Old Sep 26, 2012, 08:50 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Does removing the stock landing leg weaken a DJI frame arm?
I'd like to remove (or at least trim) the landing legs from the front two booms of my F550, to stop them appearing in the camera's field of view. I'm using a separate landing gear under the centre plate, obviously
That triangulated stock landing leg must brace the motor plate to the rest of the arm, to some extent. Does anybody know if this is significant?
If I get time I'm planning to clamp a stock leg upside down and hang a 1kg weight to the motor mount, measuring any deflection. Then remove the tip part of the landing leg and repeat. Finally remove all of the leg and repeat.
Any thoughts? Slightly restricting the gimbal pitch range would be preferable to having the motors come off in flight
Bill Glover is online now Find More Posts by Bill Glover
Old Sep 28, 2012, 07:13 PM
Joined Nov 2000
OK so I did my testing.
The answer is that the DJI 450/550 arm does not bend significantly more with the stock landing leg completely removed. With a 2 kg weight hung from the motor plate you're talking about fractions of a millimetre ... less than I could measure accurately. So I'll certainly remove them from the front booms ... possibly the others too. Removing the leg saves 5.5 grams ... so that would be 33 grams in total on a 550.
Out of interest the black arms I have are about a gram heavier than the white ones, and subjectively seem a little stiffer. I used a white one for the test.
Discussion DJI Frame Arm Color - Help iheli22 Multirotor Talk 16 Dec 04, 2012 06:05 PM
Sold DJI 450 Frame red/white arms BennettOZ84 Aircraft - Electric - Multirotor (FS/W) 3 Jun 13, 2012 05:02 PM
Question DJI F550 frame and Quadframe's 155mm landing legs moombe Multirotor Talk 9 Mar 27, 2012 01:49 PM
For Sale Snap Quad frame with extra arm/leg and center plates - $20 shipped CONUS Mactadpole Aircraft - Electric - Multirotor (FS/W) 0 Mar 17, 2012 11:46 PM
Discussion Does the DJI f450 Frame Have Vibration Issues? ukarmy04 Multirotor Talk 0 Dec 31, 2011 01:53 PM
