Old Sep 25, 2012, 09:47 PM
Joined Sep 2012
EDF glue question
I just put together my Rafale kit, and i was told to use a certain CA from the LHS. After I glued the main wings on, and put a bead along the seam, i noticed after a couple of hours that the CA had eaten away at the seam of the joint. Is this normal??? it seems to me that the LHS sold me the wrong glue!!
I'm thinking of just running a bead of clear silicone on the seam of the joint to make a better seal. Is this going to be ok?
Also, when i received my kit, one of the canard wings was a little crushed, although just cosmetic in my opinion, will this affect flight?
FU777 is offline Find More Posts by FU777
Old Sep 25, 2012, 10:37 PM
Atlanta, GA
Joined Mar 2009
CA will dissolve EPS foam so you need to use a Foam Safe CA. Be careful when you try to repair your plane the dissolved foam is likely to have created some weakness in the structure.
Double E is offline Find More Posts by Double E
Old Sep 25, 2012, 10:42 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
use fast dry gorilla glue, it will expand and fill all the holes you made
jcdfrd is online now Find More Posts by jcdfrd
Old Sep 26, 2012, 12:29 AM
Joined Sep 2012
is the gorilla glue better than using silicone?
Old Sep 26, 2012, 12:50 AM
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
silicone is flexible u dont want to use that use epoxy its very strong and sets in 5/15/30/slow cure times in minutes depending on which one u buy depending on the size of hole u need to fill u can try polyurethane glue it foams up and will fill the gaps/holes
gazza2003au is offline Find More Posts by gazza2003au
Old Sep 26, 2012, 01:08 AM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
gorilla glue is the best glue for foam...yes better than silicone and better than epoxy for foam
Discussion Easy Star II glue question mutski Beginner Training Area (Aircraft-Electric) 6 Aug 21, 2012 08:28 PM
Discussion A glue question for UK based EPP builders. Thechittyfather Foamies (Scratchbuilt) 2 Jun 13, 2012 01:56 PM
Question Glue glue glue... sticky, but which one? Hatoka Foamies (Scratchbuilt) 16 Jun 06, 2012 12:16 PM
Discussion Glue Questions neo__04 The Builders Workshop 2 Mar 14, 2012 12:11 AM
Question glue question HF_ATL The Builders Workshop 14 Mar 13, 2012 05:27 AM
