This thread is privately moderated by FairlyFaded, who may elect to delete unwanted replies.
Old Sep 28, 2012, 12:36 PM
FairlyFaded is offline
Find More Posts by FairlyFaded
Trader Rating: 26
Registered Snoozer
FairlyFaded's Avatar
Palo alto CA
Trader Rating: 26
For Sale
Rohacell structural foam! Wing skins, Tail cores
For sale are sheets of Rohacell IGF (small cell, better than older large cell Rohacell) 31 and 51 cut to useful sizes for DLG wings and tails as well as other high performance molded airplanes.
Rohacell is the strongest foam per pound commercially available. It is used in nearly every molded competition wing, and for good reason. Until now it has been very difficult to get (the only US source charges a 300% mark-up...). But enough pitch, we all know this stuff is frickin' sweet
Here are the prices for the sizes currently available
Rohacell 51 @ 833 X 350 X 1 mm 15.00 USD Quantity available: 47
Rohacell 51 @ 833 X 200 X 1 mm 7.00 USD Quantity available: 7
Rohacell 51 @ 833 X 350 X 1.5 mm 16.00 USD Quantity available: 7
Rohacell 51 @ 833 X 200 X 1.5 mm 7.50 USD Quantity available: 3
Rohacell 31 @ 833 X 350 X 1 mm 12.50 USD Quantity available: 10
Rohacell 31 @ 833 X 200 X 1 mm 6.00 USD Quantity available: 0
Rohacell 31 @ 833 X 350 X 8 mm 35.00 USD Quantity available: 8
Rohacell 31 @ 833 X 200 X 8 mm 18.00 USD Quantity available: 1
The large sheets were sized such that the top and bottom skin for a 60" dlg could be nested into one sheet with little wasted material. So for a 60" dlg wing, two large sheets will be required.
The sheets are cut with a CNC bandsaw which holds impressive tolerances. Still, cutting 1mm thick sheets with a bandsaw is tricky. The 1mm Rohacell 31 sheets are all very close to 1mm (+/- roughly .1mm). The 1mm Rohacell 51 generally lies above 1mm, ranging from ~1mm to 1.27mm.
Two shipping options are available:
Shipping option A: Foam will be packed flat between sheets of Luan plywood or cardboard and 3/4" EPS foam. $19 flat for shipping option A
Shipping option B: Foam will be rolled into a 6" x 6" by 14" box. The foam will exhibit a slight curl when unpacked. $10 flat for shipping option B.
Questions can be emailed to Norciavelo@gmail.com or through RC groups.
-Michael
FairlyFaded is offline Find More Posts by FairlyFaded
Old Sep 28, 2012, 02:01 PM
Rush2112 is offline
Find More Posts by Rush2112
Trader Rating: 2
United States, MN, Medina
Joined Mar 2008
Trader Rating: 2
Never used this stuff...intrigued. For tails, do I sand it down then cover it with something? For wings, do I send it off to my core cutting service and have them replace the blue foam with this? (I realize the thickness offered here is not enough, just trying to learn how to use it in general).
Is it lighter than blue foam? sorry for the rookie questions
Rush2112 is offline Find More Posts by Rush2112
Old Sep 28, 2012, 04:23 PM
decones is offline
Find More Posts by decones
Trader Rating: 1
making my own planes...
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
Trader Rating: 1
standart use is for skin and width=1mm is totally enaugh!
This material is very light and strong when you put it as sandwich between 2 laminates (fiberglass, aramid, carbon, etc..)
Typical core material for high performance models, I use it in my planes and it Rulez!!!
decones is offline Find More Posts by decones
Old Sep 28, 2012, 05:36 PM
slope junkie is offline
Find More Posts by slope junkie
Trader Rating: 11
Everything is "only used once"
slope junkie's Avatar
United States, CA, Newport Beach
Joined Jul 2011
Trader Rating: 11
I believe it is used for core material of skin on a hollow molded design, not for core material of a bagged design.
slope junkie is offline Find More Posts by slope junkie
Old Sep 29, 2012, 11:05 AM
samc99us is online now
Find More Posts by samc99us
Trader Rating: 22
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Trader Rating: 22
It can be used for core material in a bagged wing but most be cut on a CNC router (NOT SAFE WITH A HOT WIRE BOW!!!). It would be a very stiff and light wing-some DLG's are built this way. These sheets aren't thick enough for that application however.
-Sam
samc99us is online now Find More Posts by samc99us
Old Apr 23, 2014, 07:44 PM
bluegid is offline
Find More Posts by bluegid
Trader Rating: 0
Joined Sep 2012
Trader Rating: 0
Still available?
Is this stuff still available? Could you send to UK?
bluegid is offline Find More Posts by bluegid
Old May 18, 2014, 10:33 AM
Smeader is offline
Find More Posts by Smeader
Trader Rating: 25
United States, CA, Loomis
Joined Jul 2008
Trader Rating: 25
I'll take 6 of the igf 51 833 x350x 1mm . Shipping option A. Let me know how you want payment.
Thanks .
Scott
Smeader is offline Find More Posts by Smeader
Old Jun 25, 2014, 10:43 AM
Chuchuf is offline
Find More Posts by Chuchuf
Trader Rating: 74
Carboweave, Ask For It By Name
Chuchuf's Avatar
United States, GA, Atlanta
Joined Aug 2009
Trader Rating: 74
Is this Rohacel still available??
Terry
Chuchuf is offline Find More Posts by Chuchuf
For Sale Rohacell foam 31 and 51! Wing skins! Tail cores! FairlyFaded Aircraft - Sailplanes (FS/W) 4 May 10, 2013 01:33 AM
For Sale Rohacell 31/51 for sale CHEAP, wing skins, tail cores FairlyFaded Aircraft - Sailplanes (FS/W) 0 Nov 24, 2011 02:22 PM
For Sale Rohacell foam 31 and 51! Wing skins! Tail cores! FairlyFaded Aircraft - Sailplanes (FS/W) 0 Oct 20, 2011 04:47 PM
For Sale Rohacell 31/51 wing skins, tail cores! FairlyFaded Aircraft - Sailplanes (FS/W) 3 Jun 23, 2011 07:17 AM
Question Adhesive for bonding balsa wing skins to foam cores Rogo Hand Launch 2 May 05, 2008 09:28 PM
