Old Jan 24, 2013, 05:05 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Cg
Based on the last day of flying, the best CG is 3 7/16" from the LE at the root.
The CG can be pushed back another 5/32" but is hard to control the pitch at that setting. Performance does improve with this setting.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Jan 31, 2013, 09:46 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
I've got a Hump
While on the bungee, I keep seeing a "hump" in the trajectory. Tried shooting 60 frames/sec to get a better look. Some times it's more apparent than others. It takes off steep, then flattens out until release. I'm not touching the stick while on tow.
No wind today so got in some launch and land practice. Great way to unwind after work. This plane has no problem with speed, so to lose altitude, I normally just put the nose straight down. Today, just for fun, tried a few different approaches to a slow spiral dive to lose altitude. Without spoilers, it's good to have some tricks up your sleeve. With the plank, if you really pull back on the stick, it will certainly stall. But do the same thing while in a high banked turn and it slips nicely down and keeps flying.....some times. Some of the later flights had the most up elevator on the turns.
Plank 101 - Launch and land (0 min 0 sec)
Kent
Old Feb 01, 2013, 01:08 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Hey Kent Nice video, I think the hump is a ground effect, you are going through a dead air\rotor point at your slope, and then to the lift. This transition between no lift and lift, even in no wind conditions, can produce that effect.
my two cents
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Feb 01, 2013, 08:13 AM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Kent, I think it's the effect of hook position. Further forward hook - less hump. Further aft hook - more hump. Question is, where is the hook????
HerkS is offline Find More Posts by HerkS
Old Feb 01, 2013, 09:27 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
If the CG is 0 degrees, the hook is swept forward about 60 degrees from the CG. If the hook were on the nose it would be about 85 degrees forward.
BTW, I'm happy about the hump. The initial climb out gets the plane clear of the ground, then its a flat trajectory until release.
The hump appears to be specific to the plank. A swept flying wing launches with an even trajectory.
Launching Horti Mini Elli (1 min 8 sec)
Kent
Old Feb 01, 2013, 09:47 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Maybe......I've noticed the hump while flying at in land sites too. It might be more pronounced at higher launch forces or when a heavy rubber bungee is used without a lead line. I happens mighty quick, so it's hard to say. My hunch is that it is tied to the angle of the tow line pull.
Initially, the pull is forward, which allows the plane to climb based on the tow hook location to the CG.
Then as the pull becomes more downward, that same forward tow hook location pulls the plane down.
At the beach, due to limited launch area, the bungee is just a short piece of heavy rubber.
Kent
Old Feb 02, 2013, 12:11 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Here's the altitude flight graph from a couple of bungee launches from the last day of flying.
Kent
Old Feb 02, 2013, 01:03 PM
HerkS is offline
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Kent
At the start of the launch inertial forces are dominant. Then as speed builds up, aerodynamic forces become more prominent.
When you release it, the CG is above the line of force from the bungee, so the model begins to nose up. Then as the speed increases rapidly the trim setting begins to take over. Aerodynamic forces are proportional to speed squared. Meanwhile the bungee force is decreasing so its effect diminishes.
As long as the plane doesn't tip stall and start to rotate during the pitch-up you are ok. Your setup seems to work very well.
Old Feb 02, 2013, 01:19 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Yes, you can't forget inertia. Both initial inertia forces and tow hook location promote a rather steep climb. With the fantastic speed during launch, trim settings would also cause a steep climb.
So the only force that would cause a dip in that steep climb would be the weight of the bungee rubber pulling down on the tow hook. As the bungee relaxes, the ratio of dead weight vs. forward pull changes to pull the plane down.
Unless, of course, I'm missing something.
At 2:10 there is a decent launch with a long light lead line....and no hump. Glider was trimmed for slow flight.
Plank 101 - Soberanes - CG way back.wmv (10 min 28 sec)
Kent
Old Feb 07, 2013, 09:48 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Looks like slope season has arrived on the West Coast.
At high rates, there is an obvious hyper stall when inverted, but some how missed it in the video....maybe next time.
Kent
Plank 101 - a few landings (0 min 0 sec)
Old Feb 08, 2013, 08:35 AM
HerkS is offline
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
I like the supersonic touch and go maneuvers.
With that wind you should be able to back it in and make a zero speed landing.
Old Feb 08, 2013, 09:16 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Funny you should mention that. As I was leaving, after about 1 1/2 hrs. of non-stop flying and chasing the plane up and down the slopes, I thought I'd try to do some landing catches, but was too tired to even try.
Was flying light yesterday. .. With added weight, the high speed touch and goes would go on forever. But this little plane has external ballast, so that would mess up the T&Gs. The Plank 2.5 has internal ballast (4 lbs.) and should be able to put on quite a show.
Kent
Old Mar 09, 2013, 07:45 PM
rusty case is offline
Find More Posts by rusty case
KlonWarz
Joined Dec 2012
ok, I read, and watched... Thank you!
...Today, where is the best source for smaller than 1/2" bungee rubber,
and,
Carbon fiber stock? tube, and tow?
has it been determined the dip in launch is the weight of the bungee?
and I DID notice the First catch since 1982 ! lol
(where is the manatee or mini elli planform? reallly difficult finding the actual plans here in nurflugel) need a beginner index to... :-)
rc
rusty case is offline Find More Posts by rusty case
Old Mar 09, 2013, 08:27 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
I got my bungee from BambuReef.com
CF tow is everywhere. You should shop for it. I've got 4 lbs. of tow, so I could sell you some if you like.
I like Goodwinds.com for CG sticks and tubes.
I nominate YOU to start a new thread for newbies as a catch all spot for general info. Go to Nurflugel and click "New Thread".
Take a look at my blog for more plan references. Not every thing is available.
Kent
Old Mar 09, 2013, 10:05 PM
KlonWarz
Joined Dec 2012
OK Kent.
I shall review your blog before i pester you folks any longer...
OK, I will begin a newbie thread when I learn the right questions.
Your initial responses were very helpful and have led me to find a number of informative posts. Still, far too many questions. :-)
Tnx
rustycase
(rc is far ez r to type!)
Build Log Minute Plank-Light lift depron Plank for travel - w/ Video Marcos Quito Slope 40 Jan 06, 2009 08:53 AM
Discussion Planking 42inch plank-on-rib Jonesport Lobster Boat DaveMainzone Scale Boats 16 Oct 05, 2008 09:24 AM
Build Log Drive65 PW51 plank (Was: Anhedral/Dihedral and washout in planks) +video! Crashaholic Slope 117 Sep 21, 2008 07:17 AM
Discussion Strip planking or insert planking? Jacques Flambeau Scale Kit/Scratch Built 5 Jun 14, 2007 04:09 PM
