Old Sep 26, 2012, 01:12 PM
antslake is offline
Find More Posts by antslake
How high will it go?
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Better way to wire anti-spark device
Don't know if this has been thought of before, but I made a diagram that shows a more effcient way of wiring up anti-spark devices on high voltage applications that will save you time, money and material. No modification needs to be done to your battery packs.
antslake is offline Find More Posts by antslake
Old Sep 26, 2012, 01:22 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Interesting, but I would like to see how you do one in reality, (photos), as cable flexibility including the resistor section can be important.
eflightray is online now Find More Posts by eflightray
Old Sep 26, 2012, 01:33 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
I haven't done one yet, but I don't see there being a problem as the resistor wire is going to be light gauge and very flexible. Your concern would be identical either way you wire it. I can wire up one this week and take some pictures.
Latest blog entry: FAA registration
Old Sep 26, 2012, 01:47 PM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
What's the big deal? It's been done much the same way for years.
highflyerbill is offline Find More Posts by highflyerbill
Old Sep 26, 2012, 02:14 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
I have yet to see a wiring diagram like the one I posted. Usually modification is needed to both battery pack and esc wiring requiring lots of materials and time to do, especially if you have several battery packs. Similar to this:
Old Sep 26, 2012, 02:22 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Also an article just published in Model Aviation pg94 also shows the less effective way of doing this. I wrote to the author of the article to explain my way.
I also just noticed on the RC-warbirds site, they have the same diagram that I just made for bullet connectors, but use that last one I posted for deans? I had never seen this before. Kind of figured I wasn't the first one to think of this.
Old Sep 26, 2012, 04:51 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
The only downside I can see is the extra bulk of the additional connector. I use 4mm bullet connectors on my 450 heli packs, and I'm not sure I could fit another connector inline - but then there's not much of a spark with my little 450 packs.
2Doggs is offline Find More Posts by 2Doggs
Old Sep 26, 2012, 05:35 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Well it's one more connector if you don't have one, but if you do it the other way it's going to be a lot less connectors and a lot less work to set up all your packs. That was the point, not whether you need one or not. The spark is not a good thing.
Old Sep 26, 2012, 05:53 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Yes, no offense intended, I can see the overall benefit of only having to mod the ESC, and keeping all the packs standard. I was just saying the additional bulk of the extra connector was the only downside I could think of. When I get around to building a 600 heli, I'll definitely consider adding the anti-spark device, if the ESC doesn't already have one built in.
Old Sep 26, 2012, 06:07 PM
wildnloose is offline
Find More Posts by wildnloose
Tulsa Int, Oklahoma, United States
Joined Oct 2003
To me, the bullet connectors from esprit models seems to provide the simplest method of preventing the spark.
http://www.espritmodel.com/jeti-afc-...s-4mm-75a.aspx
But, I'm cheap, and a simple resistor on my current bullet connectors will suffice.
wildnloose is offline Find More Posts by wildnloose
Old Sep 26, 2012, 08:22 PM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
The Turnigy Dlux 80 amp ESC has an arc supressor built in where a red wire coming out of it is touched to the main plus wire before you plug it in. Works very well
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Sep 26, 2012, 10:06 PM
antslake is offline
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Gord.
I have that very ESC in the marine model and I could never get the connection made fast enough after touching, and would get a spark anyway. In other words, there is no way (the way it came) to make the resistor connection, and then the main connection without breaking the resistor connection.
Old Sep 26, 2012, 10:11 PM
Joined Nov 2009
http://scriptasylum.com/rc_speed/nospark.html even gives you a resistor calculator
Old Sep 26, 2012, 10:43 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Antslake: I had the same problem till I took a bit of heatshrink peeled back where the wire solders to the Deans. Now I hold the jumper wire to that till I connect the Deans. No problem.
Gord.
Old Sep 27, 2012, 12:33 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
This looks like a simple one, though it means the resistor lead is exposed and 'live' -
http://www.rcgroups.com/forums/showp...69&postcount=3
It's from this thread - anti spark in the Castle Creations vendor forum.
Question Anti-bluescreen device - if non existent, who would buy one? montymintypie FPV Talk 127 Mar 22, 2015 10:16 PM
Idea .... 2MacGyver Multirotor Talk 0 Jul 18, 2012 11:01 AM
Question Anti Spark Device Nederland Power Systems 12 May 19, 2012 09:45 AM
For Sale xps anti-spark wire $5dollars shipped sherlockshah Aircraft - Electric - Power Systems (FS/W) 0 Nov 20, 2010 11:48 AM
Discussion anti spark devices for esc callen Castle Creations 2 Mar 10, 2008 08:16 AM
