Old Oct 09, 2012, 03:32 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
I see what you mean about it going nose in when the fin touches down.Did you do any reinforcement of the leading edge carbon tube joint?
Regards Stuart
Stuart A is offline Find More Posts by Stuart A
Old Oct 09, 2012, 04:15 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
The leading edge is a black FIBERGLASS tube. Looks like carbon doesn't it ! Goodwinds.com doesn't even sell fiberglass colored fiberglass tube any more....the black is so popular.
At the nose, the center 3 bays will be skinned with 1/32" plywood and heavily reinforced with fiberglass from the inside. Might add a "bra" of the red Kevlar over the nose. similar to the handle at the fin.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Oct 10, 2012, 05:41 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Trailing Edge
The TE is 1//32" plywd. with 25K CF tow top and bottom. Trying out the new tow wetter for this little layup. Need to come up with good way to squeege the tow as it exits the wetter so that the wetness can be adjusted.
Kent
Old Oct 10, 2012, 07:43 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
and now....a video
New Tow Wetter - TE lay up (14 min 57 sec)
Old Oct 11, 2012, 06:12 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Got the floor boards in with glass reinforcement.
Kent
Old Oct 11, 2012, 06:35 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Test Balance
I was HOPING that this wing would balance out without a fuse because of the wing sweep.....but not enough. The test balance, even without elevons shows an aft CG even with a long nose and 2 oz. of trim weight up front.
It looks like there is a fuse in my future.... I guess I won't need to build that main skid after all.
Kent
Old Oct 11, 2012, 08:46 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Fuse
With the help of Rhino 3D came up with some templates to cut profiles in foam, then sanded to shape. Started with one layer of light glass just to get some thing stuck to the foam. When this is cured, I'll add layers of this and that until strong. Not really sure how this goes. Glassing is not my thing.
Kent
Old Oct 12, 2012, 07:38 AM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Kent, It'd be interesting to see how it balances without that big tail on there. When you were building it, I thought it might create balance issues.
Might be worth looking at alternatives.
HerkS is offline Find More Posts by HerkS
Old Oct 12, 2012, 09:35 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Hi Herk,
The tail is permanently installed at this point. It is built stronger and heavier than needed by most pilots, but stronger ships serve me better. I'm happy to pay the price.
When it comes to balance and the tail there is not much need to remove it in order to perform a balance test. The entire tail assembly weight 45 gms, IIRC. The assembly's CG could be estimated, then moments about a point to do a "what if".
I could balance this plane without a fuse, but that would require 8 to 10oz of lead in the nose which would be fine for a slope machine, but I'd like to thermal this one. The fuse should be lighter overall.
Kent
Old Oct 13, 2012, 12:37 PM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Wowow Kent, I leave you for two weeks and you come with another beauty definitely on my bucket list.
For the fin, I could advise a fully symmetrical delta shape. A collegue developed this idea for his DLGs and it reduces drag significantly. I will post some pics ASAP.
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Oct 13, 2012, 05:58 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
A fin of this caliber needs a comparable fuse to provide balance. Test balance without elevons or covering. .. 2oz. of nose lead looks good for now. Still have to gouge out the foam from the fuse.
Kent
Old Oct 13, 2012, 06:25 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Just for reference, 10oz. is needed to balance without the fuse. What a difference a little moment arm makes.
I'll test fly it in this configuration in order to determine the real CG before casting permanent lead in the nose installing the fuse.
Kent
Old Oct 14, 2012, 02:37 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
I must say I prefer the look of the fuselage version.Adds more than just a mechanical advantage.
When you say "gouge out the foam"do you mean all of it,just leaving the glass shell?Can I ask what weight of fabric you used,how many layers and how you applied them.(education education education as our Mr Blair used to say)
Regards Stuart.
Old Oct 14, 2012, 10:08 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
EZ
Feel free to post not only the delta shaped tail but anything related to planks. If my humble plank has spurred on some ideas, sketch them up an post them here.
I noticed the same thing ! I not sure if I am just conditioned to seeing the conventional fuse/tail layout but it needs the fuse to visually balance the tail. Would I like to see a shorter nose, such as the Samurdactyl....yes I would, but that's just a matter of degree.
As far as glassing goes, I'm afraid that I'm such an amateur that I don't keep track of the glass that I have in stock. This one starts with one layer of light glass (2oz?) laid up on a wetted out foam core. Cure. Then a layer of heavier glass (8oz) was applied to the work with 3M77, then wetted out. All very resin rich.
With the foam core in tack, it was rigid, but when the foam was gouged out at the rear portion, it was flexible as a shell only. Strong enough for light duty thermal flying. Then I added 50K of CF tow each side with some Kevlar patches. I'll fly it un-painted, so if it breaks, reinforcement will be easy. I post some piccies later.
As a rule of thumb Stuart, I'd start with 2 layers of medium glass to make a rigid shell. Then gouge out the foam and add more layers to suit your needs.
Kent
Old Oct 15, 2012, 01:42 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
For me it looks better without fuse. But I muss say that it will certainly help with the plane orientation and attitude
EZ
Build Log Minute Plank-Light lift depron Plank for travel - w/ Video Marcos Quito Slope 40 Jan 06, 2009 08:53 AM
Discussion Planking 42inch plank-on-rib Jonesport Lobster Boat DaveMainzone Scale Boats 16 Oct 05, 2008 09:24 AM
Build Log Drive65 PW51 plank (Was: Anhedral/Dihedral and washout in planks) +video! Crashaholic Slope 117 Sep 21, 2008 07:17 AM
Discussion Strip planking or insert planking? Jacques Flambeau Scale Kit/Scratch Built 5 Jun 14, 2007 04:09 PM
