Old Sep 25, 2012, 07:51 PM
humbertomelo is offline
Find More Posts by humbertomelo
Brasil, GO, Goi‚nia
Joined Feb 2009
Build Log
Mirage 2000 - 120mm and 90mm EDF - Parkjetdesign
Hi,
This is my Mirage 2000 for 90mm EDF, i did a lot of upgrades since my first Mirage 2000 post --> ( http://www.rcgroups.com/forums/showthread.php?t=1187662 )
Specs:
Wing: 90cm
Fuselage: 130cm
Weight: ~2,5kg
Speed: ~ 200 - 250km/h (not tested),
EDF: ChangeSun 12 blades
Motor: HET Typhoon 600-42 1600kv
BAT: 8s lipo
Enjoy!
Humberto Melo
humbertomelo is offline Find More Posts by humbertomelo
Old Sep 26, 2012, 06:44 AM
Brasil, GO, Goi‚nia
Joined Feb 2009
Installing mechanical retracts
Old Sep 26, 2012, 06:48 AM
space 1 is online now
Find More Posts by space 1
USA
Joined Apr 2007
spec's wing auw stall speed
space 1 is online now Find More Posts by space 1
Old Sep 26, 2012, 01:35 PM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Very interesting did you glass the foam? Will be watching this one.
Lt599 is offline Find More Posts by Lt599
Old Sep 26, 2012, 04:22 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
Yes i did, epoxi resin + fiber cloth
Old Sep 26, 2012, 04:28 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
Assembling EDF and retracts
Mirage 2000 - Landing Gear (0 min 36 sec)
Old Sep 26, 2012, 09:58 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Looks pretty cool. Copper plate? interesting.
Old Sep 27, 2012, 06:56 AM
Brasil, GO, Goi‚nia
Joined Feb 2009
The fiber glass copper plate it is very strong and cheap. Great material...
Old Sep 27, 2012, 07:01 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
interesting, hows the wieght compared to say, 1/8 lite ply?
How re you getting it to stick? I mean with such hard smooth surface of the copper plate. Wont a hard jolt just pop it apart?
Ive had expeirnece with the epoxies seperating with hard surfaces.Pops clean off like it was out of a mold.
Im just saying i think you would have gotten a stronger bond and much lighter if lite ply was glued to the foam then you glass and epoxy ,sandwiching the lite ply between the two.
D_FAST is offline Find More Posts by D_FAST
Old Sep 27, 2012, 07:02 AM
Brasil, GO, Goi‚nia
Joined Feb 2009
Specs:
Wing: 90cm
Fuselage: 130cm
Weight: ~ 3,5kg
Speed: ~ 250km/h
Old Sep 27, 2012, 07:52 AM
Brasil, GO, Goi‚nia
Joined Feb 2009
This copper plate have one side with copper, the other side is pure fiber glass.. sand it a little bit and it is ready to glue. I like to do some experiences. I did your way, plywood glued on foam then glassing, it is a great technique.
Old Sep 27, 2012, 07:32 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Interesting, I assume its used in electronics production?
Old Sep 27, 2012, 07:45 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
Yes, it is used in electronics devices, but it is very easy to find it... in any electronic store like Radio Shack you will find a blank copper plate.
Old Sep 29, 2012, 08:41 AM
Brasil, GO, Goi‚nia
Joined Feb 2009
Installing servos, ESC and wires
Old Oct 08, 2012, 05:16 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
One more update, installing wings and elevons
Build Log Megajets Mirage 2000 Build Guide superscott Foamies (Kits) 12 Jun 01, 2012 05:38 PM
Discussion mid air crash mirage 2000 40 pound turbine!! sherlockshah Jet Turbines 6 May 09, 2012 08:50 AM
For Sale NIB PNP Skyangel JAS39 Mirage 2000 FW190 T28 FMS 1400 & 800 warbirds www.hobbyb.com Aircraft - Electric - Airplanes (FS/W) 1 Apr 29, 2012 07:30 PM
Discussion amazing footage 40 pound turbine mirage 2000 Midair crash!!! sherlockshah Crash Discussion 21 Mar 29, 2012 10:10 AM
