This thread is privately moderated by Sandancer, who may elect to delete unwanted replies.
Old Nov 13, 2012, 10:01 AM
SA_Flyer is offline
Find More Posts by SA_Flyer
Joined Sep 2006
Are these now avalible to buy ?
SA_Flyer is offline Find More Posts by SA_Flyer
Old Nov 13, 2012, 11:08 AM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Not yet.
Sandancer is offline Find More Posts by Sandancer
Old Nov 20, 2012, 10:11 PM
reno4sure is offline
Find More Posts by reno4sure
No worries, I've got your six
reno4sure's Avatar
Joined May 2011
If the hole pattern on the mounting bracket is what prevents compatability why not make the mounting bracket long enough to fit different bolt patterns and then simply elongate one set of holes so that you can bolt the etracts as necessary.
reno4sure is offline Find More Posts by reno4sure
Old Nov 20, 2012, 10:37 PM
FWCXC is offline
Find More Posts by FWCXC
FWCXC's Avatar
London Ont.
Joined Sep 2006
Subscribed
FWCXC is offline Find More Posts by FWCXC
Old Nov 21, 2012, 12:16 AM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
That was the proposal I sent them when I photo shopped that image to them. It doesn't look like they took that suggestion to heart?
Gary
Old Nov 21, 2012, 06:53 PM
Tom Hunt is offline
Find More Posts by Tom Hunt
got any foam to bash?
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
wow gary...
was that 4-5amps per or both?
either way we had better be running a 10amp Castle BEC on these JIC!
Tom
Tom Hunt is offline Find More Posts by Tom Hunt
Old Nov 21, 2012, 07:26 PM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Originally Posted by Tom Hunt View Post
wow gary...
Tom
I was running these tests w/both units. I ran 6 cut-off tests including those on the vid and they all peaked at 4 amps.
Gary
Old Nov 21, 2012, 07:55 PM
Dangaras is offline
Find More Posts by Dangaras
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Wow! That's high. They may need to turn down the stall curent....
Dangaras is offline Find More Posts by Dangaras
Old Nov 22, 2012, 09:06 AM
Tom Hunt is offline
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
can't turn it down, it is what it is based on the torque of the motor and the applied voltage.
what they could do is set the shut-off sooner (in time) and not let it last so long.
Old Nov 22, 2012, 10:05 AM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Actually, the current will ramp up to an operating level and if the retract is blocked the current will rise again until it reaches the 'blocked rotor' value. They can adjust the trip circuit anywhere along the ramp up from operational to blocked steady state value assuming they are not monitoring some other function.....
Old Nov 22, 2012, 11:51 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
I would expect they partly do it willy-nilly.... the decision on trip values.... plus the circuit is low tolerance, so one persons does X and other persons does Y.
Plus they want it to at least 'try' to push through an issue, in case it is really just a short-lived section of travel. So allowing it to stall for one second (or something like that) is probably no problem, and worth doing.
If you really wanted to you could power the retracts directly from another power source, and just have the signal from the RX. Thus isolating RC power issues from issues with the retracts.
You can still take that source from the same battery that powers the BEC. eg possibly tap into a battery's balance plug.
And just use a diode, or few, to drop the voltage to approx operating levels.
eg Tapping into two cells off the main battery, 7.2V, throw in two diodes to drop 1.4v = 5.8v for the retract. Isolated power.
I tap off power for various things in a few planes (lights, sound system etc). Just use a 0.1in spaced header block and run whatever cell count you want from that. Heat-shrinked pins and solder joints of course. eg pin 1&2 for 1S... 1&3 for 2S etc.
PeterVRC is offline Find More Posts by PeterVRC
Old Dec 07, 2012, 07:59 AM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
which FMS metal retracts are suitable for FMS 1.4m P51 and P47? looking forward with dimension and release date? price?
viperviper is offline Find More Posts by viperviper
Old Dec 07, 2012, 08:43 AM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
viper,
Supposedly they both are
http://www.rcgroups.com/forums/showp...7&postcount=42
v8truckin is online now Find More Posts by v8truckin
Old Dec 07, 2012, 10:04 AM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
If you go back to pg. 1, I have all the pics and specs. starting there.
FMS informed me earlier this week (Monday/12/3/2012) that the Alums & their Plastic counterpart E-Tracts were ready for release within the week! The prices will also be revealed at that time. As of today (Friday) I still haven't heard anymore?
Gary
Old Dec 10, 2012, 09:32 AM
Webmaister is offline
Find More Posts by Webmaister
I like Fast Warbirds
Webmaister's Avatar
United States, GA, Atlanta
Joined Nov 2011
Can't wait until these are released
Gary
Just had both my gear fail on my F4U and the v2 P51. I bought a pair of V7 P51 gear to try out. Don't know what I'll do on the F4U. It's my 3rd pair of gear in 16 months. Should I wait for the FMS Aluminum or just buy another pair? All of my failures were due to worm gear failures.
Webmaister is offline Find More Posts by Webmaister
Sold ... T-CAT Aircraft - Electric - Jets (FS/W) 2 May 27, 2012 09:30 PM
Mini-HowTo Bringing weak E-tracts up to snuff for 25 cents Knife Liddle Electric Ducted Fan Jet Talk 18 Mar 10, 2012 12:12 PM
Sold Habu "strut" e-tracts rcgalore Aircraft - Electric - Jets (FS/W) 4 Sep 11, 2011 07:28 AM
Sold e-flite 10 to 15 e-tracts (mains) $45 shipped kevinb120 Aircraft - General - Miscellaneous (FS/W) 2 Mar 02, 2011 11:15 AM
For Sale New Uni-tract 1/5 scale FW-190 landing gear invertmast Aircraft - General - Miscellaneous (FS/W) 0 Sep 23, 2010 07:15 PM
