Old Oct 09, 2012, 01:44 PM
Pinky_d_brain is offline
Find More Posts by Pinky_d_brain
I don't do Normal
Pinky_d_brain's Avatar
Canada, NT, Yellowknife
Joined Dec 2011
I will give it a shot
Pinky_d_brain is offline Find More Posts by Pinky_d_brain
Old Oct 09, 2012, 04:03 PM
dz1sfb is online now
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Originally Posted by georgy View Post
How about Mig-21...
Now there's another 3 pages of elevon discussion LoL
George
The Mig 21 looks like a perfect PLF style model.
Pinky,
We are going with KFm2 wings which are not more than 2 layers. The KF panel generally runs from the leading edge to the 50% chord liine. These layers can extend into the horizontal laminations of the fuselage. The vertical laminations are usually not more than 3, and the placement is somewhat strategic, i.e. single layers at vertical fin, sometimes the dorsal line.
A VLF style model is usually 5-7 layers all stacked with vertical laminations. Internal channels and cavities built into the layers for wires servos and battery. These are usually more scale in appearance, but not as durable for combat as the PLF style.
You may design as you see fit. By trying to keep to design parameters any of the planes here will have similar construction and volume of material.
For the $tree foam users/designers, plan on using at least 2 sheets (20" x 30" = 600 sq. in. X 2 = 1200 sq.in.). One 24" X 48" sheet of foam is 1153 sq. in.
Ken
dz1sfb is online now Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Oct 09, 2012, 04:16 PM
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Vampire Construction Update:
Got the canopy, fuselage center and LH outer laminations glued up. Added 4 pics to this post http://www.rcgroups.com/forums/showp...1&postcount=69
Ken
Old Oct 09, 2012, 06:09 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Ken,
The Vampire is coming along. So pretty in MPF, and it just can't be beat. Good luck on the finish and maiden. I'll be staying tuned!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Oct 09, 2012, 09:31 PM
planecrazy1969 is offline
Find More Posts by planecrazy1969
Gone Fly'n
planecrazy1969's Avatar
USA, NV, Las Vegas
Joined Jan 2007
Vampire is looking great Ken...can't wait to see this gem all painted up
Stace
planecrazy1969 is offline Find More Posts by planecrazy1969
Old Oct 10, 2012, 06:21 AM
DKChris is offline
Find More Posts by DKChris
Danish? Don't U eat that??
DKChris's Avatar
Denmark
Went over my CG calculations again, as the just didn't make sense; this time I used the same tool for both calculations, by just adding nearly no tail area.
Would seem there are a few differences in the used calculation algorithms in the 2 calculator programs. The new data makes more sense.
DKChris is offline Find More Posts by DKChris
Old Oct 10, 2012, 10:25 AM
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Updated Excel spredsheet. There are 39 jets in there and the wing area is populated now.
Ken
Old Oct 10, 2012, 11:48 AM
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Finished the fuselage laminations, built up the wing, and glued up the boom sub-assemblies. Dry fitted all sub-assemblies.
Should have some sanding completed by the end of the day. I'll show that in tomorrows update.
Added 4 more pics to this post http://www.rcgroups.com/forums/showp...1&postcount=69
Ken
Old Oct 10, 2012, 11:55 AM
Commander Clumsy is offline
Find More Posts by Commander Clumsy
Proud of Brushless Sprouts
Commander Clumsy's Avatar
Belgium, Flanders, Antwerp
Joined Feb 2007
re: The Elevons/Tailerons question
Thanks for answering everybody!
Things are beginning to dawn on me now
For this Playmobil glider I will choose Aileron&Elevator to stay on the safe side.
Please skip the following as it has nothing to do with SEMFF Combat Jets:
Originally Posted by Freddie B View Post
Nice looking plane BTW. Wish they had those here!
It should be available in the US, have a search on Amazon.com or playmobilusa.com, search for "Playmobil glider".
I have converted several "toy grade" airplanes like AirAce (Buzz/Phase3/Powerfly/Venom) and Silverlit into "real" RC, but I was always reluctant to take on the Multiplex Fox because of its nasty wing tip stalls.
The Playmobil Glider however seems to fly nice, found this video from a Dutch guy: youtube.com/watch?v=FPSnCkv28hc
28-11 9g motor
Em 4,3g servos
6a Plush ESC
2s 500mah
110 grams
He flew half throttle the whole time due to space restrictions.
I also found this video from a Frenchman with comparable setup in which it makes almost perfect rolls : youtube.com/watch?v=CpogZCdskCE
Commander Clumsy is offline Find More Posts by Commander Clumsy
Old Oct 10, 2012, 12:29 PM
Joined Feb 2007
Ken
Almost nothing from the '80s and further on, nice to see it's all about the classics
Another straight winged trainer, the Hunting Percival/BAC Jet Provost?
Old Oct 10, 2012, 01:49 PM
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Along similar lines is this Cessna T-37. Kinda like the squished look of it.
Ken
Old Oct 10, 2012, 02:59 PM
I don't do Normal
Joined Dec 2011
Well here is my try at the Mig-21
I have not placed any equipment or indicated CG if you guys can provide this info I will gladly add it to the plans. I put an optional KFm-1 on the tail thinking it may or may not help just an idea. Anyways please let me know if you see anything wacky or build it and find a problem.
updated plans on post#212
Old Oct 10, 2012, 03:41 PM
georgy is offline
Find More Posts by georgy
Allways the hard way!
georgy's Avatar
South Africa, GP, Germiston
Joined Jan 2012
Pinky,
Not too shabby... done this before?
KFm for rear stab not required. I would put the wing KFm2 right to the tip...
George
georgy is offline Find More Posts by georgy
Old Oct 10, 2012, 04:42 PM
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Pinky,
George
Pinky,
I am with George. Looking pretty good.
If I may offer some constructive comments;
1. Dump the KF panel on the horizontal stabilizer. As George said, "not required". Move the stab down to where the KF panel is.
2. Run the KFm2 panel on the wing to the tip. This will make it less likely to tip stall. Current condition effectively adds washin to the tips.
3. A second horzontal lamination in front of the wing panel will make the nose more robust. This is especially important if you dork it on a less than perfect landing. Save you from snapping the nose.
4. If you refigure how its cut up, you could enlarge the scale and use more of the sheet.
I really like how you did the vertical laminations. This brings out details.
Thinking that a tractor mount motor with a prop adapter spinner nut could give the nose cone effect.
What CAD program are you using? Looks like .dwg format. I could post some components in that format for you to play with.
Overall I like its looks. Spank'in!
Ken
Old Oct 10, 2012, 04:47 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Pinky,
Thanks for the work on the MiG 21. Everyone varies, but adding a world drawing (one sheet) is my preferance. I like to see the parts all laid out without needing to tape tiles together. I also rarely use tiles as I would probably measure, multiply, mark, and cut. So much faster for me. You decide though. Thanks again.
Fred
Build Log Sporterizing dz1sfb's Hawker Hurricane, SEMFF WWII Combat Plane. Freddie B Foamies (Scratchbuilt) 152 Dec 17, 2012 09:59 PM
Video Semff combat sortie 8/28/2012 mav913 Electric Plane Talk 2 Aug 29, 2012 11:29 PM
Discussion Indianapolis Area combat SEMFF WWII combat dman65 Combat 1 Sep 12, 2010 12:35 PM
