Old Oct 20, 2012, 08:16 PM
jcmonty is offline
Find More Posts by jcmonty
United States, CA, San Diego
Joined Apr 2012
Wow, that is excellent, Hansen. Any changes since the last video? Roll looks spot on and tilt is almost there. Was is if a calm day (can't tell on my phone)
jcmonty is offline Find More Posts by jcmonty
Old Oct 20, 2012, 08:18 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
I increased the tilt just a little. I think I did a bit too much. I will back it down a bit now. I have not touched the roll.
It was a calm day so I had to create the movement with my sticks.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Oct 20, 2012, 08:21 PM
prodriverex is offline
Find More Posts by prodriverex
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
Fantastic! So you have to put the camera on manual focus and infinity focus right?
prodriverex is offline Find More Posts by prodriverex
Old Oct 20, 2012, 08:54 PM
AMA 46133
Hawaii
Joined Feb 2003
For the lens I am using yes. The lens is manual focus. Also not to have the lens focus on the yellow ball and blur the background I have to use manual focus. For normal shoot without the yellow ball I just use auto focus.
Manual focus is better if you only plan to shoot farther than 15 feet i none flight. For me sometimes I get real close to get some near shot so I leave the lens on auto focus most of the time.
Old Oct 20, 2012, 08:59 PM
The Engineer
Singapore
Joined Dec 2009
ok roger that. thanks for sharing..
Old Oct 21, 2012, 01:33 AM
jcmonty is offline
Joined Apr 2012
I could tell
Would you mind posting a clip or two of the raw footage against post-stabilized footage? I just want to compare some of the footage you are getting with the "polished" stuff I see from the Cinestar gimbals. Obviously that footage is generally stabilized so it's hard to make a 1:1 comparison when we are looking at raw video from you. I wish there was some raw CS footage I could look at.. trying to decide if there method of higher gear ratios helps with the small bumps/ticks.
Anyways, your raw footage is some of the best I have seen. Great job
Old Oct 21, 2012, 02:28 AM
AMA 46133
Hawaii
Joined Feb 2003
I could tell
Let see if I can understand what you are saying. You mean you want to see me stabilize some footage with software? I can do that.
Old Oct 21, 2012, 02:36 AM
The Engineer
Singapore
Joined Dec 2009
I was confused for a moment.
But why the need to compare post stabilised? Evaluating software like smoothcam?
Old Oct 21, 2012, 08:57 AM
mattchase is offline
Find More Posts by mattchase
United States, TX, Seguin
Joined Mar 2005
Having done a number of flights that weren't super smooth and always having to use post stabilization, I can tell you that Hansens latest raw video is probably about as smooth as any post stabilized result I've ever gotten. As smooth as his raw video is his post stabilized video should come out perfect without any noticeable loss of resolution / sharpness.
mattchase is offline Find More Posts by mattchase
Old Oct 21, 2012, 09:54 AM
Jeffem62 is offline
Find More Posts by Jeffem62
Jeffem62's Avatar
United States, TX, El Paso
Joined Apr 2012
Can you give us the fc you are using now? And gimbal gain settings?
Any new pics of the gimbal?
Jeffem62 is offline Find More Posts by Jeffem62
Old Oct 21, 2012, 11:06 AM
AMA 46133
Hawaii
Joined Feb 2003
I am using the CC3D FC and also as gimbal control. My input range on roll is 36 and on tilt is 86.
Old Oct 21, 2012, 01:02 PM
jcmonty is offline
Joined Apr 2012
Ya, I could have said that a bit more clearly. Yes
Old Oct 21, 2012, 01:56 PM
Jeffem62 is offline
Jeffem62's Avatar
Joined Apr 2012
And your servos?
Nice video by the way
Old Oct 21, 2012, 05:27 PM
tomeparker is offline
Find More Posts by tomeparker
tomeparker
United Kingdom, England, Cambridge
Joined Jul 2011
Do you think you could get the gimbal to work that good with a Naza? Apparently the Naza isn't as good at gimbal control compared to other FC such as the CC/CC3D.
tomeparker is offline Find More Posts by tomeparker
Old Oct 21, 2012, 06:48 PM
Joined Mar 2005
I finally had the chance to get in a flight this afternoon...and of course my camera had a file error while recording! It also is pretty windy and I had the copter leaning at an angle just to keep it in place, so not the best day for testing. I did get one other very short flight in with a nearly dead battery, certainly not a very good test video but here it is. The weird out of focus yellow thing in the top of the frame is the best I could do for a point of reference without going to the store to get stuff. I will try to make something better for the next test flight.
gimbal 121021 a (1 min 5 sec)
I still need to tune the gimbal some more and I know I can see some vibrations, but I'm not sure if they are from my motors (some of which don't spin as smooth as they used to - I'm looking into new bearings) or from the gusts of wind hitting the copter / gimbal. I'm also wondering if my gimbal to UAP mount might need more work.
As for the gimbal / servos, with smaller or slower movements it seems to be doing pretty good, but with larger or quicker movements it looks like it isn't keeping up on either axis. I should have another chance tomorrow evening to get in at least one more flight, hopefully it won't be as windy and I will make sure I have a fully charged battery!
Question Can you make Embedded Pictures show up with Show Attachments in this Thread? Richard N Site Suggestions / Complaints 4 Sep 04, 2012 01:03 PM
Help! Can you tell me what make and model this car is? KiTCyclic Electric Power Cars 25 Aug 14, 2012 11:41 AM
Careful! Always make sure you clarify functional condition prior to agreeing to buy!!!!!! -= GYRO =- Trader Talk 84 Jun 15, 2012 01:06 PM
Help! Is there any gimbal stabilisation unit out there that can do camera lock? hexa Multirotor Talk 9 Apr 17, 2012 06:46 PM
The new momie hopperz f/d channel rc you can make a full functional micro plane saab2fast Scratchbuilt Indoor and Micro Models 10 Dec 16, 2004 07:43 PM
