Old Sep 26, 2012, 06:44 AM
rappy30rc is offline
Find More Posts by rappy30rc
Joined Jan 2010
Hobbyking KK2.0 Multi-rotor LCD Flight Control Board will not arm.
Yesterday I fitted a Hobbyking KK2.0 Multi-rotor LCD Flight Control Board (V1.2) to my newly constructed Quad.
I have been through the complete setting-up procedure but cannot get the FC to Arm.
The Hobbyking 30A Blue Series ESCs were first programmed with the appropriate programming card before connecting to the FC.
Receiver checks are all OK- direction and travel. FC correctly set-up for Quad X and motor rotation.
ESC calibration was then performed as per instructions. Tx ON, Throttle to Max, hold down buttons 1 & 4 apply power. 4 sets of double beeps followed by a musical tone (to the best of my recollection). The throttle was then put to minimum resulting in a single tone. Power to the FC was then disconnected and transmitter switched off.
Now, when I apply power to the FC the LCD shows Self Level Off, OK, and battery 0.0 (no battery connected). However when I switch on the transmitter and apply minimum throttle and right rudder (as instructions), the board will not arm and remains at Safe and OK. Arm and Self Level set to 'Sticks'.
All menus seem to be OK but, and I do not know if this is an anomaly, when I apply minimum throttle and LEFT rudder I hear constant beeps.
Anyone any ideas please?
rappy30rc is offline Find More Posts by rappy30rc
Old Sep 26, 2012, 07:27 AM
Steveis is online now
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Beeping on LEFT rudder is expected.
Have you checked your subtrims and that you are only set to 100% ATR on your transmitter yaw?
Steveis is online now Find More Posts by Steveis
Old Sep 26, 2012, 08:51 AM
Ducati777 is offline
Find More Posts by Ducati777
Joined Sep 2012
Sounds like what my 2 boards did....
It'll boot up, but go into rx test, does it say no signal? If so, it's the same as mine. I found that the board will turn on with just about any ol' ESC, but for some reason, it would only turn on and read a receiver input on some of my ESC's. I had to keep trying different ESC's to find one that worked, even though they're ALL HK 20 amp models, the exact same.
Then just run power to M1, leave the red wire off the rest of the esc's.
The one that gets my board to boot has different arming beeps. Not sure whats up with that. Also adding a cap to the power side of the board had no effect
ORRRRRR.....
This one tricked me the other day too... Went to arm, get nothing. Go to receiver test, and it's reading ok, just the numbers seem low.
Oh right, I had dual rates on low.... flip of a switch on the radio and I'm in the air.
Ducati777 is offline Find More Posts by Ducati777
Old Sep 26, 2012, 07:10 PM
lquick is offline
Find More Posts by lquick
Joined Feb 2003
I had the same problem.
Try connecting the battery and in less then 1 second, move the throttle stick to the right.
It works for me.
If you disarm it, then it can not be rearmed again until you disconnect the battery.
Hope this works for you.
Lloyd
lquick is offline Find More Posts by lquick
Old Sep 27, 2012, 07:42 AM
lougedo is offline
Find More Posts by lougedo
lougedo's Avatar
Spain, GA, Corunna
Joined Jan 2011
hello
I had the same problem too, it does not want to ARM.
it worked if i quick conect the battery a move the rudder to the the left (itīs reverse the way to arm it, how can ia change it?), but it canīt not disarm...
lougedo is offline Find More Posts by lougedo
Old Sep 27, 2012, 07:49 AM
lougedo is offline
lougedo's Avatar
Spain, GA, Corunna
Joined Jan 2011
Playing with servo jittering and it worked sometimes, but a few times only. I donīt know what happens, if is the servo or what, but if i choose arm On it work just fine
sowftware problems of this new update 1.2 iīm thinking
Old Sep 27, 2012, 08:37 AM
AVR Dude
Joined Jul 2011
When you check Receiver Test in the KK2 menu, is throttle between 0 and 100 and yaw between -100 and +100. It won't arm/disarm if throttle is not 0 and yaw throw is too low or too high (for yaw, too low may be when you have low rates and too high may be when you have ATR way above 100%)
Old Sep 27, 2012, 08:54 AM
lougedo is offline
lougedo's Avatar
Spain, GA, Corunna
Joined Jan 2011
yes, my throttle is on 0 idle, and the same for all the channels, 0
Old Sep 27, 2012, 09:17 AM
AVR Dude
Joined Jul 2011
What is your max and min yaw values?
Old Sep 27, 2012, 04:08 PM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Perform a Sensor Calibration and then try.
Check the sensor test & see if any of them report "NOT OK"
If a sensor is not okay, the board will not arm.
AcroFPV is online now Find More Posts by AcroFPV
Old Sep 27, 2012, 04:16 PM
lougedo is offline
lougedo's Avatar
Spain, GA, Corunna
Joined Jan 2011
When arrive at home will check the limits of the yaw.
Yes, i did various sensors check, and always they were fine, all ok
Thanks for the reply's
Old Sep 27, 2012, 10:50 PM
NtiT is offline
Find More Posts by NtiT
Joined Sep 2012
To determine if it's a hardware issue, I'd try setting the KK2 to arm automatically, and check if it works then. Make sure the sensors are CALIBRATED, if they aren't it won't arm. Now, go to reciever test, and make sure you get values of +/- 100 (and correct reversal) for yaw.
NtiT is offline Find More Posts by NtiT
Old Sep 27, 2012, 11:18 PM
orlandvic is offline
Find More Posts by orlandvic
Joined Apr 2012
reset your rudder trim. from one side to the other, until it arms. Do the same to make sure it will disarm.
orlandvic is offline Find More Posts by orlandvic
Old Sep 28, 2012, 01:44 AM
AVR Dude
Joined Jul 2011
I have performed a test to check the operation with extended travel on my yaw.
On my DX8, I set the yaw servo travel to 150% (maximum). In KK2 receiver test, I checked the values it recorded for rudder. Right went up to -143 at full right yaw. However Left went up to 146 and then went to 0 at full left yaw. This resulted in being able to arm the kk2 but unable to disarm it.
Equally, if receiver test left and right yaw max readings do not go above +/-50 on full yaw stick deflection, you remain in the "safe area" so won't be able to arm / disarm.
And, of course, to be able to arm / disarm, throttle should be 0 idle in receiver test.
Old Sep 28, 2012, 06:23 AM
lougedo is offline
lougedo's Avatar
Spain, GA, Corunna
Joined Jan 2011
I works now!!
I did a new model, resetting all data on my DX7 and the same on the kk2, check the EPA on the KK2 to get full -100 to 100 in all channels... but it didnīt want to arm either.
So i replace the Rx with a Orange spektrum compatible 6ch and it WORKS perfect everytime now.
Thank you all
Discussion Where to mount Hobbyking KK2.0 Multi-rotor LCD FCB josephr Multirotor Electronics 8 Apr 26, 2014 09:36 AM
Discussion Hobbyking KK2.0 Multi-rotor LCD Flight Control Board MoRaLeSD Multirotor Talk 5 Apr 09, 2014 11:05 AM
Discussion Schematic of "Hobbyking KK2.0 Multi-rotor LCD Flight Control Board" MHefny Multirotor Electronics 60 Jun 29, 2013 12:45 AM
Question V-Tail Quad copter with HK KK2.0 Multi-Rotor Control Board horst1903 Multirotor Electronics 3 Dec 16, 2012 11:14 AM
Sold Hobbyking KK2.0 Multi-rotor LCD Flight Control Board Cobra68 Aircraft - Electric - Multirotor (FS/W) 4 Sep 14, 2012 12:40 PM
