eager to see how well some of the different gears in different servos hold up to a little light abuse. I think a few thousand short fast cycles with a fair bit of weight might do the trick. I bring this up as we have been testing a lot of servos lately and found many of the cheaper metal gear servos start off with tight gears but they get loose VERY quickly. A good example are the cheap Corona 929, 939 series. (We no longer sell them for this reason.) I'm looking forward to torturing some of the new titanium/alloy geared servos. ![]() -Wayne |
Joined Apr 2012
RE: Gear wear.
Back when there was no such thing as a cheap metal gear servo I got in the habit of using a dab of silicone grease. I had a couple bearings go bad but the gears themselves stayed nice and tight. An old friend took it one step further and he would pull all the gears, coat them with Duralube or Slick50, and bake them in a 200 degree(?) oven for a half-hour or so. I was flying with him a couple weeks ago and he has some 15 year old servos that are still silent and slop free despite his habit of really abusing servos (and everything else!).
| Thread Tools | |
| Discussion Looking for a camera gimbal that does not use servos | ripmax | Multirotor Talk | 4 | Jul 10, 2012 04:15 PM |
| Discussion Does someone make a quick disconect for wing servos? | Dave K | Radios | 1 | May 29, 2012 05:37 AM |
| Discussion looking for a good X8 wing can not find one?? | aopen3434 | Foamies (Kits) | 1 | Mar 18, 2012 04:56 PM |
| Alert Can someone confirm that I am not the only one who cant search at the moment | Willard | Micro Helis | 4 | Jan 10, 2005 06:58 PM |
| Can someone suggest a good next plane? | saitrix | Electric Plane Talk | 25 | Jul 25, 2004 06:28 AM |
