Old Oct 24, 2012, 12:02 AM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Originally Posted by CoolerByTheLake View Post
Lt599 A word to the wise on the Ready Patch. I used the stuff labled MH Ready Patch by Zinnser, on the foam plug for my F-86F. I seemed to work well untill I glassed the fuse. On J Morgans advice I used regular sheet rock compound for fill b-4 glassing. But I did have some Ready Patch that showed through. It seems it does not like epoxy!!! Every where I had used RP the foam got very soft or some what melted. Ended up cutting out all the RP and filling with Bondo.
Granted that was for a plug, but be carefull if you glass over it!!!.
CoolerByTheLake, Wow! I am glad I mentioned it. I am currently in the planning stages of a twin 90mm M21 (SR 71) that I plan to use a foam plug for molding FG skins. Thank you for the heads up. I have used it allot but have never glassed over it. Thanks agian Greg (Lt599)
Humbertomelo, I really like the paint on your Mirage!! It is turning out great Greg
Lt599 is offline Find More Posts by Lt599
Old Oct 27, 2012, 10:29 PM
humbertomelo is offline
Find More Posts by humbertomelo
Brasil, GO, Goiânia
Joined Feb 2009
I did the maiden flight of mirage 2000 today, man i am so nervous! I feel my heart beating at max and a little hand shaking, hahaha, but let´s go. All set and go, runs nice and fast, smooth take off, all stable just two clicks on aleron trim... Let´s try a fast pass, wow!!! great!!! I did two more passes but i forgot to erase the camera memory, damm! but i did a great landing and will do a full video tomorrow! heheheh
Mirage2000 90mm maiden (0 min 47 sec)
Thanks !!!
humbertomelo is offline Find More Posts by humbertomelo
Old Oct 29, 2012, 08:35 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Very nice, may i ask how do you get access to the EDF now that it is all sealed?
Slaanesh is offline Find More Posts by Slaanesh
Old Oct 29, 2012, 10:32 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
very nice.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Oct 30, 2012, 09:02 AM
Brasil, GO, Goiânia
Joined Feb 2009
Slaanesh,
I did a lot of tests with esc, edf, battery, all working together... after a several runs if all ok, then i install inside the jet and seal the fuselage. For me, after sealing the fuselage there is no reason to access the edf, if i have to access the edf then will cut a square area in actual edf position.
Humberto
Old Nov 04, 2012, 05:59 AM
aqkhana2002 is offline
Find More Posts by aqkhana2002
Australia, NSW, Plumpton
I am searching this kind of thread almost 3 month you are grate man. But I have question and hope you can help me . Do u have any video where u make any part of this plan with fiber glass can you please list us what kind of material you have used . Really that will help and as non professional in fiberglass things. Pls pls pls help me ....
aqkhana2002 is offline Find More Posts by aqkhana2002
Old Nov 04, 2012, 07:45 AM
stingeragents is offline
Find More Posts by stingeragents
Joined Jan 2011
Fiberglass is easy man. Fiberglass cloth. Then cover it with minwax polycrylic or epoxy
stingeragents is offline Find More Posts by stingeragents
Old Nov 04, 2012, 04:37 PM
thanks for reply , just want one thing more to confirm , are you still using depron form/any form and over it you are using fiberglass ? or this is complete build with fiberglass?
aqeel
Old Nov 05, 2012, 12:28 AM
Brasil, GO, Goiânia
Joined Feb 2009
In my jets, i bend the depron first with a hot air gun then apply one fiberglass cloth with epoxi resin, simple as 2+2.
Old Nov 05, 2012, 05:57 PM
you got us a great idea. but i think i still need to do more practice as i tried yesterday ... but its really hard for me to curve it the way you did ... let see how many sheets i destory to learn how to do it... i visited your site where you have video how to do it... once again man thanks you very much ... you really save our time to join forms and then use filer to make its design...
+++can you tell me what was your final electronic. in this jet ?
+++ hot gun how much watt you have i have 2000w and i think its tomuch for 6mm form ?
+++ are you using 6mm depron form ?
Old Nov 06, 2012, 06:47 AM
Brasil, GO, Goiânia
Joined Feb 2009
EDF: 90mm, 12 Blade changesun
Motor: HET Typhoon 600-42, 1600kv
Lipo: 8s 3300ma 40c
ESC: TURNIGY K-Force 120A-HV OPTO V2 5-12S Brushless ESC
Servos: 3 x STD 35g, 1 x 9g Metal gear
I am use 5mm depron, and 2000w i think is enough to bend, but in my hot gun i have a switch to control the temperature.
Old Nov 06, 2012, 08:54 PM
do you recommend me this morot ?
http://www.ebay.com.au/itm/HET-RC-Ty...item3a7b5fdf56
i can only find this motor in australia... or any link for ebay etc.
Old Nov 06, 2012, 09:13 PM
Brasil, GO, Goiânia
Joined Feb 2009
No, i do not recommend... it is to small for our application... try this one: http://shop.rc-electric-jets.com/HET...00-68-1500.htm , if you gonna use 12 blade edf and 8s lipo...
Old Nov 08, 2012, 11:50 AM
Joined Jan 2011
I like your intake design. The half intake lip. Do you do the same thing for top of the edf or just leave it like in the pictures. Also is it sealed to each side of the fuesalage or is there a gap where air can pass by the fan
Old Nov 08, 2012, 02:03 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
stingeragents Look on the 5th row down 2nd pic in,fan
not fully enclosed yet, but would guess when top is on, that it is.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Build Log Megajets Mirage 2000 Build Guide superscott Foamies (Kits) 12 Jun 01, 2012 06:38 PM
Discussion mid air crash mirage 2000 40 pound turbine!! sherlockshah Jet Turbines 6 May 09, 2012 09:50 AM
For Sale NIB PNP Skyangel JAS39 Mirage 2000 FW190 T28 FMS 1400 & 800 warbirds www.hobbyb.com Aircraft - Electric - Airplanes (FS/W) 1 Apr 29, 2012 08:30 PM
Discussion amazing footage 40 pound turbine mirage 2000 Midair crash!!! sherlockshah Crash Discussion 21 Mar 29, 2012 11:10 AM
