Old Dec 07, 2012, 06:08 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Originally Posted by pmerritt View Post
i wish i could fly my mastercp....too friggin cold out for flying anymore. Just gonna tinker and sim for now. Sim is so boring these days but i'm still working on inverted circuits....my brain doesn't want to grasp it for some reason.
I used the SIM to learn inverted hovering but never used it to learn inverted circuits. However, it was just like learning inverted hovering. Everything suddenly clicks and fall into place. I have been using the V120D02S to lean inverted circuits but was having a financial bloodbath because of it. I was spending up to $50 to $100 per week in parts. I was forced to go back to the mCPX but the cost was not that much lower. This was probably because mCPX parts were much more expensive. Still I appreciate the fact that repairs could be easily carried out at the flying field. Eventually I closed the deal with the Mini CP which I think is one of the greatest inverted flight trainer around.
The process of learning inverted flight was so difficult that I am very hesitant on learning reverse flight. The big problem I encountered with learning inverted flight was that I had many crashes with upright flight because of confusion. There was a horrible patch when I had to use the SIM to learn how to fly upright again. I was so frustrated that I wanted to scream. It was as if nearly 20 years of flight experience had been lost.
The Master CP just sort of grows on you. Now after 120 flights and many crashes. I found that the repair costs are probably lower than that of the V120D02S. That is as long as the problem with the servos are sorted out.
zadaw is offline Find More Posts by zadaw
Old Dec 07, 2012, 08:26 AM
nelsonlee is offline
Find More Posts by nelsonlee
Malaysia
Joined Nov 2012
Master CP-Servos (WK-7.6-6)
My 3 original servos (wk-7.6-6) has Stripped and i ordered new to replace it to my CP, but i forgot to mark which servos should connect to the receiver position!
Need someone expert to correction my replaced servos for PIT/AILE/ELEV for it.
Below is the picture....
Name: Master CP_Servos Install.jpg
Description:
nelsonlee is offline Find More Posts by nelsonlee
Old Dec 07, 2012, 10:24 AM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
While I'm not truly proficient at reverse flight yet, I do find it much, much easier than inverted so far. What I can't imagine is inverted reverse flight.
pmerritt is online now Find More Posts by pmerritt
Old Dec 07, 2012, 11:10 AM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Get the hobbyking transmitter underwear, its been tested and holds your hands warm even at -20. Do make sure to store your batteris somewhere warm like a inner pocket or a shielded box.
http://www.hobbyking.com/hobbyking/s...uff_Black.html
HobbyKing Daily - Turnigy Transmitter Glove (1 min 44 sec)
Though, i expect the durability of the master cp is much lower in the cold, as the plastic stiffens up more.
Xermalk is online now Find More Posts by Xermalk
Old Dec 07, 2012, 11:26 AM
jazzjohn is offline
Find More Posts by jazzjohn
Madison WI
Joined Jan 2009
Zadaw, I'm right behind you. I can hover inverted on the sim, but it's still a chore to even keep the heli in a small area. I'm thinking about it too much. I've been attempting inverted with my Genius in order to hold down crash costs, but even there the replacement parts (especially servos without replacement gear availability) add up. (When a cheaper, Deviation-compatible micro comes out I'm there!)
I won't even attempt inverted with V120 yet. That's where I hope the Master CP comes in. I'm still waiting for it in the mail, but have been following threads about the servo options.
jazzjohn is offline Find More Posts by jazzjohn
Old Dec 07, 2012, 11:38 AM
Malaysia
Joined Nov 2012
BangGood selling Walkera Master CP RC Helicopter Spare Parts Metal Servo WK-7.6-9 HM-Master CP-Z-28 only US$ 10.37 with free shipping!
Description:
http://www.banggood.com/Wholesale-Wa...080763201209MY
Old Dec 07, 2012, 11:45 AM
jazzjohn is offline
Madison WI
Joined Jan 2009
Attachment 5356096
Too late -out of stock!
Old Dec 07, 2012, 12:22 PM
Malaysia
Joined Nov 2012
Just keep looking....it will available anytimes!
Old Dec 07, 2012, 01:39 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Slow the sim time speed to about 70%. I did that and in several days, I was back to 100% and able to keep in the air for ten minutes at a time instead of 10 seconds.
BThirsk is offline Find More Posts by BThirsk
Old Dec 09, 2012, 05:04 PM
RCCrashTestDummy is offline
Find More Posts by RCCrashTestDummy
Finding Creative Ways To Crash
RCCrashTestDummy's Avatar
Joined Jun 2012
Hey Guys,
Just a heads-up; I'm selling my whole set-up here: (All NIB)
http://www.rcgroups.com/forums/showt...9#post23484857
1x Master CP Heli
6x Servos
6x Zippy Compact Batts 1,000mah/3S/35C
3x Main Gear
all $180 + shipping (I'm in the U.S.)
Pretty much all you need to get started - the Tx
-Pat
RCCrashTestDummy is offline Find More Posts by RCCrashTestDummy
Old Dec 10, 2012, 06:05 AM
xiswell is offline
Find More Posts by xiswell
Joined Dec 2012
hello
hello guys.. i recently had a nasty crash..and things just went exploded to bits..
now after ordering my new parts..
can someone tell me...wats the length of the ball links that connects to the swashplate and blade holders..coz i lost all the original ball links...
is the links screwed all the way down till we can't see anymore threads on the rod?
need help..
im a newbie in this..
xiswell is offline Find More Posts by xiswell
Old Dec 12, 2012, 07:30 AM
candy76man is online now
Find More Posts by candy76man
alienfpv, warpquad, goby180
Tampa,FL
Joined Dec 2003
need help..
You may have already got your answer but on my mastercp the swash to grip length is 31mm and the servo to swash length is 27mm. These measurements are both from the center of the ball to center of ball, not overall tie rod length. A little bit of thread is still visible on all links.
candy76man is online now Find More Posts by candy76man
Old Dec 13, 2012, 01:52 PM
weedan is offline
Find More Posts by weedan
weedan's Avatar
United States, WI, Janesville
Joined Apr 2011
Setup for the Devo 10
I used the set up sheet that came with the master cp. When I tried to fly it it was like trying to fly an old Honey Bee. The set up sheet said to have the Gyro Sensor in manual, Mix switch and at 75 %. Sevral folks have psoted about using the Mini Cp set up.. Whats the best choice? With the set up sheet it seems that there is no gyro at all. Does anyone have the Master set up for the Devo 10?
weedan is offline Find More Posts by weedan
Old Dec 13, 2012, 02:07 PM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
MCP Maiden brief flight....> its alive !!
Mine came with no battery but have some similar size and riged it for a short hop. Up she went and seems to handle pretty sweet. Flew it in bedroon so took it real easy. Sure handles alot better than 100 size FBL helis/ Even Genius handles better than Super F/P/ V100D01. I sure need more flight time but it is very much going to happen !!. Nice and easy does it...> Yeahhhh!!
dankar04 is offline Find More Posts by dankar04
Old Dec 13, 2012, 04:23 PM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
I have the Master CP setup guides in my sticky and have the Devo 10.
The Master CP 3D setup is fine tuned for no bogging of the motor.
You can aslo use the Mini CP settings which work well also. I have Beginner Settings, Intermediate to Advanced Settings, and 3D Settings.
http://www.rcgroups.com/forums/showthread.php?t=1325037
Tom
Tom Z is offline Find More Posts by Tom Z
Mini-Review Walkera QR Ladybird Review - Pictures, Video, Flight Times, and Thrust Tom Z Mini Multirotors 984 Dec 20, 2015 10:12 PM
Mini-Review Walkera V100D01 Review with Pictures, Video, Flight Times, Motor and Pinion Options Tom Z Micro Helis 2114 Oct 17, 2015 01:54 AM
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
Mini-Review Walkera Mini CP Review - Pictures, Video, Flight Times, Head Speed, Brushless Upgrade Tom Z Micro Helis 701 Aug 17, 2014 11:54 AM
Data Walkera 4G6/M120/V120 Spreadsheet: Motors, Flight Time, Head Speed, Pinion, Lipo, Esc Tom Z Micro Helis 5 Jun 16, 2011 09:52 AM
