Old Sep 27, 2012, 05:01 AM
rondean1 is offline
Find More Posts by rondean1
Joined Mar 2007
more news from Deans Marine
More news from DEANS MARINE
we now have added a range of new items for the model boat hobby, this is a selection of the new items. More to follow.
Full details can be found on our website in the chandlers section.
P.R. 5
M2 Thread /2mm plain lightweight propshaft fitted in to a 140mm long 4mm tube, the tube is fitted with MINIATURE NEEDLE ROLLER bearings at the both ends.
P.R. 6
M2 Thread /2mm plain lightweight propshaft fitted in to a 140mm long 4mm tube, the tube is fitted with NYLON bearings at the both ends.]
P.R. 1
Bright steel 120mm tube fitted with Delrin water lubricated bearing at the prop end and bronze bearings at the inboard end
The steel shaft is a M4 thread for the prop, 2mm plain shaft at the inboard end and carries a reverse locking collar.
The outboard end of the tube has a moulded hard nylon skeg /bearing holder fitted onto the tube
P.R. 7
Hard Brass 85mm tube fitted with Delrin water lubricated bearings at both ends
The steel shaft is a M4 thread for the prop, 2mm plain shaft at the inboard end, the inboard carries a reverse locking collar.
PR 8
Bright steel 170mm heavyweight tube fitted with BRASS sintered bearing at the both ends of the tube and has a moulded hard nylon skeg fitted onto the tube
The steel shaft is a M4 thread, 220mm long a nylon oiler unit is also attached.
This unit is ideal for fast hulls when a serious amount of power is to be passed through the shaft.
PR 10
Bright steel 200mm heavyweight tube fitted with needle roller heavy duty bearing in a housing with oil fed hole at the inboard end and a delrin water lubricated bearing at the outboard end of the tube. The shaft is threaded M4 for the prop and 4mm plain at the motor end.
This unit is ideal for fast hulls when a serious amount of power is to be passed through the unit and smooth running is required.
RDM-2 Mini geared motors suitable for drive to radars and scanners 38mm x 10mm Will run on 1v -7.2 volts 6volts will give 60 R.P.M. wt = 9gms
RDM-3
Mini geared motors suitable for drive to radars and scanners 38mm x 10mm Will run on 3v -6 volts 6volts will give 100 R.P.M. wt = 9gms
Regards
Deans Marine
rondean1 is offline Find More Posts by rondean1
Discussion more news from Deans Marine rondean1 Scale Boats 2 Sep 22, 2012 12:54 AM
Discussion new from Dean Marine rondean1 Scale Boats 0 Sep 17, 2012 06:00 AM
Discussion news from DEANS MARINE rondean1 Scale Boats 54 Aug 19, 2012 06:23 PM
Discussion Deans marine news rondean1 Scale Boats 4 Jul 17, 2012 03:04 PM
Discussion News from Deans Marine rondean1 Scale Boats 2 Oct 28, 2010 03:29 PM
