Old Nov 30, 2003, 12:55 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
GWS UM-1 crystal lead is custom made 0.4mm
GWS UM-1 crystal lead is custom made 0.4mm ( 0.01575")
Pls make sure you got a right crystal! on your GWS R6N and R4P!!
GWS original UM-1 crystal lead is custom made 0.4mm ( 0.01575") at 10PPM Spec. Device was made in Japan by same reliable vendor of "F" Brand crystals.
Pls do not use cheap commercial grade crystal, it may cause crystal contact lost! Or too many frequency drift out of spec!
GWS UM-1 crystal inside has customized with stronger holder to protect crystal damaged by shock of crash.
Do not use a wrong spec cheap substitude UM-1 crystal which come with 0.012" lead! That may cause improperly contact and lost control!
GWS4CEO is offline Find More Posts by GWS4CEO
Old Nov 30, 2003, 01:08 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
GWS crystal problems?
Do you have any bad experience of GWS crystal problems?
Welcome to post here. So we can traceing where the bad clone crystal comes from?
Old Dec 01, 2003, 05:49 AM
hermperez is offline
Find More Posts by hermperez
know it all
Miami, Fl
Joined Nov 2003
how do you identify the crystals?, is there a UM-1 printed on it?
hermperez is offline Find More Posts by hermperez
Old Dec 16, 2003, 01:32 PM
sheerLuck is offline
Find More Posts by sheerLuck
Crash Site Instigator
sheerLuck's Avatar
Novato, CA USA
Joined Jan 2002
Just bought a batch of new crystals in order to switch to a less-used frequency. The vendor specified what looked like a GWS part number for them. I was concerned when I received them, as they all had a plastic frequency tab covering the writing on the crystals, so I couldn't see if they said GWS on them, like the old ones.
Got out the ol' micrometer, and sure enough the leads measured .016-.017" (cheap micrometer, probably not too accurate). I remember buying one generic, and the old one that didn't say GWS had leads that measured .013" (same cheap micrometer). It was working, but I'm glad it's out of my airplane.
Only question - the GWS ones that I removed had a thin plastic spacer under the crystal housing, and the new ones do not. Mr. Lin, do you think I received genuine GWS crystals ?
Thanks - Larry
sheerLuck is offline Find More Posts by sheerLuck
Old Dec 27, 2003, 11:25 AM
frankenfoamy is offline
Find More Posts by frankenfoamy
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
All the GWS crystals I have came on a cardboard card with a plastic bubble cover.
Mike AMA 2241
http://rcguy.tripod.com
frankenfoamy is offline Find More Posts by frankenfoamy
Old Apr 06, 2004, 04:54 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Pls do not use bad quality cheap crystal!
During WRAM show, I spoke with more than hundreds peoples who came to GWS stand to say thanks.
But A GWS with a cheap subsitute X'tal will cause range shorten and weak anti-vibration!
Pls, besure to buy a GWS original crystal.
For Sale HUGE GWS UM-1 Crystal Sale! 2dogrc Aircraft - General - Radio Equipment (FS/W) 23 Jul 15, 2007 10:37 PM
For Sale Give away or trade GWS UM-1 CH 21 xtal bc-slowflyer Aircraft - General - Radio Equipment (FS/W) 2 Jun 27, 2005 06:49 PM
For Sale Crystals: GWS UM-1 Channels: 12, 24, 54 hbsloper Aircraft - General - Radio Equipment (FS/W) 0 Jun 24, 2005 08:39 AM
Discussion GWS UM-1 crystal lead is custom made 0.4mm ( 0.01575") GWS4CEO Radios 1 Nov 30, 2003 01:06 PM
FS: GWS UM-1 x-tals....48,52 AL19044 Aircraft - Electric - Airplanes (FS/W) 3 Sep 14, 2003 11:01 PM
