Old Sep 27, 2012, 12:35 AM
oomodel is offline
Find More Posts by oomodel
Joined Feb 2012
Walkera New Product Forecast: V450D03
Walkera's new version 450 generation 2 is coming soon, it's 6 axis, still flybarless, it's both for beginners and experienced pilots.
main specification:
Main Rotor Dia. : 712mm
Tail Rotor Dia. : 150mm
Overall Length: 676mm
Weight:816g(Battery included)
Transmitter: DEVO 7(standard); DEVO-6/7E/8S/10/12S(Optional)
Receiver: RX-2703H-D
Battery: 11.1V 2600mAh Li-Po
You can view more details : http://www.oomodel.com/walkera-v450d03-generation-ii-6-axis-gyro-flybarless-helicopter-p-63948.html . Hopefully it will be ready by next month.
oomodel is offline Find More Posts by oomodel
Old Sep 27, 2012, 07:26 AM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
pretty cool . you should put this in the mini heli section though . this wont get too many views in the big 500 to 800 helicopter section .
jombo is offline Find More Posts by jombo
Old Oct 01, 2012, 12:52 AM
Demonofpyro is offline
Find More Posts by Demonofpyro
Joined Dec 2011
0.o
Hmm lets see, same shotty servos that will need to be changed.
Cheaper construction, i.e. uni-frame plastic; but that might be more resilient in moderate crashes, just more of a pain in bad ones.
Looks like the same type of skids on the 450D01 just no metal pipes this time, warning: they break easily.
I don't know how i feel about all plastic blade grips.
And fair warning if it's the same ESC that was on the 450D01 don't trust if for too long.
Although if it has the same main shaft dimentions as the D01 you can do the Align DFC mod to it.
Just my 2c
Demonofpyro is offline Find More Posts by Demonofpyro
Old Jul 04, 2013, 02:09 AM
Helifan Ensenada is offline
Find More Posts by Helifan Ensenada
Helifan Ensenada's Avatar
Mexico, BC, Ensenada Municipality
Joined Feb 2013
Fixed ID cancellation problem on Rx2703H-D
Hello,
I just bought a crashed V450D03 to use as a second bird. I am having problems cancelling the Fixed ID on this receiver.
Normally to perform the Fixed ID cancellation on a Walkera receiver one should insert the Bind Plug in the battery channel and then connect the power in order to get a slowly flashing light that signals the cancellation.
The problem is that the Rx2703H-D does NOT have a battery channel. The manual states that the bind plug should be inserted into the ELEVATOR channel. I have tried it several times, but I cannot get the receiver to flash slowly.
I have read on several posts and in Youtube that some people have had the same problem.
Does anybody know how to cancel the Fixed ID???
Any help will be appreciated,
Helifan
UPDATE 31.07.13
I updated the Receiver and Transmitter firmware using the UP03 cable and adapter and it solved the problem. I want to thank Jacky from helipal.com for answering all my emails and guiding me through the whole process.
My V450D03 is flying smoothly now.
Helifan Ensenada is offline Find More Posts by Helifan Ensenada
Old Apr 09, 2015, 11:27 PM
Downzy is offline
Find More Posts by Downzy
Jeff
United States, NH, Franklin
Joined Nov 2013
Can you tell me the steps you took to fix your receiver ...Any help would be helpful, running out of hair to pull out !!!
Thanks Jeff
Downzy is offline Find More Posts by Downzy
Discussion Latest product from Walkera: Walkera 62 - 2006 model tungnguyen Micro Helis 26 Sep 04, 2013 11:04 AM
Discussion New Product Forecast: Walkera smart adapter devention Hacking oomodel Radios 0 Aug 21, 2012 09:04 AM
New Product New Walkera 200SD3 Airwolf 4ch RC Helicopter Product Tour RaidenTech Mini Helis 2 Oct 07, 2011 12:16 PM
Cool WindFinder Forecast for New Century KTMRacr RC Barnstormers 0 Sep 13, 2011 01:39 AM
