Old Sep 28, 2012, 04:08 PM
wheelsB4wings is offline
Find More Posts by wheelsB4wings
Joined Nov 2010
HABU 32 repair.
Hi all,
Sharing a repair I did on a friends habu 32. He crashed on a deadstick landing hitting a tree.
After reviewing the damage, thankfully on the balsa and ply pieces were broken. The fiberglass fuselage had minimal damage. Leading edge and skin of the right wing had some cracks as well. Rich used florescent trim monokote to help with orientation.
I started with the fuselage repair.
Removed the battery tray and landing gear pieces to inspect the damage. These were used as templates for cutting replacements. Used 1/8 6 layer ply for these pieces.
Jigsaw used to cut overall shapes.
Rotary tool with a multipurpose bit used to initially cut all lightening holes and required openings then finished with a sanding drum.
Finished pieces.
Test fitted before epoxying into fuselage.
Installation of battery tray and nose gear support into fuselage. Started on the damaged wing next.
Removed the monokote to see how much damage done.
Removed damaged skins and leading edge.
Sheeting applied. 1/16 sheet balsa worked well.
Sanded repair skin to match rest of wing.
Used peeled off existing monokote and some additional color for Rich's orientation.
Safe flying,
Shaz-
wheelsB4wings is offline Find More Posts by wheelsB4wings
Old Oct 25, 2012, 01:58 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Nicely done. Thanks for sharing!
Josh
jgalexander is offline Find More Posts by jgalexander
Sold Eflite 80amp esc and Delta V 32 fan and motor from Habu 32 Mattsrcking Aircraft - Electric - Jets (FS/W) 0 Aug 22, 2012 09:44 PM
Discussion Habu 32 -- where to use metal gear servo's ? rcfun2005 Electric Ducted Fan Jet Talk 14 Mar 29, 2012 06:00 AM
Sold Habu 32 complete electric package choopi Aircraft - Electric - Jets (FS/W) 6 Mar 10, 2012 07:34 PM
Wanted Habu 32 wings and stab fred685 Aircraft - Electric - Jets (FS/W) 0 Feb 25, 2012 05:39 AM
Sold NIB delta 32 fan unit & 32 motor for habu 32 yf22raptor Aircraft - Electric - Jets (FS/W) 2 Apr 29, 2011 10:23 AM
