Old Sep 25, 2012, 05:41 PM
trucker41 is offline
Find More Posts by trucker41
cant get right !!!
trucker41's Avatar
United States, CA, Victorville
Joined Sep 2012
Help!
250 mech dont fit in the fuse
cant seem to get the mech to fit in the fus the elevator servo is in the way and pushes it to the side iv racked my brain for two strait days trying to figure it out can some 1 please advise me on what to do thanks in advance
trucker41 is offline Find More Posts by trucker41
Old Sep 25, 2012, 07:48 PM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
How about some specifics on your build and some photos so we can offer some recommendations. Generally speaking, you either need to move or reduce the size of the servo or make room in the fuselage by grinding or cutting.
Double E is offline Find More Posts by Double E
Old Sep 26, 2012, 02:22 AM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
post some photo please ! The idea always more than trouble !
kin is offline Find More Posts by kin
Old Sep 26, 2012, 06:30 AM
Keyrigger is offline
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
If it is the Align fuselage, then most times, it is not the elevator servo causing the issues, but the tail servo needing to be swung down and made verticle to the ground, under the boom. If you are not using Align or Savox micro servos, change out the elevator servo to one of those as it fits perfectly with a 250 SE. Take care.
Don
Keyrigger is offline Find More Posts by Keyrigger
Old Oct 01, 2012, 06:33 PM
cant get right !!!
trucker41's Avatar
Joined Sep 2012
well i figure now i will just buy a gaui 200 or ill see if cap 231 still wants to sell his
Old Oct 04, 2012, 03:01 PM
C Andrew Green is offline
Find More Posts by C Andrew Green
แอนครู กรีน (เขียว)
C Andrew Green's Avatar
Oxford, UK
Joined Mar 2002
Trucker41,
The simple fix for the elevator servo hitting the fuz is to fit it inside the frames. Don't separate the frames, all I did was to carefully remove the top of the servo and fit it inside the frames then reassemble the servo in-situ. I then fitted the ball on the inside of the servo arm to maintain the line of the pushrod. I made an extension to mount the battery further forward as can be seen here , if you look at some of my other posts there, there are some other pics of my MD500.
Andrew
C Andrew Green is offline Find More Posts by C Andrew Green
Old Oct 04, 2012, 04:17 PM
Brutus1967 is offline
Find More Posts by Brutus1967
life without risk isn't living
The Netherlands
Joined Nov 2009
Andrews solution is also valid for the 450 size MD 500 Align fuse, as we found out.
At least, with the servo's we used (Hitec HS-65HB it was)
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Old Oct 06, 2012, 08:27 AM
cant get right !!!
trucker41's Avatar
Joined Sep 2012
the servos that i am using are the ones from copter x they are just too big and now i am just going to invest in a gaui 200 and make life a little simpler . my big prob now is going to be weight i am scaling the fuse out with all the neat little bird parts fom a bbi little bird toy the complete cockpit and grab bars and bench seat that runs along the sides of the fuse etc etc
Old Oct 08, 2012, 10:11 PM
YankleStl is offline
Find More Posts by YankleStl
YankleStl's Avatar
United States, MO, St. Louis
Joined Sep 2012
What do u do when u someone scams u for 275 dollars on a used heli???
YankleStl is offline Find More Posts by YankleStl
Old Oct 09, 2012, 01:46 AM
The Netherlands
Joined Nov 2009
Dunno.... Bust 'is nose? But what has that got to do with a servo touching the fuse of a 250 size MD 500?????
Brgds, Bert
Sold explorer fuse 250.00 3.8 4.0 mike wiese Aircraft - Sailplanes (FS/W) 0 Aug 28, 2012 08:06 PM
Question Satellite Rx won't fit in fuse, where should I put it? arnav Radios 5 Aug 06, 2012 12:25 PM
For Sale 2 Align 250 F3C Fuse kits NEW! Both colors! HD Hucker Aircraft - Electric - Helis (FS/W) 0 Apr 26, 2012 10:19 PM
Question Would exi 250 tail aseembly fit on Dynam E Razor 250? jcervantes11 Micro Helis 0 Oct 30, 2010 08:09 PM
Discussion Where to buy small receiver packs that will fit in DLG fuses? ptglass Hand Launch 6 Mar 10, 2006 01:02 PM
