This thread is privately moderated by hobby2011, who may elect to delete unwanted replies.
Old Sep 26, 2012, 02:22 AM
hobby2011 is offline
Find More Posts by hobby2011
中国, 广东省, 深圳
Joined Sep 2011
X-power Micro Integration 4-axis LED Quadcopter X-copter RTF MWC Control Board
2012 New X-power Micro Integration 4-axis Quadcopter X-copter RTF
100% Brand new
Flight video: http://v.youku.com/v_show/id_XNDM1ODExNTUy.html
Technical video: http://v.youku.com/v_show/id_XNDQ1MzQ3MDky.html
Feature:
1, compact, stable flight, suitable for indoor and small space flight
2, accessories easy to install, it use 5030 propeller, battery can select 500MAH--1500MAH, 2S--3S Lipo battery, (after testing with 7.4V 1000mah , it can fly over 7 minutes),if use 2 blade propeller,it can obtain longer flight time.
3, the total weight is 250 grams, can pull up to 680 grams, you can equip more equipment to meet your demand for DIY.
4, the copter designed the LED light,Frame and ESC integration, cabling is simple & elegant. (Cross and X mode light can adjustable)
5, the flight controller is MWC MultiWii Lite control board,it can be switched between manually model and self-stabilized mode in flight , please view the insruction by clicking on http://www.multiwii.com/
6, this unit can use with other control board.
Size(L*W*H): 265*265*63mm
Motor: 1804-2400kv brushless motor
Attention:
This aircraft is suitable for the players who know about multi-axis aircraft for DIY
Following Parts are required to complete the kits (not included): - 4 Channel above Radio system (transmitter and receiver) - 2S-3S Lipo battery 500mah-1500mah
This aircraft integrated with 4 ESC, at the time of first use, please calibration them with the throttle.
1. set up S1.S2.S3.S4 signal cable,then calibration.
2. you can also calibration them one by one.
Our website link: http://www.rcmodelpart.com/xpower-mi....html?cPath=23rcmodelpart3@hotmail.com
hobby2011 is offline Find More Posts by hobby2011
Sold Lady Bug 4CH 2.4Ghz 4-Axis RTF Micro QuadCopter KiTCyclic Aircraft - Electric - Multirotor (FS/W) 2 Aug 22, 2012 08:28 PM
Help! cna some one help me with my first mwc 2012 red board in x config. copter? crash8384 Multirotor Talk 4 May 26, 2012 09:42 PM
Discussion control Quadcopter LED lighting through control board sirbow2 Multirotor Talk 4 Dec 12, 2011 07:31 AM
Discussion MWC MultiWii Lite lightweight version 4-axis flight control board Erknie Multirotor Talk 0 Dec 05, 2011 06:58 PM
