Joined Oct 2010
Point being, I wonder how much of the performance of these is due to the MI, or is it that their gears and motor are good. I'm really itching to buy one of the $80 MI Brushless servos and see how it does direct drive. I could see how maybe you could get less deadband and jitter with MI vs. a pot. With the pot, the precision in your measurement, and the deadband you want to control at is going to depend on how clean your power supply is. I'd think any ripple in the voltage would result in noise on the pot feedback. If you make the deadband too small, it will never stop moving. But with MI, that all goes away. You'd only have to worry about magnetic fields, which are easier to deal with I think. |
Hawaii
Joined Feb 2003
http://www.shop.aglhobbiesllc.com/Ca...Parts-Kit.html Rusty ordered the pulleys and belts so the option 2 kit will be ready when he is ready. |
Hawaii
Joined Feb 2003
I am just about ready to use a 180 degree servo for the tilt instead of the external pot. Maybe if I drop the ratio back to 2.5 to 1 and use a super strong servo will be good. |
VA
Joined Nov 2009
Hawaii
Joined Feb 2003
Well, this way it is very strong for sure.
Rusty |
Hawaii
Joined Feb 2003
Ok I refined the kit gimbal a little. I was trying to enlarge the pot plate hole to get the Bourns pot to stick the shaft out a bit more. Then I decided to drill the holes in the middle instead of using the holes on the side of the plates. That way I save 50% of the hardware. Then I started substituting the stainless bolt with aluminum bolt except for places where I don't have the correct length. FWIW the bulk of the bolts are 3/4" with about 8 each 1 1/4" mixed in plus a few shorter ones for the bottom of the camera tray.
On a totally unrelated note, I was not happy with the Tamron 24mm I was using on my Pentax camera to take these pictures. So I rummage around and found a very very old Asahi Pentax Super Takumar 35mm f2 screw mount lens in my stash. I rummage around some more and found a screw mount adapter to Pentax K and voila. I have the 35mm lens on The Pentax K200D digital. The lens has some radioactive stuff on it so it is turning yellow but oh the image quality is to die for.
| Thread Tools | |
| Question Can you make Embedded Pictures show up with Show Attachments in this Thread? | Richard N | Site Suggestions / Complaints | 4 | Sep 04, 2012 01:03 PM |
| Help! Can you tell me what make and model this car is? | KiTCyclic | Electric Power Cars | 25 | Aug 14, 2012 11:41 AM |
| Careful! Always make sure you clarify functional condition prior to agreeing to buy!!!!!! | -= GYRO =- | Trader Talk | 84 | Jun 15, 2012 01:06 PM |
| Help! Is there any gimbal stabilisation unit out there that can do camera lock? | hexa | Multirotor Talk | 9 | Apr 17, 2012 06:46 PM |
| The new momie hopperz f/d channel rc you can make a full functional micro plane | saab2fast | Indoor and Micro Models | 10 | Dec 16, 2004 07:43 PM |
