Old Oct 28, 2012, 10:56 AM
13brv3 is offline
Find More Posts by 13brv3
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Originally Posted by mattchase View Post
Sweet, I get to test another gimbal!
Oh, wait, you meant Hansen didn't you?
No, I went over both of you your heads. This one goes to James
Rusty
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old Oct 28, 2012, 11:23 AM
mattchase is offline
Find More Posts by mattchase
United States, TX, Seguin
Joined Mar 2005
Do'h!
mattchase is offline Find More Posts by mattchase
Old Oct 28, 2012, 12:30 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Rusty as usual very nice work. I guess that takes the 9" belts also? That looks like an AB or Ohmlite pot on there. Spectrol makes a nice 5K continuous rotation wire wound pot for this type use but may be a little more expensive than what some want to pay.
pug398 is offline Find More Posts by pug398
Old Oct 28, 2012, 12:33 PM
SeismicCWave is online now
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
Originally Posted by prodriverex View Post
Is making the rectangle into L shape to get rid of the corner going to affect the rigidity?
I don't know. I want to at least cut an angle in the plate to get rid of the corner.
SeismicCWave is online now Find More Posts by SeismicCWave
Old Oct 28, 2012, 12:36 PM
AMA 46133
Hawaii
Joined Feb 2003
>>OK, here's a picture of Prototype #2<<
That sure looks good.
Old Oct 28, 2012, 12:38 PM
AMA 46133
Hawaii
Joined Feb 2003
>> Spectrol makes a nice 5K continuous rotation wire wound pot for this type use but may be a little more expensive than what some want to pay.<<
Do you have a link to purchase this? I also want to test different pots.
Old Oct 28, 2012, 12:43 PM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
The pot is complicated by the fact that it's physical properties are also important. The one you see has a 2" shaft, and the shaft is just enough under 0.25" to fit the bearings well. I haven't found many pots that fit that description I'm afraid. This is the pot I'm using:
http://www.digikey.com/product-detai...502C-ND/222782
Rusty (off to exercise my poor neglected car)
Site Sponsor
Old Oct 28, 2012, 12:47 PM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
If you don't want to take up space in the inside corner of the yoke, and you still want to use a rectangular plate, you can just extend the rear bar past the left and right bars, then move the plate outboard. That gives the same contact area, but will cost a tiny bit of weight in extra bar length.
I'd love to have made an essentially triangular plate, with the bars mitered at 45 degrees where the meet in the corners, but that would be cruel to people who use my plates
Rusty
Site Sponsor
Old Oct 28, 2012, 12:53 PM
pug398 is offline
VA
Joined Nov 2009
The next problem is the value. Everyone seems to keep using this 5K ohm number, but the pots that ServoCity leaves on my servos measure around 1.4K ohm. The above pot comes in 1k, 2.5k, and 5k. So far, I've only tested the 5K with a servo, and it worked fine, but later today, I hope to try at least the 2.5K compared to the 5K, to see if there's any noticeable difference. I suspect it's just a voltage divider, so the value shouldn't matter, but I haven't found a servo schematic with enough details to confirm that. If 5K works, it's probably the safer choice, since it should never allow more current through the circuit than the servo maker expected (assuming 5K is the max value used in servos).
Looked closer and see how you would need the long shaft version now. I am pretty sure you are correct they are using it as simple divider but the there is always the chance they have trim resistors on each leg in which case the value would be important. Always something to consider
Old Oct 28, 2012, 12:57 PM
pug398 is offline
VA
Joined Nov 2009
http://www.digikey.com/product-detai....0K-ND/1287395
Thats the least expensive one with others having a better tolerances. You may can use a shaft coupler with it since its a short shaft. Didn't realize you all were using the pot itself for the coupling shaft until Rusty just said something.
Old Oct 28, 2012, 01:11 PM
tigar is offline
Find More Posts by tigar
tigar's Avatar
Athens, Greece
Joined Sep 2001
Can a parts list be compiled? It would be nice to know what bearings, pots, belts and pulleys are needed. I guess the better way is to get all of these from Rusty but until the kit is ready....
tigar is offline Find More Posts by tigar
Old Oct 28, 2012, 01:25 PM
AMA 46133
Hawaii
Joined Feb 2003
>>If you don't want to take up space in the inside corner of the yoke, and you still want to use a rectangular plate, you can just extend the rear bar past the left and right bars, then move the plate outboard. That gives the same contact area, but will cost a tiny bit of weight in extra bar length.<<
That will work. Especially for those that want to create a smaller gimbal with maximum inside space. I can't wait to see how many different ways of making the gimbal with your plates.
>>I'd love to have made an essentially triangular plate, with the bars mitered at 45 degrees where the meet in the corners, but that would be cruel to people who use my plates <<
Oh yeah, that would be really nice.
Old Oct 28, 2012, 01:27 PM
AMA 46133
Hawaii
Joined Feb 2003
Thanks. Yes it is simpler to use the shaft from the pot with a bearing as support.
Old Oct 28, 2012, 01:45 PM
AMA 46133
Hawaii
Joined Feb 2003
Ok here it is:
1) 2 each MXLS-01 or MXLS-02 for Futaba or Hitec servo. http://www.lynxmotion.com/c-75-accessories.aspx
2) 2 each "A 6Z16-090DF2508" 90 groove pulley. https://sdp-si.com/eStore/
3) 2 each "A 6B16-120025" 120 groove timing belt. https://sdp-si.com/eStore/
4) 2 each 1/4" X 1/2" X 3/16" flanged bearings for roll.
http://www.vxb.com/page/bearings/PROD/1-4inch/kit776
5) 3 each 1/4" X 3/8" X 1/8" flanged bearings for tilt.
http://www.vxb.com/page/bearings/PROD/1-4inch/Kit10974
6) 2 each .2947" precision stainless shafts "S4016Y-US3-20".
https://sdp-si.com/eStore/ (Rusty is using some anodized aluminum shafts. He will have to tell you where he gets his from.)
7) 1 each 5K pot.
Or this is where I got mine from:http://www.mouser.com/ProductDetail/...II4b0wYafEc%3d
I think that's everything you will need. Of course some 4-40 nuts and bolts if Rusty is not providing them. I am now using aluminum nuts and bolts and love them.
Old Oct 28, 2012, 02:15 PM
tigar is offline
tigar's Avatar
Athens, Greece
Joined Sep 2001
Great thanks for that!
One more thing. The mks servos what kind of hub the have? Futaba or hitec
Question Can you make Embedded Pictures show up with Show Attachments in this Thread? Richard N Site Suggestions / Complaints 4 Sep 04, 2012 01:03 PM
Help! Can you tell me what make and model this car is? KiTCyclic Electric Power Cars 25 Aug 14, 2012 11:41 AM
Careful! Always make sure you clarify functional condition prior to agreeing to buy!!!!!! -= GYRO =- Trader Talk 84 Jun 15, 2012 01:06 PM
Help! Is there any gimbal stabilisation unit out there that can do camera lock? hexa Multirotor Talk 9 Apr 17, 2012 06:46 PM
The new momie hopperz f/d channel rc you can make a full functional micro plane saab2fast Scratchbuilt Indoor and Micro Models 10 Dec 16, 2004 07:43 PM
