Old Sep 30, 2012, 02:24 PM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Gee what a great review. Right from the start problems with servos. I know price is lower but its a heli only. Even if you get different sevos they need to be reversed with a programer/ what a f*@# mess. I sure hope Walkrea wakes up to this. Sure big let down as I like this bird[did] till read more of this post.. Great job guys looks like they sure picked right folks to tear this bird apart. Oh well maybe build a quad.
dankar04 is offline Find More Posts by dankar04
Old Sep 30, 2012, 02:54 PM
54885488 is offline
Find More Posts by 54885488
Joined Jan 2012
Originally Posted by xtian3188 View Post
expensive heli with such serious issues. good thing i read these threads first before buying one. can you replace master cp's servos with emax ES08MD?.
I would hardly call this a expensive heli and like others have reported it flys great and the servos are not even close to a deal breaker . Go price what you will have in a trex or gaui in this size .
54885488 is offline Find More Posts by 54885488
Old Sep 30, 2012, 08:28 PM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Anyone?
Originally Posted by Razors edge 29 View Post
Anyone?
Hs5055mg and programmer on route
But
Was wondering why couldnt a person reverse servo via programmable tx? Is it because of Walkera electronics or?
Also does this programmer only work in hitec servos?
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Sep 30, 2012, 08:44 PM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Anyone?
Apparently, you can reverse the servos but the gyro still compensates in the same direction. It may be possible to correct this by mounting the receiver upside down.
zadaw is offline Find More Posts by zadaw
Old Sep 30, 2012, 08:53 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Ok so it is Walkera electronics that are the culprut
Old Sep 30, 2012, 09:13 PM
zadaw is offline
Hong Kong
Joined Jan 2010
You can change the direction of compensation with the FBL systems on larger helis, This includes the rx2702D. But you cannot do it on smaller cheaper helis. This applies to other brands as well. I don't think they intended or wanted you to use third party servos. Another reason is that it would make the setup much more complicated which is not that good for beginners.
Old Sep 30, 2012, 09:48 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Today i used a cheap 5 gram servo and didnt habe to reverse anything
Old Sep 30, 2012, 11:25 PM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
I can only comment about my Hitec servos, what happened when i initially setup is that i found i had to reverse the pitch, ail, and elev in the transmitter in order for them to move in the correct directions. Afterwards I found that the gyro would correct in the same direction which is very bad. So I reversed the servos AND set the transmitter back to normal and then everything was fine. (i reversed the reverse so to speak)
Now, as on of the previous posters mentioned as this being done on purpose by Walkera....I don't think so, I think it matches what they already have on hand because these are the exact same servos on other models. Also, when you buy more expensive flybarless units they know you may have servos that move in the opposite direction and they give you a way to reverse right in the gyro programming.
If you purchased the Hitec's, the programmer, and some batteries. Yes, you will be pushing your costs up but it's still less than a real flybarless trex. But you get a good flying heli that is MUCH easier and less expensive to repair. Less time on repairs and cheaper repairs is exactly what I need since I still crash a lot more than I'd like. What it boils down to though is do I enjoy flying it and I can say wholeheartedly that this is a fun little chopper and it was well worth the money.....even the money I spent upgrading it. Hopefully I have helped some others since I already know, and listed, what headaches may arise in upgrading.
Happy flying everyone!
pmerritt is online now Find More Posts by pmerritt
Old Oct 01, 2012, 04:45 PM
Joined Oct 2010
I just came from a park just threw a battery through the MasterCP, I tried out a 15t pinion today. I flipped her a couple of times and that went well, I didn't feel any problem with headspeed at all with this config and it's quick enough to be scary to me, i've been flying the little heli's too much, not used to a fast helicopter. I did notice the tail having just the slightest trouble with keeping up but it wasn't bad at all. Just a little wobble from time to time and not the rock solid feel you get from a belt or TT. I'm very happy with this little thing so far. oh, btw, not sure if it's the new servos or what but i'm going to have to turn down the travel on aileron. this thing was ready to do a roll when i was giving it maybe 30%-40% stick and i'm talking serious roll. So i'm definitely going to have to tweak that some. Question for those of you who have lost it, was it because it was far away or was it because of the sun? One thing I didn't have a problem with was seeing it, I also wear sunglasses when the sun is out...it helps tremendously. Not to mention you still look cool after you crash (nobody can see the tears) lol.
Old Oct 02, 2012, 11:17 PM
candy76man is offline
Find More Posts by candy76man
alienfpv, warpquad, goby180
Tampa,FL
Joined Dec 2003
Originally Posted by pmerritt View Post
I just picked up three more batteries....GensAce 1300mah and they should fit if the dimensions listed are correct. Should give a nice flight time increase. Best thing is it only cost 35.00 shipped
Did you get those gens ace packs in yet? do they fit?
I ordered my mastercp tonight and also ordered six of these turnigy packs which, according to the listed dimensions, are a bit thinner than the gens ace 1300's so I am hoping I will be able to squeeze them in. It would be nice to be able to use the stock battery holder so I hope they fit.
candy76man is offline Find More Posts by candy76man
Old Oct 03, 2012, 12:40 AM
Joined Oct 2010
nope, about 2mm too thick....battery mount could easily be modified to fit them but it would screw with the placement of my brushless esc....just gonna leave well enough alone.....i am quite certain i will find a new home for those batteries in some other project.
Old Oct 03, 2012, 06:16 AM
Tampa,FL
Joined Dec 2003
hmm, well the nanotechs are about 2mm thinner so hopefully I'll be able to squeeze them in without modification
Old Oct 03, 2012, 07:50 AM
mono is offline
Find More Posts by mono
mono's Avatar
Joined Aug 2008
I not sure those 1300 Turnigys will go in there either, they are 22mm thick.
When looking through my battery collection for one which would fit it (I got the BNF version without the battery), I found an RC Smart one that looked perfect. Measured it with calipers, 19.6mm thick all the way along, but, it would not slide more than a short distance into the tray.
The tray was actually distorting a little as it was. So I think 18-19mm maximum thickness to avoid problems.
One of the members posted the internal measurements of the tray a while back... 66mm X 37mm X 19mm (height). You can have a batt longer than 66mm though, as this Turnigy has been used...
http://www.hobbyking.com/hobbyking/s...dproduct=11901
mono is offline Find More Posts by mono
Old Oct 03, 2012, 09:46 AM
Tampa,FL
Joined Dec 2003
yeah I saw those measurements and knew I was rolling the dice with the 1300 mah packs but I really want that extra minute or two of run time per pack...Most of my other heli's have been modded to fit larger packs so this one will be no different I guess
Old Oct 03, 2012, 10:00 AM
mono is offline
mono's Avatar
Joined Aug 2008
If you're fine with modding the tray, then it's all good.
I was disappointed my battery would not fit, as it's a 1450mah, but I'm not going to hack the heli just for a couple of batteries I've had for about 4 years
Mini-Review Walkera QR Ladybird Review - Pictures, Video, Flight Times, and Thrust Tom Z Mini Multirotors 984 Dec 20, 2015 10:12 PM
Mini-Review Walkera V100D01 Review with Pictures, Video, Flight Times, Motor and Pinion Options Tom Z Micro Helis 2114 Oct 17, 2015 01:54 AM
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
Mini-Review Walkera Mini CP Review - Pictures, Video, Flight Times, Head Speed, Brushless Upgrade Tom Z Micro Helis 701 Aug 17, 2014 11:54 AM
Data Walkera 4G6/M120/V120 Spreadsheet: Motors, Flight Time, Head Speed, Pinion, Lipo, Esc Tom Z Micro Helis 5 Jun 16, 2011 09:52 AM
