Old Sep 26, 2012, 08:34 AM
abuzer01 is offline
Find More Posts by abuzer01
Joined Jul 2012
Help!
prop and motor for pusher fpv
prop and motor for pusher fpvp combo and even I have posted about it but took no results
Im pleased if you can help and suggest a in or outrunner motor and prop.
I have 2m wingspan pusher plane(for fpv)
weighting 1000g (35.7 oz) without motor and battery,
max. Prop diameter is 7".
Also we want the plane to fly like trainer models, acrobatics are unnecessary, flight time is about 10m or less and speed is as low as possible (25mph or higher if necessary), i read guides and whole site but didn't find an answer
abuzer01 is offline Find More Posts by abuzer01
Old Sep 27, 2012, 12:00 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Try 4 cell with very low kv motor and largest prop
The low kv motor will let you put monstrous prop on
Slow fly apc work well
7x5 Apc slow fly is good
Expect lots more flight time
QUOTE=abuzer01;22838132]prop and motor for pusher fpvp combo and even I have posted about it but took no results
Also we want the plane to fly like trainer models, acrobatics are unnecessary, flight time is about 10m or less and speed is as low as possible (25mph or higher if necessary), i read guides and whole site but didn't find an answer[/QUOTE]
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Sep 27, 2012, 03:10 AM
abuzer01 is offline
Joined Jul 2012
Firstly I posted on my phone and it didn't send "hello ... part", sorry for that,
I think by saying low kv motor you mean outrunner, so can it supply enough thrust? because as you see our prop is relatively small (7") ? and if so, can you suggest a motor?
Also, because I want slower speed, isn't it little high for a pitch(5")? or is there a reason for not 3"?
thanks again
Old Sep 27, 2012, 08:15 AM
WitnessOnly is offline
Find More Posts by WitnessOnly
Cleared for take off...
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
http://www.rcgroups.com/forums/showthread.php?t=739069
do the learning, it's worth it
WitnessOnly is offline Find More Posts by WitnessOnly
Old Sep 27, 2012, 11:33 AM
abuzer01 is offline
Joined Jul 2012
Learning is a life-long process, but I did read all related topics including that; but still can't sure what motor-prop would be satisfy the requirements.
And simply ask to anyone who can lead me; however it seems now it is more difficult than I think because no one replied except one that is not clear yet.
Old Sep 29, 2012, 05:37 AM
sweflyer is online now
Find More Posts by sweflyer
Joined Nov 2007
Imho a plane weighing 1300 grams and intended for relatively slow flight
the 7" prop is to small to be efficient. 8" or 9" prop diam. and relative low kv motor would be better for thrust and cruise at low amperes.
sweflyer is online now Find More Posts by sweflyer
Old Sep 29, 2012, 07:07 AM
dk31 is offline
Find More Posts by dk31
dk31's Avatar
Athens
Joined Oct 2009
Assuming an all-up-weight of 1.5 kilos, I would start with an 3536-1250kV powered by 4s lipo. Turnigy at hobbyking is at around 20$.
dk31 is offline Find More Posts by dk31
Question What is the best pusher design for FPV GOPRO camera? brendon7800 Aerial Photography 6 May 28, 2012 10:28 AM
Discussion pusher props are loud and wiggly stick with this radian mutant for fpv wingymaster FPV Talk 0 May 19, 2012 01:44 AM
Discussion What is the best pusher design for FPV GOPRO camera? brendon7800 Foamies (Scratchbuilt) 6 May 11, 2012 12:05 AM
Question Can you use a pusher prop to power a tractor motor AzTrekie Power Systems 3 Apr 20, 2012 01:07 PM
Question Which way do I mount pusher prop on mjv3 for hawk sky? slowjett Power Systems 4 Mar 02, 2012 10:03 AM
