Old Sep 25, 2012, 11:11 PM
DanielSN is offline
Find More Posts by DanielSN
Joined Sep 2012
Spitfire Airfoil question
Hi, I would like some opinions on using the original NACA 2213 and 2209 in a 1/6th scale MK XIV including the washout +2 (root), -0.5 deg (tip). (wingspan 1,87 m, root chord 42 cm, and about 6,5 kg). I have seen one or two commercial models using these airfoils or similar in 1/4 scale, but I´m not sure what is used in 1/6 scale versions.
Any advice/experience on this is welcome!
DanielSN is offline Find More Posts by DanielSN
Old Sep 26, 2012, 03:00 AM
HELModels is online now
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
Those foils are semi symmetrical, nothing fancy that I can see.
HELModels is online now Find More Posts by HELModels
Old Sep 26, 2012, 07:44 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Use it - It is a workable configuration.
In that size tho -the weight of the finished model is of far more importance than minute washout .
building an exact replica of that shape in wood is a labor of love
I once figured out how to do it as a foam core -also a lot of work setting up the twist and bow in the foam block.
richard hanson is online now Find More Posts by richard hanson
Old Sep 26, 2012, 09:03 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I'm too lazy to do 'scale', but I do love my Spit -
Spitfire 5 (5 min 11 sec)
eflightray is offline Find More Posts by eflightray
Old Sep 26, 2012, 09:09 AM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
The old NACA 4 series airfoils are based on the Clark Y/Goe 398 thickness form, which works pretty well at model scales in most of the NACA variations. The 2213 and 2209 should be good at the size you are contemplating.
Those pointy tips on the Spit mean the Re is very low out there, particularly at model sizes. That was a problem with the real thing at high altitude, hence the later versions "clipped" the low Reynolds Number tips for better performance, and fewer tip stall problems. The clipped wing versions would be a bit better at model sizes too.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Sep 26, 2012, 10:02 AM
Joined Oct 2007
http://www.youtube.com/watch?v=qS5wJ0Wa_w4
That is a great model- I have a small one I am setting up
at 6 ft it is obviously a good size for fun flying performance
My scale Dalotel /Bucker are also larger models (80" spans) - makes flying more fun
I am using 10 cell Hacker setups -with 20x14 " props
What power setup did you select?
Old Sep 26, 2012, 12:17 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I think I "gotcha" on this one Kevin. The clipped wing Spits were done for added roll rate and a little more speed at low altitudes. They later came up with extended tips for the photo recon Spits that were flown at high altitudes to add a little wing area. The books on the Spitfire history are pretty consistent on the reasons for those mods.
But that aside with our models and the low Reynolds numbers at the tips an extra degree of washout would not be a bad idea at all. And as a free flighter I'm also in agreement with the "Light is Right, and Lighter is Righter" school of thought as well.
BMatthews is online now Find More Posts by BMatthews
Old Sep 26, 2012, 12:45 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
[QUOTE=richard hanson;22839206]That is a great model- I have a small one I am setting up
What power setup did you select?[/QUOTE]
Motor - BL4030 385kv
Prop - APCe 16" x 10"
Lipo - 6s 4400mAh
But then the flying weight is 7Lb - 2oz, (3.23Kg).
My build thread - http://www.rcgroups.com/forums/showthread.php?t=1592598
Old Sep 26, 2012, 12:52 PM
Joined Oct 2007
[QUOTE=eflightray;22840612]
Lipo - 6s 4400mAh
Looks like a good combo-plenty of punch off the line - The response of a well setup electric really beats th e IC setups with the small screaming propellers
My Dalotel literally explodes into the air. Prior power was with a ST2300 on tuned exhaust and 18x8 props- this is far better .
Old Sep 26, 2012, 01:00 PM
kcaldwel is offline
kcaldwel's Avatar
Joined Jan 2007
You're right Bruce. They were clipped just for roll rate to keep up with the 109. The high altitude ones had even pointier tips, but more wing area. The low-altitude version doesn't seem to always have clipped wings:
http://spitfiresite.com/2010/04/conc...g-types.html/2
Only the British would build an elliptical wing in war time, when it was an elliptical span loading you want not an elliptical planform. And it turns out elliptical is not the best span loading shape for minimum induced drag either, if you don't assume a planar wake like they did back in the '30s to keep the math doable.
Kevin
Old Sep 26, 2012, 01:52 PM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
IIRC the "clipped and cropped" Spits were done following evaluation of MkV's vs Fw190's, which were found to be both faster and superior in roll rate. The clipping was a sort of "stop gap" to try to narrow the margin until the MkIV was introduced. Roll rate was much improved apparently, but thats about all.
The "modification" for low altitude was really down to the smaller but higher boost supercharger fitted which was aimed at increased performance at low level and initial climb rate.
Just for what its worth, the "high altitude" MkVII had some rather horrible looking extended wingtips;
MCarlton is offline Find More Posts by MCarlton
Old Sep 26, 2012, 02:20 PM
Brandano is online now
Find More Posts by Brandano
I believe that the additional roll rate was meant to exceed rather than just match that of the BF109 and FW190. The Merlin engined Spitfires were limited to positive G loads, and it was relatively common for a German fighter being chased in a turn to just pitch the nose down (outside the turn) and hit the rudder inside the turn to go in a fast vertical dive. The Spitfire could not chase in this maneuver, the float carburetors would run dry, so the pilot had to roll inverted and pull towards the diving fighter, losing distance and aim in the process.
Brandano is online now Find More Posts by Brandano
Question Airfoil question....... rcbif Electric Plane Talk 4 Sep 24, 2012 06:05 PM
Question Noob airfoil question Flyextreme Hand Launch 12 Jun 23, 2012 05:57 PM
Discussion pw-51 airfoil question paraman007 Slope 14 May 07, 2012 08:21 PM
Question Wing/Airfoil chord line angle in "level" flight Question Pauliwog Thermal 3 Apr 05, 2012 09:00 PM
Spitfire airfoil question Yeti GWS (Grand Wing Servo) 3 May 26, 2004 01:28 AM
