1. No, you did not buy the wrong tx. I own the same futaba and played with a spektrum so I know for sure, you did not buy the wrong tx.
2 and 3. On the other hand, you won't be able to use the s-bus on the nanoquad. Only the Mega boards are able to use an s-bus receiver according to the code below: /******************************* SBUS RECIVER ************************************/ /* The following line apply only for Futaba S-Bus Receiver on MEGA boards at RX1 only (Serial 1). You have to invert the S-Bus-Serial Signal e.g. with a Hex-Inverter like IC SN74 LS 04 */ //#define SBUS 4. what do you call cheap ![]() But seriously, keep the futaba. it's a great transmitter that is developed through years of experience. Try to find a small receiver for the nanoquad although a "normal" size receiver will do too. Especially for my NanoQuad, I ordered a smal receiver at hobbyking and could let you know if it works. |
Joined Feb 2013
I've seen some hacking (voided warranty) on a fubata Rx to get the PPM sum signal out, any way possible to do this with any other receiver out on the market today that is FASST compatible?
or Is there any such Rx out there (FASST compatible) that can use the satellite signal cable? I'm trying really hard to try and use only 1 - 3 wire cable instead of 4-6 cables. good find on that tiny Rx though ;o |
Joined Feb 2013
![]() ![]() ![]() ![]() ![]() very nice Sandav!!!! That looks awesome! Hobbyking should sponsor you because I just ordered a couple of these little guys bc of you!
It flies very stable and much faster than I expected. I haven't flown much outside because it's cold and wet, right now it's snowing again. The esc's will be flashed with SimonK firmware but I'm waiting for some small connectors I bought of ebay. They fit straight on the esc solder pads so I have a connection point for future upgrades on the esc's. |
| Thread Tools | |
| Build Log MiniWii NanoQuad V2 | SebastianJ | Multirotor Talk | 112 | Dec 17, 2012 02:08 PM |
| For Sale Flyduino Mega // Flyduino Cheese Plate // Gimbal // Servo // Suppo 2212/13 Motor &ESC | Jessestr | Aircraft - Electric - Multirotor (FS/W) | 12 | Jul 20, 2012 06:57 AM |
| Help! Hexa-H configuration - Flyduino | funfox | Multirotor Talk | 2 | Mar 04, 2012 01:29 AM |
| Build Log MultiWii NanoQuad and NanoHex | ben123 | Multirotor Talk | 32 | Nov 30, 2011 02:46 PM |
