Old Nov 15, 2012, 05:26 PM
planecrazy1969 is online now
Find More Posts by planecrazy1969
Gone Fly'n
planecrazy1969's Avatar
USA, NV, Las Vegas
Joined Jan 2007
Originally Posted by dz1sfb View Post
Stace,
You need to smooth that airfoil a bit. Not suprised about stalling at slow speed. It may be prone to tip stalling, but the blunt LE (I mean the sharp corners) are tripping up the air.
Overall your airframe looks very nice. You may need only move the motor aft 1 to 1-1/2" to get good balance with the battery.
Ken
Hi Ken...I'll certainly smooth out that airfoil before putting it back into the air...I'll have to do some measuring to see what kind of room I have for moving the motor back slightly...as long as I can get that battery on the centerline of the fuselage...that's my main goal
planecrazy1969 is online now Find More Posts by planecrazy1969
Old Nov 15, 2012, 06:54 PM
dz1sfb is online now
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Originally Posted by planecrazy1969 View Post
Hi George...yeah it is set up with tailerons...think I might mod to ailerons and elevator when I do the motor placement
Stace
This is a mod I want to do to my F-16. Better control at slow speeds, with better response at near stall.
Ken
dz1sfb is online now Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Nov 27, 2012, 11:48 AM
Pinky_d_brain is online now
Find More Posts by Pinky_d_brain
I don't do Normal
Pinky_d_brain's Avatar
Canada, NT, Yellowknife
Joined Dec 2011
Not much going on here lately
I need to make some time and work on the X4, how the rest of you doing out there any new build pics
Pinky_d_brain is online now Find More Posts by Pinky_d_brain
Old Nov 27, 2012, 12:31 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
I'm building 4 jets, but they have full fuselages and are not for combat. Soon I'll be building one of these.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Jan 29, 2013, 12:48 PM
I don't do Normal
Joined Dec 2011
Hay Ken how's the Jets doing you guys try them out yet, got any combat vids??
Old May 20, 2013, 09:59 AM
SONICX is offline
Find More Posts by SONICX
SONICX's Avatar
South Africa, GP, Krugersdorp
Joined Jul 2012
Any plans for the Vamp yet?
SONICX is offline Find More Posts by SONICX
Old May 31, 2013, 10:48 AM
XDmToter is offline
Find More Posts by XDmToter
XDmToter's Avatar
Joined Apr 2012
Ken, I designed this Before I was made aware of this thread... I'm a little bit bigger than your 150 Sq In rule depending on how I measure...
What do you think... Am I close enough?
XDmToter is offline Find More Posts by XDmToter
Old May 31, 2013, 11:01 AM
XDmToter is offline
XDmToter's Avatar
Joined Apr 2012
Sorry if this was answered earlier.... If it was, I couldn't find it...
You say you are running a 7x6 prop on the 1700kv BW with a 3S Battery. Do you still use the little 12Amp ESC with that setup?
Thanks.
Old May 31, 2013, 12:20 PM
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Thanks.
Good job Kieth! and yes, we are running that gear if at all possible.
Ken
Old May 31, 2013, 01:53 PM
XDmToter is offline
XDmToter's Avatar
Joined Apr 2012
I've incorporated many of the ideas that I gathered from the guys on the main SEMFF thread. I also changed the size of the Plan for MPF instead of $Tree foam. Here is the updated design.
EDIT: I'm removing the PDF plan. It just had too many problems. I'll have the revised edition up soon.
EDIT: The Corrected plan has been posted Here:
http://www.rcgroups.com/forums/showp...&postcount=280
Old Jun 01, 2013, 12:29 PM
XDmToter is offline
XDmToter's Avatar
Joined Apr 2012
Ok. The first prototype is finished and ready to fly.
AUW ended up being 9.2 oz with a 1000mah 3S.
I'll try to get some video of a maiden flight later today, if the weather cooperates. Right now I have to go to my niece's dance recital.
Also, I've noticed some issues with the plans I posted above. The spacing of the firewall and prop slot is wrong.
Also, if you use a stick mount, the alignment tab is in the wrong spot. Either way, the motor mount area is just wrong. There are other issues as well. I'll be correcting these as time permits.
EDIT: The corrected plan has been posted above.
Description:
Old Jun 01, 2013, 12:34 PM
XDmToter is offline
XDmToter's Avatar
Joined Apr 2012
Ken. When this thing goes up in flames, all I'm going to have to say is "Ken said it could handle a 3s"
I just ran it up to HALF throttle for a few Seconds, and that motor got awful hot. Hopefully the airflow of actual flight conditions will keep everything cool enough.
The other obvious concern is if my thumbs can handle a 3s in this bird...
We'll find out soon enough.
Old Jun 01, 2013, 06:39 PM
SGTalon is offline
Find More Posts by SGTalon
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
You should have a smaller prop if you are going 3s. I don't think i would run it with a 7x6.
SGTalon is offline Find More Posts by SGTalon
Old Jun 01, 2013, 11:58 PM
XDmToter is offline
XDmToter's Avatar
Joined Apr 2012
4. Power System - I want to go with the 1700 Kv 24g motor again, but this time it will be set up for 3s. We found on the WWII models that the motor/esc/prop combo that they handled 3s just fine. Since these are models of jets, I want to see a more jet like performance. Batteries in the 1000 mAh + 200 mAh. Sticking with the 7x6 prop as well. These may be tractor, prop in slot, or pusher setups.
Ken
Ken doesn't like to keep that magic smoke bottled up
Could make for a good show.
Old Jun 02, 2013, 01:25 AM
XDmToter is offline
XDmToter's Avatar
Joined Apr 2012
The maiden flight of my Combat F-22 didn't go so well. I think I have the CG set too far aft. It was very hard to control. I also think my battery was too far off center. It had a bad tendency to roll to the right.
Luckily I was able to bring it down without incident. I moved the battery forward, and tried again, but it wasn't enough. It was better, but still difficult to control. This time it ended up in a tree 25' up...
I recovered it from that hang up with nothing more than a couple wrinkles...
So, I'm going to add the bottom panel, which is entirely in front of the CG. I am also moving the servos in front of the prop slot.
Build Log Sporterizing dz1sfb's Hawker Hurricane, SEMFF WWII Combat Plane. Freddie B Foamies (Scratchbuilt) 152 Dec 17, 2012 09:59 PM
Video Semff combat sortie 8/28/2012 mav913 Electric Plane Talk 2 Aug 29, 2012 11:29 PM
Discussion Indianapolis Area combat SEMFF WWII combat dman65 Combat 1 Sep 12, 2010 12:35 PM
