Old Sep 27, 2012, 10:51 AM
tindsor is offline
Find More Posts by tindsor
Allerod, Denmark
Joined Sep 2004
Which 5-blade rotor head for 700E?
Hi,
I have just bought a new 700E mechanics and a Huges MD500 scale body to put it in. To make it nicer I want to put a 5 blade head on it
I have looked at a couple of options:
Sportsmoto: http://www.sportsmoto.co.uk/acatalog...rts.html#a3743
cnchelicopter (xmchobbies): http://www.cnchelicopter.com/servlet...ss-Head/Detail
Scaleflying.de: http://www.scaleflying.de/product_in...ny--700er.html
I have tried looking around but could not find many reviews of these. Have any of you tried them (maybe with a different number of blades) or can recommend something else? The Sportsmoto one seems really nice, but my biggest concern is that it might be a little overengineered.
Thanks for you help guys,
Anders
tindsor is offline Find More Posts by tindsor
Old Sep 27, 2012, 01:25 PM
viggen65 is offline
Find More Posts by viggen65
Sweden, Gothenburg
Joined Aug 2005
Originally Posted by tindsor View Post
Hi,
Anders
Anders, I have ordered the 4 bladed head from Sportsmoto to mine Eurocopter tiger, Really like the looks of it, especially the maingripbolts, dont know much about it but the price seems fair,gone try and evalute it,I have talked to Mark as it stated that the linkballs are not included but he said that everything is included exept
the pushrods,in case of the pushrods the existing one that comes with the trex are used.
Cheers
Jack
viggen65 is offline Find More Posts by viggen65
Old Sep 29, 2012, 09:36 AM
tindsor is offline
Allerod, Denmark
Joined Sep 2004
I just read a very positive review of the Sportsmoto head in Model Helicopter World (May 2012 issue), so I bougt it now
Found it on ebay (http://www.ebay.co.uk/itm/700-Scale-...item2c6621e788) from the same seller for 279 incl transportation to Denmark, so that seems a pretty good bargain.
I will give a little review myself once I get it.
Old Sep 30, 2012, 12:58 AM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
i can help you to buy this head in good price , they are one of my soucing company . pm me !
kin is offline Find More Posts by kin
Old Oct 01, 2012, 12:09 PM
rotoraddict is offline
Find More Posts by rotoraddict
Joined Jul 2008
Here are two high quality ones that are well worth considering:
metal blade grips:
http://www.centuryheli.com/products/...MV2&pageid=472
or with Glass Reinforced Plastic blade grips:
http://www.centuryheli.com/products/...105&pageid=472
rotoraddict is offline Find More Posts by rotoraddict
Old Oct 01, 2012, 06:41 PM
Keyrigger is offline
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
Although I have only bought the 600 size rotor head, I also would give a recommendation for the Century head, either version. The one I have is very smooth and set up very easy. Good luck and take care.
Don
Keyrigger is offline Find More Posts by Keyrigger
Old Oct 02, 2012, 01:09 PM
Scaleman01 is offline
Find More Posts by Scaleman01
Joined Feb 2012
you are looking for goor quality heads ?
Take a look at our hp, all Made in Germany
http://www.scaleflying.de/index.php?...otorheads.html
Scaleman01 is offline Find More Posts by Scaleman01
Old Oct 02, 2012, 01:18 PM
Cyclick is offline
Find More Posts by Cyclick
Joined Dec 2007
I have never had a multiblade heli, but I also would recommend the Century rotor head as there are four of them at our local field and all perform very well.
Cyclick is offline Find More Posts by Cyclick
Old Oct 02, 2012, 03:55 PM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
Today i got mine monsterhead from sportsmoto.....wow,what a piece of art,also very grateful to Mark for his outstanding service and very god mailcontact,hope the head perform as good as it looks!!
Cheers
Jack
Old Oct 03, 2012, 06:53 AM
Joined Feb 2012
you need to have look at the swash plate.
Servo and blade grips level are not on the same height, this will have the affect of a strange control.
Only as Info before your first flight.
Old Oct 03, 2012, 07:08 AM
viggen65 is offline
Sweden, Gothenburg
Joined Aug 2005
see what you mean, in worst case changing the swashplate, but the head is superb..
Cheers
Jack
Old Oct 03, 2012, 07:53 AM
Brutus1967 is online now
Find More Posts by Brutus1967
The Netherlands
Joined Nov 2009
Should not really give much problems, because the "inner ring" ball joints are in the same plane with the swash plate swivel point, so control movement of the blades will be evenly distributed all around the cyclic movement.
Only possible effect is, due to the "outer ring" ball links being below the swash plate swivel point, that ailleron or elevator commands will have a slight negative pitch movement as side effect, but that should not be too problematic.
With a four point control it micht cause some additional strain on the servo's however but as far as I can see, that is not the case here.
It would be different if the swash plate swivel point woild be lowered to the "outer ring" level: in that case cyclic movement would not be distributed evenly. But that is not the case either.
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Feb 17, 2016, 08:58 PM
planekrzy is offline
Find More Posts by planekrzy
planekrzy
Yakima,WA
Joined Jan 2011
Anders
Saw your 700 rex video on you tube.Can you help with setup.I have a 700 trex with 5 blade head 500kv scorpion motor and castle 120hv esc.I have never done one and think the motor they recomended may be to big.Did you use stock gearing?And how did you fix tail hold problem?
planekrzy is offline Find More Posts by planekrzy
Old Feb 18, 2016, 05:27 AM
tindsor is offline
Allerod, Denmark
Joined Sep 2004
Hi,
I think that with the castle esc you need a different motor as they tend to get hot when running at a very low throttle. On my setup I'm using a scopion 330kV motor on 12S and at 90% that gives around 1350 RPM which seems very good for approx 8 kg of heli. For main blades I'm using the Spinblades Matt Black scale 700mm asymetrical and they provide very good lift.
I had big trouble with lack of tail power using the standard gearing for the Trex 700E due to the high inertia of the main rotor, but the solution was to use also asymetrical tail blades and changing to a 104T tail drive gear and 21T torque tube front drive gear set from the Nitro version.
Old Feb 19, 2016, 12:00 AM
planekrzy
Yakima,WA
Joined Jan 2011
Thanks for the info I was affraid that motor was going to be to much.So you used the tail rotor drive gear and torque tube gears from the nitro trex 700? Do you have an email or facebook page? May have more questions as I get closer to first flight. New to scale helis and this is my first ekectric as well as beastx and multi blade so appreciate the feedback.My name Is Ryan Siebol have facebook page and email is fordfnstic@gmail.com
For Sale 450 size 5 blade head and 5 blade tail rotor drakonis Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2014 09:29 PM
Help! Trex 250 5 blade rotor head leereyn Micro Helis 5 Mar 02, 2014 05:04 AM
Alfa 5 bladed Rotor and 5 rotor plugs NEW $5.00 for shipping Mikey 68 Non R/C Items (FS/W) 0 Feb 26, 2012 11:42 PM
Wanted I want a 5 blade rotor head for a Rex 450 !!!! J_Cunny Aircraft - Electric - Helis (FS/W) 1 Jan 08, 2012 01:17 PM
Discussion Which 4-blades rotor head for my Trex450pro ? Kira Nakazato Scale Helicopters 5 Jun 11, 2011 01:39 PM
