Old Sep 27, 2012, 12:54 AM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
1S ESC, 5V System. I got this right, right?
I'm pretty confident that I got this right, but even the astronauts in the Apollo missions asked for a orbital calculation math check before executing a burn.
This ESC takes the input power for the motor through the control lead. Attached is a picture of the intended usage diagram, with my diagram below it. I'm running a gyro, though, with a minimum of 5V, so I need a 5V step-up regulator.
Name: Screen Shot 2012-09-26 at 8.20.59 PM.png
Description:
Yeah, I did that in emacs. Paint wouldn't launch.
acetech09 is offline Find More Posts by acetech09
Old Sep 27, 2012, 01:04 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Are you sure ESC will burn if powered at 5V ?
It's right as above, but I would try everything at 5V...
renatoa is offline Find More Posts by renatoa
Old Sep 27, 2012, 01:08 AM
acetech09's Avatar
Joined Apr 2012
The ESC uses the input from the control lead to power the motor. I don't want to run the motor through the step-up at 5V
Old Sep 27, 2012, 01:22 AM
renatoa is offline
Joined Sep 2007
Sure, depends what stepup and what motor...
I have a nano tricopter powered from 1s 750mAh, drawing 1.5Amps in hover. 1s wasn't enough, I must finally to power it at 5V to fly stable. Stepup is rated for 2Amps, and works cold so far.
Old Sep 27, 2012, 01:31 AM
acetech09's Avatar
Joined Apr 2012
Hmm. How efficient is the step up? I might run it like that.
Old Sep 27, 2012, 01:43 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Now that you told, you just gotta show some pics of that three, or have I missed them while searching from your attachments ?
msev is offline Find More Posts by msev
Old Sep 27, 2012, 01:49 AM
renatoa is offline
Joined Sep 2007
Didn't measured efficiency, sorry. Would be a bit difficult at these low Amps...
But a switching unit, if cold, can't be less than 90%, any loss means heat.
msev, not finished yet, will post when ready.
Discussion 1S ESC, 5V System... Do I have this right? acetech09 Power Systems 0 Sep 26, 2012 10:23 PM
Discussion ESC Throttle Position vs Heat: Is This Guy Right? Gerry__ Power Systems 46 Sep 02, 2012 11:18 AM
Discussion You gotta admit, Bush got THIS right. SaulOhio Life, The Universe, and Politics 10 Jan 02, 2009 08:15 AM
Discussion Headtrackers: Have I got this right? tomp FPV Talk 15 May 25, 2007 03:01 AM
Just got lithiums and is this sound right? machine 3D Flying 14 Apr 13, 2004 12:30 AM
