Old Dec 03, 2012, 09:30 AM
addifromgermany is offline
Find More Posts by addifromgermany
Joined Sep 2012
Originally Posted by dankar04 View Post
Cost looks no more than Futaba 3114's/ lower than hi-tech H5055's. . Will the Hi-tech servos work as is in V400D02 ? And Futaba 3114's work in Master C/P as is ?? I have new V400D02, and Mastrer c/p is on the way from X-heli. I was aware of sevo issue. Plus bought extra motors. V400D02 cost me $114.00 shipped. Master C/P was $113.00 + $14.00 postage. For a 400 sized/ and 250 size not bad even with servos. Yes they have issues I can live with as I'm not heli beater.
Futaba 3114 fit in perfectly into the master, you can also just use the gears from the Futabas in the Walkera Servos.
addifromgermany is offline Find More Posts by addifromgermany
Old Dec 03, 2012, 11:47 AM
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Do not, i repeat do not use the gears from the S3114 in a walkera servo. thats how my heli had its second crash, the gears almost fit, but if you use a slightly lager battery like i tried to do the gears will slip. this resulted in a pretty nasty crash dive. and im still waiting for spare parts from slower then slow banggood.
Just replace all the stock servos.
Xermalk is offline Find More Posts by Xermalk
Old Dec 04, 2012, 12:12 PM
Joined Sep 2012
Yesterday i did a brushless conversion on the master cp
http://www.rcgroups.com/forums/showt...8#post23438976
I am flying with emax ES08MD digital metall gear servos, nearly indestructable
Old Dec 05, 2012, 09:45 PM
valestrife is offline
Find More Posts by valestrife
Indonesia, Jakarta Capital Region, Jakarta
Joined Nov 2012
Originally Posted by valestrife View Post
http://www.hobbyking.com/hobbyking/s...dProduct=17321
try to replace my servos with this..still in "shipped" state..coming soon the review
Here is some picture of my master Cp with these servo (Turnigy 9025 metal gear servos and it went in the right direction no need to re wire them!)
you just need to modify the both ears of the servo,cut it out and then put it under the servo holder which is unite with the swashplate guide,and for more hold just use 2 pcs of cable tis,it will hold the servo well,i test hovering with this servos and all good,very strong for aileron and PIT,i havent put it for elevator's servo because the frame really dont fit,need to do some mods for the frame and i aint gonna do that,i want to keep the frame original..and i havent tried 3D movement with this servo because im not good at it..
valestrife is offline Find More Posts by valestrife
Old Dec 06, 2012, 02:18 AM
one01 is offline
Find More Posts by one01
Hobbyone
Joined Aug 2011
Originally Posted by nelsonlee View Post
It showing available soon......not yet available
The master cp metal gear servo will be available on 12th Dec. , next Wed.
one01 is offline Find More Posts by one01
Old Dec 06, 2012, 06:21 AM
RaymondM is online now
Find More Posts by RaymondM
Multirotor Promotor
RaymondM's Avatar
United States, MI, Cadillac
Joined Apr 2011
Great, thanks for the heads up!
RaymondM is online now Find More Posts by RaymondM
Old Dec 06, 2012, 08:56 AM
jazzjohn is offline
Find More Posts by jazzjohn
Madison WI
Joined Jan 2009
Is the ES08MD a direct, drop-in replacement?
jazzjohn is offline Find More Posts by jazzjohn
Old Dec 06, 2012, 09:50 AM
Joined Sep 2012
No, you have to modify the frame with a dremel and the front servo had to be fixed with epoxy.
Took an hour for all 3 Servos, but they never broke again, even at crashs after inverted flight (tries) and high speed
Old Dec 06, 2012, 05:54 PM
jazzjohn is offline
Madison WI
Joined Jan 2009
The S3114 costs about twice as much as the stock servo and the replacement gear set (plastic) costs almost as much as the stock servo.
What are the advantages?
Old Dec 06, 2012, 07:31 PM
nelsonlee is offline
Find More Posts by nelsonlee
Malaysia
Joined Nov 2012
Then how about Metal Gear Servos for Walkera V400D02?
Do you know when their will release it?
nelsonlee is offline Find More Posts by nelsonlee
Old Dec 06, 2012, 08:47 PM
pmerritt is offline
Find More Posts by pmerritt
Joined Oct 2010
The stock servos are the same ones in the v400D02....think about it
pmerritt is offline Find More Posts by pmerritt
Old Dec 06, 2012, 09:04 PM
one01 is offline
Hobbyone
Joined Aug 2011
the V400D02 metal gear servo still in processing . I will keep you update.
Old Dec 06, 2012, 11:08 PM
Malaysia
Joined Nov 2012
You mean the CP Metal servos are same with V400D02?
Old Dec 07, 2012, 12:41 AM
zadaw is online now
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
The servos of the V400D02 may move in the opposite direction to the servos on the Master CP. So you better be careful about it.
zadaw is online now Find More Posts by zadaw
Old Dec 07, 2012, 05:56 AM
pmerritt is offline
Joined Oct 2010
i wish i could fly my mastercp....too friggin cold out for flying anymore. Just gonna tinker and sim for now. Sim is so boring these days but i'm still working on inverted circuits....my brain doesn't want to grasp it for some reason.
Mini-Review Walkera QR Ladybird Review - Pictures, Video, Flight Times, and Thrust Tom Z Mini Multirotors 984 Dec 20, 2015 10:12 PM
Mini-Review Walkera V100D01 Review with Pictures, Video, Flight Times, Motor and Pinion Options Tom Z Micro Helis 2114 Oct 17, 2015 01:54 AM
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
Mini-Review Walkera Mini CP Review - Pictures, Video, Flight Times, Head Speed, Brushless Upgrade Tom Z Micro Helis 701 Aug 17, 2014 11:54 AM
Data Walkera 4G6/M120/V120 Spreadsheet: Motors, Flight Time, Head Speed, Pinion, Lipo, Esc Tom Z Micro Helis 5 Jun 16, 2011 09:52 AM
