Old Sep 25, 2012, 09:57 PM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
converting an Oly II to Full House ALES
Hi,
I fly with a growing bunch of electric glider fliers. Our field configuration and ages are leading us towards ALES. We are mostly flying Radian type equipment but are starting to see an advancement into 100" + birds. An electric BubbleDancer showed up just this Sunday.
Since most of our group are flying 2M foam birds. I am building a 100" kit that can use the same gear. I selected a OLY II varient that has shoulder mounted wings and can be configured in a variety of options. Those options would be spoilers, flaps, ailerons and be electric powered. Kits can be found at SKYBENCH.COM or MountainModels.com among others.
My goal is to demonstrate a glider that performs well above the foamy class yet is NOT A BUDGET BUSTER. I have built (and rebuilt ) enough birds over the years that this is an easy task. However I want it to be a reasonable project for beginers too.
So I need some sugestions on how to do the flaps and aileron options in a woody wing.( I have done spoilers several times previously.)
Thanks In advance for your help
OzMo
ozmo01 is offline Find More Posts by ozmo01
Last edited by ozmo01; Sep 26, 2012 at 06:50 PM. Reason: the direction of the post changed...again ;-)
Old Sep 26, 2012, 01:42 AM
ozmo01 is offline
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
hmmmm still thinkin'
Hi,
Did some further research. Start by moving the built up TE strips forward and create a new location for the TE. Then add new balsa plank strips to form the ailerons and flaps. I could use my good balsa and make em solid.
How deep to make them is what I have not figured out yet
here is a pic of an Oly II wing plan
I think do to the length of the inboard pannels the flaps will not have to be very big chord wise. The aileron may need to be though. I'll use less dihedral and polyhedral as well.
opinions welcome!
Old Sep 26, 2012, 06:18 AM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
I would make them 20 - 25% of the local chord for both the flaps and ailerons. I believe even though that may appear more than needed it will help with camber/reflex airfoil changes.
Neat project!
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old Sep 26, 2012, 09:47 AM
jcstalls is offline
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
20%.
Another thing to consider is either full span or stopping one bay at the root, poly joint and tip. This will reduce the working are just a little but would aid in trim adjustments and checking if the control surfaces is warped.
Looks like fun.
Jared
jcstalls is offline Find More Posts by jcstalls
Old Sep 26, 2012, 04:29 PM
ozmo01 is offline
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Dihedral??
Thanks Jared and Curtis,
Going abit oversized will ensure adequate control as well. Can't wait to play with Crow!
Any sugestions on how much "duhedral" to use??
Old Sep 26, 2012, 06:36 PM
Red Merle ALES
Joined Apr 2002
I like about an EDA of 6 degrees.
Have you seen Sailplane Calc? It is an excel file that will easily calculate that and much more. There is an article that examines it too.
See www.TailwindGliders.com
Curtis
Old Sep 26, 2012, 06:37 PM
ozmo01 is offline
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
project goals
Here is what I hope to achieve:
Equal or lighter wing loading than a typical 2M foam glider. (we'll see)
Enough umph to get to competitive altitude
Improved flight performance ( no "rubber butt" effects)
Low cost to encourage participation (reuse 2M foamy's gear + wing servos)
Possibly use a less MAh battery to reduce weight / optional
Old Sep 26, 2012, 07:19 PM
ozmo01 is offline
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Curtis
Thanks for the link! Good stuff
Old Oct 16, 2012, 01:20 PM
jcstalls is offline
jcstalls's Avatar
Joined May 2002
Movement?
Old Oct 16, 2012, 01:31 PM
ozmo01 is offline
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
project stalled
Hi,
The kit maker has confirmed the order but is holding shippment waiting for wing rods. AHHH the joys of being dependant on supliers!
Old Oct 16, 2012, 02:29 PM
jcstalls is offline
jcstalls's Avatar
Joined May 2002
Excellent. She is moving. My SkyBench Oly II kit is slated for this winter.
Old Oct 24, 2012, 10:25 PM
ozmo01 is offline
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
kit on the way
Got an email that it was shipped yesterday
Bench is cleared off, glue is fresh , scalpels at the ready
Old Oct 24, 2012, 11:12 PM
jswain is online now
Find More Posts by jswain
Gasbags & Gussets
jswain's Avatar
Riverside, Ca
Joined Feb 2009
i am interested in this project....
I have a towhook version OlyII and thought it would be a great subject to build ALES style. That said i am looking forward to following what ever version you build and i hope the weather isn't too severe in the midwest to cause the maiden flight to be delayed until spring time.
A local flyer wanted something better than his radian and i suggested this model but he is hesitant to build. Maybe this will be the build-thread that he can look at later on and feel like it is 'do-able'. This model kit doesn't get any better for ease of building, lightness, ease of flying and bang for your $$'s !!
best wishes, john s.
jswain is online now Find More Posts by jswain
Old Oct 26, 2012, 09:10 PM
ozmo01 is offline
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Kit arrived today!!!
Hey GUYS,
The big brown truck came today. I had time to look over the kit and WOW it looks really nice. Fine lazer cutting and quite complete.
jswain
This plane is easy to build, should be no more complicated than a Gentle Lady, just a bit bigger. If your freind has just a few tools and a FLAT table its fine for a first build. Might be nice to have help covering the first time even though it is as easy to cover as anything out there. Should be a fine first or twentyfirst glider.
I actually got the Mountain Models Scepter which is an updated OLY II.
Whenever you build a "classic" model you have to remember they are a classic for good reasons...generally because they fly well.
Now off to the RC cave to build! I'll post pics in a couple of days.
Work is a four letter word ya know.
Ozmo
Old Oct 30, 2012, 09:40 PM
ozmo01 is offline
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Kit Pic and method to add flaps
Hi,
Sending a pic of the Mountain Model's Scepter kit and pics of a flap mod to a GL. I plan to do the Scepter's ailerons and flaps the same way.
Idea Aileron/Flap facing on bagged wings target Composites Fabrication 25 Mar 21, 2013 11:52 AM
Question Aileron & flap quick connects for wing connect zeezee Power Systems 12 Jun 03, 2012 04:29 PM
Question Are flaps and ailerons included in wing loading calcs? snipeworm Electric Plane Talk 4 May 22, 2012 06:51 PM
Wanted Wanted Topaz Center section with flaps and right wing with ailerons icharus Aircraft - Sailplanes (FS/W) 10 Apr 27, 2012 04:25 PM
Discussion Is there a way to set up the DX6 for full flaps using the ailerons? grampi Radios 2 May 22, 2007 11:32 PM
