Old Oct 19, 2012, 10:48 AM
Allways the hard way!
georgy's Avatar
South Africa, GP, Johannesburg
Joined Jan 2012
Ken,
Vamp plans ready for release?
& the STARFIGHTER? No pressure....
George
georgy is offline Find More Posts by georgy
Old Oct 19, 2012, 01:22 PM
I don't do Normal
Pinky_d_brain's Avatar
Canada, NT, Yellowknife
Joined Dec 2011
Well got some time to day and updated the Mig-21
Pinky_d_brain is offline Find More Posts by Pinky_d_brain
Old Oct 19, 2012, 01:28 PM
I don't do Normal
Joined Dec 2011
I also had some fun and did a Northrop X-4
With a bit of sanding this thing will be so close to scale it's not funny
All comments are welcome good or bad
Old Oct 19, 2012, 01:41 PM
georgy's Avatar
Joined Jan 2012
Pinky,
Me likes... Think i'll give your hard work a go.
Broke my Skyray, so in need of another plane now..
George
Old Oct 19, 2012, 01:58 PM
I don't do Normal
Joined Dec 2011
Excellent let me know if you have any problems
I recommend checking that CG don't no if its correct
Old Oct 19, 2012, 02:04 PM
Heaven Bound
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Originally Posted by georgy View Post
Ken,
George
George,
As soon as I get an opportunity to remaiden the Vamp with the elevator, and there are no other issues, I'll be ready to work up the plans.
The Starfighter (just the name sounds cool) may have to wait. I have more ideas than time to execute them.
I have to finish testing changes made to the Hawker Hunter also. Then onto its plans.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Old Oct 19, 2012, 02:06 PM
Heaven Bound
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Nice work there Pinky!
The combo laminations on the X4 is novel. Should build up nicely.
Sorry I've not had time to get those component files out yet.
Ken
Old Oct 19, 2012, 02:15 PM
georgy's Avatar
Joined Jan 2012
Originally Posted by dz1sfb View Post
George,
Ken
Ken,
Just messing with you kind sir... know you are pounding a million projects!
If i had a plane for every plan, i would need a hanger!!
Good luck with those re-maidens...
Greeting
George
Old Oct 19, 2012, 02:26 PM
I don't do Normal
Joined Dec 2011
No problem on the components I don't have much time my self
I have plans to build the X4 but I only have a 180 motor and a 2cell 400mAh battery together they make a brick
Old Oct 19, 2012, 02:58 PM
I don't do Normal
Joined Dec 2011
I have a small tec. noob question, how do you connect the small batteries that have no 2 wire connection?? The one I am looking at has the charge plug but as far as I can tell that is it. I know this type of batt. is meant to connect to small plains with the 3 prong plug directly to the on bord ESC but I don't have one of them and want to use a normal speed controller. How would I go about this is there an adapter or something? I'm thinking the red and black are +/- and the white is used for balancing. was thinking if I got a plug to connect onto that and only connected the black and red to my ESC it should work but I need to make sure here.
http://www.e-fliterc.com/Products/De...ID=EFLB1802S20
Old Oct 19, 2012, 03:09 PM
Gone Fly'n
planecrazy1969's Avatar
USA, NV, Las Vegas
Joined Jan 2007
Hey all...had some time today to start the next set of plans...decided on a MiG-19...I'm still going to finish the F-100, but am tweaking the design to have a prop in slot rather than a tail mount motor...hoping to get one built and flown by next weekend...the MiG-19 has a 19.6" ws and length of 27.3"...wing area coming in at 91.38 sq in...this was designed at 1/18 scale...it has a tractor setup and am drawing in ailerons and elevator...the one I build will have elevons.
Stace
planecrazy1969 is offline Find More Posts by planecrazy1969
Old Oct 19, 2012, 03:16 PM
Gone Fly'n
USA, NV, Las Vegas
Joined Jan 2007
Plans look great Pinky...love how this thread is moving along...great work all
Old Oct 19, 2012, 05:17 PM
Heaven Bound
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
This is done often to save weight. You need the corresponding plug, which will come with three wires also. Clip the center wire, it is for balancing during charging as you thought. Now you can attach to your esc.
Ken
Old Oct 21, 2012, 03:49 PM
Thomas B.'s Avatar
Germany, Nordrhein-Westfalen, Cologne
Joined Mar 2012
What do you think about the Grumman Cougar?
http://www.aviastar.org/pictures/usa/grumman_cougar.gif
Thomas B. is offline Find More Posts by Thomas B.
Old Oct 22, 2012, 12:00 PM
I don't do Normal
Joined Dec 2011
Thanks for the info Ken
George how's the build going hope all is fitting together ok sorry I can't give you more info on where to locate everything
Grumman Cougar looks good to me did some numbers and it's about a 25" wing span at 1:16 scale and some major wing area there. May have to scale this one down a bit to fit on one sheet
Build Log Sporterizing dz1sfb's Hawker Hurricane, SEMFF WWII Combat Plane. Freddie B Foamies (Scratchbuilt) 152 Dec 17, 2012 09:59 PM
Video Semff combat sortie 8/28/2012 mav913 Electric Plane Talk 2 Aug 29, 2012 11:29 PM
Discussion Indianapolis Area combat SEMFF WWII combat dman65 Electric Combat 1 Sep 12, 2010 12:35 PM
