Old Oct 16, 2012, 08:15 AM
humbertomelo is offline
Find More Posts by humbertomelo
Brasil, GO, Goi‚nia
Joined Feb 2009
Fixing the fiberglass turtledeck in to fuselage.
humbertomelo is offline Find More Posts by humbertomelo
Old Oct 18, 2012, 01:00 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
Almost ready to paint.
Old Oct 18, 2012, 01:41 PM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Looks very nice, is the whole outside of the model glassed with 3/4, and if so what did you use to fill the weave?
Lt599 is offline Find More Posts by Lt599
Old Oct 18, 2012, 07:11 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
Hi Lt599,
In fact the glassing process i did is inside glassing not outside, and i use epoxi resin with fiber glass cloth 90 grams/m2. For the external gaps i use a gap filler then sanding a lot... :-)
Next step is painting!
Old Oct 18, 2012, 08:48 PM
AMARILLO1978 is offline
Find More Posts by AMARILLO1978
AMARILLO1978's Avatar
Argentina, Corrientes
Joined Jan 2009
looks great!!! thank you for sharing plans... we wait for maiden flight video... regards from argentina!!
AMARILLO1978 is offline Find More Posts by AMARILLO1978
Old Oct 19, 2012, 11:51 AM
Optimus One is offline
Find More Posts by Optimus One
Joined Feb 2012
Hi humbertomelo..For one 64mm edf,the wingspan how must could be!?
If i let this dimensions,make some difference!?
Thanks,for the plans....Cheers
Optimus One is offline Find More Posts by Optimus One
Old Oct 19, 2012, 01:12 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
The PDF files (mirage 2000_part#1.pdf and mirage 2000_part#2.pdf) are for 64 - 70mm and (mirage 2000_EDF90mm) are for 90mm, all in scale 1:1 and ready to print.
Old Oct 22, 2012, 09:07 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
Applying acrylic base and the second layer with darker acrylic brown
Old Oct 23, 2012, 06:06 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
Wow
space 1 is offline Find More Posts by space 1
Old Oct 23, 2012, 07:51 AM
stingeragents is offline
Find More Posts by stingeragents
Joined Jan 2011
Does glassing the inside provide as much strength as glassing the outside? I've glassed a few planes but have never heard of glassing the inside of the plane. Also, do you ever end up with any gaps on your builds and if so how do you fill them or cover them.
stingeragents is offline Find More Posts by stingeragents
Old Oct 23, 2012, 01:41 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
stingeragents,
I think the strength is the same, but i don't like to sand resin + fiber glass, i put it inside just for convenience. Here in Brazil i found a gap filler mass used to cover gaps in walls, it is ultra light and matches foam color.
Old Oct 23, 2012, 04:13 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Humbertomelo, the plane looks great! thanks for making the plans available We have a light weight spackle over here that is probably the same thing. It is packaged under different names, "Fast and Final" , "Ready Patch" and probably others. It works great on foam. Did you seal the foam prior to paint? if not what paint did you use? , Greg (Lt599)
Old Oct 23, 2012, 04:38 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Lt599 A word to the wise on the Ready Patch. I used the stuff labled MH Ready Patch by Zinnser, on the foam plug for my F-86F. I seemed to work well untill I glassed the fuse. On J Morgans advice I used regular sheet rock compound for fill b-4 glassing. But I did have some Ready Patch that showed through. It seems it does not like epoxy!!! Every where I had used RP the foam got very soft or some what melted. Ended up cutting out all the RP and filling with Bondo.
Granted that was for a plug, but be carefull if you glass over it!!!.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 23, 2012, 05:10 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
Lt599,
Yes i did seal the foam before paint, it is just white acrylic paint then sand with fine grain then paint with acrilyc color.
Old Oct 23, 2012, 05:12 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
Painting more layers then the first varnish layer
Build Log Megajets Mirage 2000 Build Guide superscott Foamies (Kits) 12 Jun 01, 2012 05:38 PM
Discussion mid air crash mirage 2000 40 pound turbine!! sherlockshah Jet Turbines 6 May 09, 2012 08:50 AM
For Sale NIB PNP Skyangel JAS39 Mirage 2000 FW190 T28 FMS 1400 & 800 warbirds www.hobbyb.com Aircraft - Electric - Airplanes (FS/W) 1 Apr 29, 2012 07:30 PM
Discussion amazing footage 40 pound turbine mirage 2000 Midair crash!!! sherlockshah Crash Discussion 21 Mar 29, 2012 10:10 AM
