Hawaii
Joined Feb 2003
I finally got the 1/2" square aluminum tube gimbal on a multi rotor and flew it.
The result is pretty encouraging. I believe with a little tuning it should yield very usable video footage.
VA
Joined Nov 2009
I really like your alum design and will try to follow that. Since I will only be testing with a small camera I may just braze the C and L brackets. This is probably a dumb question (won't be first or last) but why is the roll pivot off center?
Hawaii
Joined Feb 2003
My philosophy is that you are not trying to setup a gimbal to be able to follow the movement perfectly. The stabilizer is only there to "damp" the large movement and reduce it. So instead of over compensating with too much gain I am using less gain. Yes, the camera was a NEX 5N. I took off the camera to take the still image after the flight. |
Hawaii
Joined Feb 2003
The whole idea behind these gimbals I am building is that you DO NOT need a drawing. You just pick up the off-the-shelf parts, measure, cut and bolt them together.
If you have to follow a drawing and use specialized tools, not too many people can build one. |
What makes it difficult for me is the sizes and the measures of special items. It would be great if I had a shopping list for bearings, rods, pulleys and belts that are needed. The measuring and cutting of alu tubes is the easy part.
By the way askman has made a nice change to his yoke design. He is using carbon tube and delrin sheet... |
Hawaii
Joined Feb 2003
>>What makes it difficult for me is the sizes and the measures of special items. It would be great if I had a shopping list for bearings, rods, pulleys and belts that are needed. The measuring and cutting of alu tubes is the easy part.<<
That is why Rusty at AGL Hobbies is going to make a kit. You can get the pulleys and belts from a number of different sources. Andrey (askman) sells belts, pulleys and potentiometers. You can find bearings on eBay. Rusty is trying to make the gimbal so the builder does not have to drill holes. >>By the way askman has made a nice change to his yoke design. He is using carbon tube and delrin sheet...<< Yes I have been keeping up with Andrey on his designs and improvements. His gimbals are getting nicer with each upgrade. I am flying 4 of his prototypes. |
United Kingdom, England, Cambridge
Joined Jul 2011
Great thread, great work. I'm currently after a gimbal just like these, buying one is far too expensive. I only need to have it hold a GoPro so I might be able to cut some weight once the design is fully refined.
Until then, I'm trying to get this printed on an FDM free of charge. http://www.thingiverse.com/thing:20080 |
| Thread Tools | |
| Question Can you make Embedded Pictures show up with Show Attachments in this Thread? | Richard N | Site Suggestions / Complaints | 4 | Sep 04, 2012 01:03 PM |
| Help! Can you tell me what make and model this car is? | KiTCyclic | Electric Power Cars | 25 | Aug 14, 2012 11:41 AM |
| Careful! Always make sure you clarify functional condition prior to agreeing to buy!!!!!! | -= GYRO =- | Trader Talk | 84 | Jun 15, 2012 01:06 PM |
| Help! Is there any gimbal stabilisation unit out there that can do camera lock? | hexa | Multirotor Talk | 9 | Apr 17, 2012 06:46 PM |
| The new momie hopperz f/d channel rc you can make a full functional micro plane | saab2fast | Indoor and Micro Models | 10 | Dec 16, 2004 07:43 PM |
