Old Sep 25, 2012, 10:12 PM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Motor Timing
just had to come here and ask a question that I never got a good answer for. Is there a formula to figure out the best brushless motor timing. Like the number of poles the motor has Xs the number of wraps? Or do you just play with it till you find what ever feels like its the best. Or do you check the heat and go for the lowest motor temp? I always put mine on the default setting
barnstorm100 is offline Find More Posts by barnstorm100
Old Sep 26, 2012, 02:03 AM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Timing is one of those things that causes more confusion than it's worth. If the motor runs smoothly, don't worry about it.
All it does is affect the ESC's commutation cycle advance relative to the rotor position. A higher timing advance means that the permanent-magnet rotor is trailing farther behind the electromagnetic fields that are governed by the ESC, which tends to increase RPMs at the expense of additional current/heat. If the timing setting is too high, the ESC can get ahead of the motor's physical position which results in skipping or jerking.
Piece is online now Find More Posts by Piece
Old Sep 26, 2012, 05:38 AM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
Here is an article on timing:
http://www.theampeer.org/timing/timing.htm
Ken Myers is offline Find More Posts by Ken Myers
Old Sep 26, 2012, 09:49 AM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
The monkey wrench in the whole thing is the timing is set by firmware in the ESC. Each manufacturer may do it slightly differently so there is no way to develop a 'formula' that matches all the variations.
You will find motors that will not run on some ESC and run fine on others. Timing can be an issue on some higher RPM motors. We get a lot of "why does my motor screech?" questions.
flydiver is offline Find More Posts by flydiver
Old Sep 26, 2012, 09:30 PM
Joined Jan 2011
Thanks for the info
Old Sep 30, 2012, 04:01 PM
dmyers0403 is offline
Find More Posts by dmyers0403
United States, OK, Roland
Joined Jan 2011
What cause out runner motor to screech severely if throttle is advanced to fast. How can it be corrected. I have older Atlas 5020/30 and I have tried all to esc timing positions to no avail. Motor does just fine if advanced at a moderate rate.
dmyers0403 is offline Find More Posts by dmyers0403
Old Sep 30, 2012, 04:27 PM
flydiver is offline
flydiver's Avatar
Joined Jan 2007
Screeching is the motor getting out of synch with the ESC. Generally advancing the timing will help, IF you are NOT over propped. Prop down > try again.
If that doesn't work, stay propped down and try a different brand of ESC. Occasionally there is just an ESC + motor mismatch.
What is the claimed KV of the motor, weight, and what prop(s) have you tried?
Old Sep 30, 2012, 09:49 PM
Joined Jan 2011
Specs: 215Kv, 10S lipo, 10-35Amp max eff., 50A max, 19x12 or 20x13 prop
I used Sentinial (HK) 100A-12SEsc running 10SLipoly on 16x8x3 props set on high timing
set up is on a 132inch Wingspan Lancaster (4 of em)
Flys well just can't jamb throttle, not that we need to butbjust curious why
Last edited by dmyers0403; Sep 30, 2012 at 09:51 PM. Reason: Tried bigger props but it was worse and amps are in proper range with the 16x8x3 and they fit the plane scale wise
Old Sep 30, 2012, 11:26 PM
flydiver is offline
flydiver's Avatar
Joined Jan 2007
You are out of my realm with those kind of motor, batteries, and props. Principal is still the same I would think. Prop down. Try again.
Then try a different ESC.
What ever specs are claimed for them .....don't believe them, especially HK stuff. Reduce by at least 20% and work from there.
Discussion Any one else having a hard time getting KDA motors? Always out of stock spacecase Multirotor Electronics 4 Aug 27, 2012 10:32 AM
Sold Align RCM-BL600M 1200KV Motor used 3 times! volcomsnows2k Aircraft - Electric - Helis (FS/W) 3 Jun 25, 2012 02:16 PM
Question Hacker motor timing chart Ken Manuel Power Systems 1 Jun 25, 2012 09:54 AM
Help! Motor / Prop recommendation for e-Bird of Time Conversion doo Electric Sailplanes 9 Jun 23, 2012 09:49 AM
Discussion Flight time of 3 motors 1 batt vs. 4 motors 2 batteries bladeaudio Multirotor Talk 3 Mar 16, 2012 09:43 PM
