Old Nov 13, 2012, 12:27 PM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Thanks very much VR Flyer!
I'll look into these goodies... Good thing I have a solid amateur radio background. I also have worked on novel antenna ideas over the years. May come up with a more solid link option down the road. Who knows?!
Very cool stuff though! I'll also look into the panning options. I may need a better or more elaborate TX for that stuff (currently using a DX6i).
Cheers and safe flying!
SkyCadet
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Old Nov 13, 2012, 12:46 PM
VRflyer is offline
Find More Posts by VRflyer
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
You love antennas, you must meet IBcrazy if you don't know him already. He is the God of the antennas!
http://www.rcgroups.com/forums/member.php?u=103113
Clover leaf are very popular: http://www.rcgroups.com/forums/showthread.php?t=1388264
I think Spironet antenna that I suggest above are inspired by Clover leaf from IBCrazy
VRflyer is offline Find More Posts by VRflyer
Old Nov 13, 2012, 01:37 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
SkyCadet,
Nice to meet another fellow ham op! N0NCO here. I also enjoy designing & building antennas. If you're interested, check out my QRZ page for a few pics of my latest 160-10m HF antenna.
VRflyer,
Thanks for taking the time to post your UM FPV setup in such detail. I've also been thinking about using the UMX Carbon Cub as an FPV platform. Any thoughts?
Joel
turboparker is offline Find More Posts by turboparker
Old Nov 13, 2012, 02:57 PM
VRflyer is offline
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
I also have a Carbon Cub on order, I will install FPV gear of course. I will post it on this thread when done with severals photos. It will be the same setup as my Beast, the cam install in the cabin on panning servo control via my headtracker. Only one lipo to power everything onboard.
About it, I will post in the next days detail explanation of my Beast. How to modify servo for extra panning, how to make realistic dashboard and info about the linear regulator I use to power the video gear from the main lipo
Old Nov 15, 2012, 08:58 AM
VRflyer is offline
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
I received a monitor like the one I suggest above in my DIY micro FPV setup thread.
http://www.foxtechfpv.com/foxtech-m8...tor-p-644.html
I am not impress... I was expecting better picture quality.
The monitor have an adjustement to get a brighter picture outside, I tough it will have a more powerfull backlighting, but the adjustement augment only the brightness . I can do the same by going in the MENU directly
I prefer my goggle and will continue with them. The monitor will be great for my friend to watch while I fly.
I will use it mainly at home, it will become a portable tv monitor. I will integrate a 5.8ghz receiver in the monitor, and install a 5.8ghz Tx on the tv cable box to transmit the tv signal to the monitor. So I will be able to watch my tv program when I go to sh...
I just have to think how much I pay for it and it will help...
Old Nov 24, 2012, 04:03 PM
VRflyer is offline
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
DIY Micro FPV setup (2)
Few posts above I suggested you a simple video setup that use a second lipo onboard to power the video cam and Tx. The setup that I use in my Beast is power from the main lipo, the second battery is replace with a linear regulator.
If you install a cam in the cockpit, you need a wide FOV. No cam are available with 110deg lens. You will buy a cam that have a 45deg lens and buy a 110deg lens.
http://www.fpvhobby.com/83-1-gram-nano-camera.html
http://www.fpvhobby.com/138-wide-ang...no-camera.html
Both cam and the Tx work on 5V. You will power them from the main lipo using a linear regulator:
http://www.flytron.com/camera-transm...regulator.html
If you intend to install the cam on a panning servo, you simply have to glue it on the servo arm. The arm move only 45deg on each side. I install one tiny resistor on each leg of the pot to extend the movement (see photo)
http://www.hobbyking.com/hobbyking/s...g_0_08sec.html
http://www.digikey.ca/product-detail...0CT-ND/1942567
The dashboard is made using a photo found on the web of the real Beast. I begin by reducing and printing one photo in B&W to found the good size for my Beast. Then I print two photos in color. On one photo I cut and remove the dials. I then place this photo on top of the other one with a plastic sheet between the two photos. It look like real dial with depth.
The cam and the 5.8Ghz Tx will be power at 5V from the linear voltage regulator
the red wire of the cam is solder to the VCC tab of the 5.8Ghz Tx. The black wire will be solder to the GND tab. The third wire of the cam is solder to the VIDEO tab of the Tx.
The output (5V) of the linear reg is solder to the VCC tab of the Tx. The GND output of the linear reg is solder to the GND of the Tx.
And the input of the linear reg (7-18V and GND) are solder to the wires of the 7.2V lipo connector
Do not forget to solder a wire between the CH1 and GND for channel selection.
The voltage regulator will heat a lot, it is normal. You can install on the battery tray on the side of the Tx. I use double side sticky tape wit foam between.
If you are interest in google, no one are perfect. You need good vision. Some have diopter lens available or adjustable focus but they are rare. Some have adjustement for interpupillar distance.
One goggle that have a integrate 5.8Ghz receiver compatible with the Tx I suggest and have a headtracker are the Foxtech goggle:
http://www.foxtechfpv.com/allinone-f...ade-p-258.html
Fatshark goggle have lightly better optic but the receiver frequencies ARE NOT COMPATIBLE with the Tx I suggest.
If you buy the goggle or use a video monitor on ground, don't forget to order the Fatshark Spironet antennas. You will use the receiver (Rx) antenna on your receiver
http://www.dpcav.com/xcart/5.8GHz-sp...stem-RHCP.html
http://www.dpcav.com/xcart/SMA-Jack-...g-Adapter.html
Head tracker are not compatible with most brand radio. If you use a Futaba high end model, you are ok. If you have other radio, probably it will not be compatible
Old Nov 24, 2012, 04:28 PM
VRflyer is offline
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Enjoy!
Micro FPV Beast no4 (1 min 59 sec)
Old Nov 24, 2012, 07:02 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
Note: fatsharks are not compatible with the rx, but you can make a module easily. You just get a rx module and solder the wires in the right order.
There's a how to here (if you don't read german, use google translate or uhm.. the images are enough really) http://fpv-community.de/showthread.p...ominator-bauen
On mine I'm trying to make a tiny LC filter to use one battery as well (mostly for fun/convenience since its lighter with a 50mah batt), but unless i put really big caps (2000uF) I still have lines. I know you're using 2 caps, I'm wondering how heavy it is for you and if you have a pic, i dont see it on the upper pics
CrashMeUp is offline Find More Posts by CrashMeUp
Old Nov 24, 2012, 07:29 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Originally Posted by VRflyer View Post
Enjoy!
OUCH! Still a beautiful video though!
RealGambler is offline Find More Posts by RealGambler
Old Nov 24, 2012, 08:04 PM
VRflyer is offline
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
I use the linear reg from Flytron and one cap 1000uf on the output of the reg, I can install it anywhere between the reg and the cam.
On the photo it miss the heatsink. total weight is around 3gr.
I still have little noise when the motor run, but it is acceptable at my taste
Old Nov 24, 2012, 08:11 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Bravo!
Silverexpress is offline Find More Posts by Silverexpress
Old Nov 25, 2012, 02:50 AM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
Ok thanks
I'm guessing its the regulator that makes the difference (I've the integrated reg from fpvhobby)
Old Nov 25, 2012, 10:27 AM
VRflyer is offline
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Do you use this regulator?
http://www.fpvhobby.com/111-12v-to-5...egulator-.html
it's a switching regulator,Flytron regulator is a linear regulator.
Switching regulator are more efficient and do not come hot like the linear regulator. But the output voltage is not clean like a voltage coming from a battery or from a linear regulator. With an oscilloscope you would see that the voltage fluctuate rapidly around 5V. The noise is also present all around the regulator and can be pick up by the wires or servo in the plane affecting the receiver onboard. So range check must be perform one time if you use switching reg to be sure the receiver onboard is not affect.
Linear regulator are less efficient, and become very hot if it have a big difference of voltage between the input and output of the regulator. The Flytron regulator I suggest will have 8V appr. at input and 5V at output, it will be hot but probably no heatsink is neccessary if you use the 200mW tx from FPV hobby. This Tx have his own voltage regulator inside and will drop the 5V to 3.3V internaly.
I use the 200mW Tx from Foxtech that must be power at 3.3V. So I use the other linear regulator from Flytron, this one have 3.3V output. In my situation, the regulator have 8V at input and 3.3V at output for my Tx. My regulator become very hot and need a little heatsink.
It need also a capacitor 1000uf because I use the Foxtech Tx. I'm pretty sure you will not need the capacitor if you use the FPVhobby Tx, because it have some cap internally.
I hope I will not confuse you too much...
Old Nov 25, 2012, 02:13 PM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
yes i was talking about the tx with integrated linear regulator. it certainly needs filtering for a 1 batt setup. lines are terrible on my ladybird and my ar6400 escs :-)
Old Jan 31, 2013, 07:18 PM
mgreinke is offline
Find More Posts by mgreinke
mgreinke's Avatar
Joined Sep 2011
I use only one Spektrum radio, the camera servo is plug in the fifth channel of the Brick onboard the plane. The headtracker is plug in the buddy port of my Futaba radio.
What brick do you use? Do you go without a rudder in order to be able to use the camera panning servo?
mgreinke is offline Find More Posts by mgreinke
Discussion UMX Beast vs UMX Sbach binaryclock Micro Ready-to-Fly 43 Apr 06, 2013 06:50 PM
Idea Proper pants for your UMX Sbach or Beast? ICU Micro Ready-to-Fly 53 Feb 02, 2012 02:55 PM
Wanted umx beast or sbach wrecked or guts terret725 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Aug 29, 2011 05:07 PM
Discussion PhoenixRC UMX Beast & UMX Sbach 342 Models MarkDeLo Simulators 2 Apr 30, 2011 02:28 PM
