Old Oct 04, 2012, 10:16 AM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
The 150 sq. in rule gives 29" wingspan on the Vampire, but I forgot to check the distance between the booms. Doing that now. Okay, I have clearance for a 6" propeller (6.6395").
I was thinking a 5mm carbon tube inside a 3 layer lamination with the vertical stab as part of the center lamination.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Oct 04, 2012, 10:25 AM
georgy is offline
Find More Posts by georgy
Allways the hard way!
georgy's Avatar
South Africa, GP, Germiston
Joined Jan 2012
Originally Posted by DKChris View Post
......the dental drill sound would be inevitable.....but what the heck.....
YEAAHH BABY
My sport slot-jet is louder than a hot nitro! Gives a real raw power feel
Not park friendly though
George
georgy is offline Find More Posts by georgy
Old Oct 04, 2012, 10:59 AM
DKChris is offline
Find More Posts by DKChris
Danish? Don't U eat that??
DKChris's Avatar
Denmark
Originally Posted by dumb_thumbs View Post
One jet that might work well for combat is the Vampire.
-Heath
I now see i'm not first with the idea......
Ken
Sounds a bit heavy to me, but I think i'm doing the error of having my mind set on indoor plane construction, where you need a rather tight turning ability - I'd most likely go for 150-180g AUW (Or less if possible) at 29".............maybe I should go over the thread again.......
Your idea would be strong though.....Probably suitable for a park model.
DKChris is offline Find More Posts by DKChris
Old Oct 04, 2012, 12:06 PM
Jimmy JFlyer is offline
Find More Posts by Jimmy JFlyer
For us He died, in me He lives
Jimmy JFlyer's Avatar
United States, MI, Saint Clair Shores
Joined Dec 2008
Wow Ken, I been away from RCG so long, I didn't even know this thread was here. Looking forward to reading thru this one for sure.
Jimmy JFlyer is offline Find More Posts by Jimmy JFlyer
Old Oct 04, 2012, 01:16 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
More Vamp!
Ken
Old Oct 04, 2012, 01:48 PM
DKChris is offline
DKChris's Avatar
Denmark
Looking seriously nice............good proportions!
Old Oct 04, 2012, 03:10 PM
georgy is offline
georgy's Avatar
Joined Jan 2012
Ok, I'm confused. Is this Vampire designed to fly "elevons" only? Like a wing-type airframe?
Do you then deliberately "under-size" the horisontal stab & "over-size" the ailerons?
I saw you flew the Hunter like that Ken... boggles my mind!
George
Old Oct 04, 2012, 04:07 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
George,
I am interested in flying the Vamp on elevons only. It should be quite stable as the fixed elevator will dampen the response. In the case of elevator size I increased the chord by 10% as well as the vertical stabilizer area.
I want to try this out this way first since servo space is tight and I am constrained to use dual aileron servos on this design. However a functional elevator is not out of the equation. I will test it both ways. CG may be a challenge on this one with a pusher motor and a relatively short nose.
Ken
Old Oct 04, 2012, 08:57 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
VLF Vamp
I was not real happy with the looks of the PLF style fuselage on the Vampire, so I figured a VLF on would be much sharper.
Ken
Build Log 06-OCT-2012: Cut the prototype kit this evening. Seems quite easy to assemble. Will post plans and build guide here.
Build Log 09-OCT-2012: Started assembling the kit today. Got the canopy, fuselage center and left hand outer laminations glued up.
Build Log 10-OCT-2012: Finished the fuselage laminations, built up the wing, and glued up the boom sub-assemblies. Dry fitted sub-assemblies. Presanded the subs, and glued up the entire airframe. Finish sanded, added firewall, servos, motor, esc, and rx. Finished battery retention magnet installation.
Old Oct 05, 2012, 04:16 AM
georgy is offline
georgy's Avatar
Joined Jan 2012
QUOTE: The canopy comes off to access the electronics and battery.
Some nice innovation there!
With all those VLF layers this Vamp (with some detail sanding) will be much too nice for Combat!
a Few triangular pieces aound the intakes & you got a "stand-off scale" model....
If the elevons work out well it will also suit the BAC Lightning. It is basically an "interrupted" delta... I recall in one of my early posts 'bout the Lightning some-one posted that very set-up. Must go back & look.
Sure will help simplicity & weight saving (& $$$)
Waiting report on the elevon success...
George
Old Oct 05, 2012, 05:17 AM
georgy is offline
georgy's Avatar
Joined Jan 2012
Found the short thread on BAC/EE Lightning with taileron & elevon discussion...
http://www.rcgroups.com/forums/showthread.php?t=1645907
George
Old Oct 05, 2012, 05:59 AM
DKChris is offline
DKChris's Avatar
Denmark
From the comments in the linked thread and gut feeling, i'm getting a hunch, that the elevon solution will get to be more interesting to operate, the further the tail gets away from the wing rear edge.......at some point it would actually make sense to reverse the elevator input, in reality working it as flaps......but where that point is.....good question...? And in between that point and the point where there's stable normal elevon control, the handling is very likely to be sluggish.......but I guess the only reasonable way to find out is to build a crude test model and try it out....
Old Oct 05, 2012, 06:56 AM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
One of the discoveries made flying the Hunter in both modes is that elevon setups require a further forward CG than a conventional setup. So this could be helpful to know with long nosed jets.
Ken
Old Oct 05, 2012, 07:38 AM
georgy is offline
georgy's Avatar
Joined Jan 2012
Found this F-4 Phantom plan in the C/Line section... Ready-made VLF jobby. (Hope it's OK to re-post! Let me know, if not i will remove asap)
If you were to build this, would you put ailerons in-board or out-board of that famous wing dihideral? (or both?)
Full flying H-Stab? Or conventional fixed H-Stab + elevator split?
George
Old Oct 05, 2012, 08:50 AM
DKChris is offline
DKChris's Avatar
Denmark
Ken
Makes sense; If the CG is placed more or less as if there was no stab surface(but still a vertical tail to balance the nose weight), It should fly like a wing only model, the tail would just dampen the elevator reactions a bit.
Build Log Sporterizing dz1sfb's Hawker Hurricane, SEMFF WWII Combat Plane. Freddie B Foamies (Scratchbuilt) 152 Dec 17, 2012 09:59 PM
Video Semff combat sortie 8/28/2012 mav913 Electric Plane Talk 2 Aug 29, 2012 11:29 PM
Discussion Indianapolis Area combat SEMFF WWII combat dman65 Combat 1 Sep 12, 2010 12:35 PM
