Old Sep 28, 2012, 01:00 AM
Blade Crasher is offline
Find More Posts by Blade Crasher
USA, WA, Bremerton
Joined Feb 2007
Question
Tail Servo Arm / Gyro / End-Points
I'm having trouble getting my head around the issue of TX setup for the tail servo, as it relates to the location of the ball on the servo arm.
I'm using a Align 750 gryo which, when I set the left and right yaw maximums in the gyro, these limits I think are only applicable for when the gyro issues a correction command. Is that true or am I confused?
When I command rudder on the TX, I think this over-rules the gyro limits. I'm thinking this is why some posts I've read talk about setting the servo travel end-points on the rudder, so that the TX will not over drive servo causing binding. Again, am I confused or on track?
So then the question on the ball location on the servo arm, do I want the ball closer to the pivot so that I need more "swing" with the end-points further apart, or further out on the servo arm and the end-points closer together?
You can see I'm lost here. Maybe I'm over-thinking this. Thanks for reading this long post and helping get me back on track.
Blade Crasher is offline Find More Posts by Blade Crasher
Old Sep 28, 2012, 07:28 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I think most gyros work the same way - so although I don't have any experience with the 750, I used several other gyros.
You set the tail slider travel by adjusting the gyro limits. All but the lowest end gyros will have a separate left and right limit, so you set them to ensure that there is no binding in the tail rotor at full left or full right rudder.
If you can't get the tail slider to reach the mechanical limits on one or both sides, it means you need to use a longer servo arm - i.e. move the linkage ball out on the servo arm.
Conversely, if the limits have to be set at say around 50% to prevent binding, you need to move the linkage ball in on the servo arm.
The ATV or End Point settings in the TX will affect the piro rate - and have no effect on the tail limits. That seems counter-intuitive, since most of the time, adjusting the TX ATV's will affect the servo travel.
You normally use the rudder ATV's to equalise the left and right piro rates, and that's most easily done on a Lazy Susan test stand, though you can also do it, less conveniently, by test flying the heli. A small change in the TX ATV value can make a big difference.
Hope that helps, and good luck with your tail!
2Doggs is offline Find More Posts by 2Doggs
Question Hitec servo programming, center and end points tb47 Radios 4 Jun 24, 2012 07:30 PM
Discussion Boosted end points, VS. longer servo arms.. SteveT. 3D Flying 14 Oct 20, 2009 10:40 PM
Discussion Hi-Tec 500 Gyro tail end points Heritic Mini Helis 3 Mar 03, 2009 06:38 AM
V-tail and servo end point adjustment?? RBF Parkflyers 0 Jun 08, 2004 09:47 PM
End points for Corona Tail Servo gregw Electric Heli Talk 2 Feb 21, 2003 10:33 AM
