United States, CA, Malibu
Joined Apr 2012
Square Tubes price for two found here:
http://quadframe.myshopify.com/colle...e-aluminum-arm and cool black here: http://quadframe.myshopify.com/colle...k-aluminum-arm I think igimbal should be done with L brackets without boom blocks. |
I do talk about there being no free lunch, and part cost do add up pretty quick if you go 4:1 gear ratio you could probably get away with cheaper servo, but pulleys cost bit more. downside is that you will lose platform independance and performance. so, cost will somewhat depends on what you are willing to live iwth. I mean crius SE is about 75% performance of HFG, but cost lot less. though once you try HFG, it is tough to go back(once you are using good gimbal system)
To be honest, you should be doing it not to save money, but because you enjoy building, testing and possibly contributing to the hobby. The cost and time factor do add up quick(especially the time, but cost is not trivial), but if you have right passion, you should be able to get something to work pretty well with knowledge that you built it. not going to say it will be easy though. It is funny because hansen really did not like using stabilized gimbal until I finally showed it to him that it does work with right setup. now, he is using my gimbal for his work and built this to share. I can provide pulleys/belt and isolators as well and usually bit cheaper with shipping than getting from others. I do think having some form of erector set would be cool though. kind of mini or micro 80/20 kit. hmm. would make building structure much easier. |
Latest blog entry: direct drive servo vs geared servo
Hawaii
Joined Feb 2003
>>Yes but I would like to see some videos.. building a gimbal is one thing. Having it perform correctly is another. Looking forward to some flight reports.<<
So would I. I am still waiting for parts to finish either gimbal. LIving in the middle of the Pacific Ocean has a price. >> Also it would be nice to have a running count on part cost.. servos alone will be $200 , correct?<< Of course I am keeping track of the part costs. The Servo cost will be entirely up to you. I am just talking about the gimbal here. You can spend way over than $300 on servos. |
![]() Quote:
Yes but to get any good results imho, you will need to spend at least $200 on servos.. sucks, I know! |
Hawaii
Joined Feb 2003
>>Yes but to get any good results imho, you will need to spend at least $200 on servos.. sucks, I know!<<
The gimbal can only hold the camera on. The servo is the muscle that keeps the camera movement smooth. So high quality servo is a must to achieve good video. Either that or use a fixed gimbal. |
United States, NC, Tryon
Joined Sep 2005
http://www.dpreview.com/news/2012/09...or-NEX-E-mount Wouldn't this work to reduce those "micro bounces"? Albeit at a fairly high cost (around $850 for the lense alone)... |
Joined Sep 2005
They sell square and round tube that is used in full scale aircraft construction. At $2 to $4 a foot, it's priced comparatively. You can also order small quantities with no issues and they ship fast... |
Hawaii
Joined Feb 2003
Great idea on the gimbal. I am too a "diy"er and i was missing a kick start to build a gimbal. Actualy Seismic had helped me in the past with a previus design that worked great as a fixed gimbal because i was missing the pulleys, bearings and special tools. This on the other hand looks that can be done, especialy if Rusty helps to make it a kit.
I am 100% in for this. Well done Seismic!!! |
Joined Sep 2005
Hey Seismic,
Hawaii
Joined Feb 2003
>>You think you might be able to turn some parts for an interested diy'er? I'm thinking about trying the square alum arm style with the bearings pressed in and the pot screwed into the arm. I can make any arms or plates I need (benchtop milling machine) but I don't have a lathe. Let's talk...
<<I will be happy to help you with turning parts. However if you hold on just a little longer I will be able to figure out what parts you need turned. I think for the aluminum square tube version it may come down to only two parts. They will be the bushings on the camera tray to hold the shafts. However Rusty is getting excited about the aluminum tube version and he may make some Delrin blocks just for 1/4" shafts so we don't even need the bushings. Rusty is testing out plates right now. So you don't have to make those. All you need is to get those aluminum tubes and cut them to size. You don't even need to drill holes on the arms. Rusty is thinking about making plates for the ends of the arm so you can screw the external pot on one plate and press the bearing on the other. This is getting simpler and simpler and very exciting. I really like simplicity in design. It is just so elegant. |
Joined Sep 2005
SWEEEET!!!
That's great news. I have an nex5n that really needs a nice mount. Your design looks better than anything I've seen that I could even think about being able to afford. I'm definitely in whenever this gets close... Thanks' |
| Thread Tools | |
| Question Can you make Embedded Pictures show up with Show Attachments in this Thread? | Richard N | Site Suggestions / Complaints | 4 | Sep 04, 2012 01:03 PM |
| Help! Can you tell me what make and model this car is? | KiTCyclic | Electric Power Cars | 25 | Aug 14, 2012 11:41 AM |
| Careful! Always make sure you clarify functional condition prior to agreeing to buy!!!!!! | -= GYRO =- | Trader Talk | 84 | Jun 15, 2012 01:06 PM |
| Help! Is there any gimbal stabilisation unit out there that can do camera lock? | hexa | Multirotor Talk | 9 | Apr 17, 2012 06:46 PM |
| The new momie hopperz f/d channel rc you can make a full functional micro plane | saab2fast | Indoor and Micro Models | 10 | Dec 16, 2004 07:43 PM |
