Old Oct 06, 2012, 10:01 AM
alevesque is offline
Find More Posts by alevesque
Creative director
Canada, QC, Montreal
Joined Dec 2011
There's also onlinemetals.com, they seem to have a pretty good selection...
alevesque is offline Find More Posts by alevesque
Old Oct 09, 2012, 05:34 PM
jcmonty is offline
Find More Posts by jcmonty
United States, CA, San Diego
Joined Apr 2012
Hansen or Rusty, any more testing/updates on this gimbal idea?
jcmonty is offline Find More Posts by jcmonty
Old Oct 09, 2012, 06:24 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
Yes, Rusty is busy making one out of 10mm square aluminum tube. I am waiting for some parts to show up to finish up the 1/2" square aluminum tube version. Hopefully later today I will have some more pictures.
Rusty is keeping his build a secret for now but it is looking really good.
Since Rusty is making a 10mm version I ordered some 10mm carbon pultrude square tubes and 5/16" square basswoods. My plan is to cut the carbon tubes and CA glue the basswood inside. Then I will build a 10mm square tube version with the carbon/basswood to see how light I can make it.
Right now the 1/2" square tube version may very well be under 500 grams without the camera.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Oct 09, 2012, 11:15 PM
jcmonty is offline
Joined Apr 2012
500 grams would be really good. If i recall, the CS is about 700 grams, which is pretty light for the size.
How are you liking your servos for the carbon tube version you made?
Old Oct 09, 2012, 11:55 PM
AMA 46133
Hawaii
Joined Feb 2003
I am just about finished with the 1/2" alum gimbal. It is at 577 grams. So not quite below 500 grams. I hope the 10mm version will be lighter.
I also got some 10mm alum tubes from Rusty and I weighed them against the carbon tubes. On a 12" piece the difference is only 5 grams so I am not going to bother with the carbon tubes for now. Unfortunately the 10mm tubes are hard to find in the States.
I liked the servos I used on the CF gimbal. I only had one flight and the gimbal went to Matt for testing. I hope he will let us know how it is working for him.
On my one flight the roll was just fine and the tilt was over compensating.
I got most of the parts and pretty much finished the 1/2" alum gimbal. I just have to wait for the roll servo to show up from Servo City. I just realized all my servos need external pot and I am not ready to use one on the roll axis.
Old Oct 10, 2012, 01:08 AM
AMA 46133
Hawaii
Joined Feb 2003
I think pictures make the thread less boring.
Old Oct 10, 2012, 01:46 AM
FlyingMcCoy is online now
Find More Posts by FlyingMcCoy
Joined Mar 2010
FlyingMcCoy is online now Find More Posts by FlyingMcCoy
Old Oct 10, 2012, 07:41 AM
13brv3 is offline
Find More Posts by 13brv3
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Greetings,
I'm not sure I'd call the build "secret", but I know that things will change several times along the way, so I usually try to avoid posting pics until I'm close to the final design. The biggest thing I need right now is time.
500 grams will be tough, and maybe impossible without using directly bolted tubes. What you see in the crappy photos is 465 grams (yes my scale can read grams <g>) with the second servo and pulley included. The additional material will certainly push that over 500, but I haven't substituted the aluminum hardware yet, so that will help. Unfortunately, those servos are about 150 grams of the total.
Cheers,
Rusty
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old Oct 10, 2012, 08:03 AM
mattchase is offline
Find More Posts by mattchase
United States, TX, Seguin
Joined Mar 2005
Hi guys,
I just got Hansens round tube gimbal last night, so far I've only had a chance to open the box and give it a quick once over. It does feel a bit heavy (about 730g including mounting hardware) but is really well built and quite clever in it's design. I'm not too worried about the weight since I'm planning on flying this on a Y6 which currently flies my gimbal / GH1 at half throttle, so should have enough power (I don't remember what my current gimbal weighs, will check later).
More thoughts and comments as I get it setup and use it.
mattchase is offline Find More Posts by mattchase
Old Oct 10, 2012, 01:29 PM
jcmonty is offline
Joined Apr 2012
Originally Posted by 13brv3 View Post
Greetings,
Cheers,
Rusty
Looks great, Rusty! I like how adjustable and scaleable it's going to be and the simplicity. A few questions to satiate my curiosity:
1) What's your kit going to include? Plates, hardware (including bearing/bushings), pulleys.. ?
2) Can we expect that it will integrate nicely with your current isolation setup?
3) Where are you getting your alum tubes from?
4) What is that tilt pot you are using?
5) What ratio are you trying out in those pictures?
Also, HK has some CF tube that may work http://www.hobbyking.com/hobbyking/s...50x10_5mm.html. I would add dowels to help with torsional stresses
Old Oct 10, 2012, 01:41 PM
AMA 46133
Hawaii
Joined Feb 2003
>>1) What's your kit going to include? Plates, hardware (including bearing/bushings), pulleys.. ? <<
Rusty can best answer that. I would imagine providing pulleys, belts, bearings and pot will be more convenient for the end user.
>>2) Can we expect that it will integrate nicely with your current isolation setup?<<
I have been thinking about that for a couple of nights now. I would like to see the isolator attachment points to spread out farther apart for less movement.
>>3) Where are you getting your alum tubes from?<<
Rusty will know. I don't.
>>4) What is that tilt pot you are using?<<
Rusty found them.
>>5) What ratio are you trying out in those pictures?<<
32 tooth servo side and 90 tooth gimbal side. So that's 2.8 to 1.
>>Also, HK has some CF tube that may work http://www.hobbyking.com/hobbyking/s...50x10_5mm.html. I would add dowels to help with torsional stresses<<
So does Radical RC and a couple of other vendors in the States. If 10mm square aluminum tubes are hard to come by in the US the square carbon pultrude will be an alternative. It will be slightly lighter but not by much. I weighed them.
You do have to sleeve the carbon tubes with either square basswood or round dowels for the ones with round holes in the middle.
Let me see if I can find some 5/16 balsa. I may try sleeving the tubes with balsa.
Old Oct 10, 2012, 07:00 PM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Good question, and I wish I had a good answer
Seriously, the most basic kit would have everything but the servos, pulleys, and tubing. One or two ratios of pulleys would certainly be available as an option. Since the 10mm is so hard to get in the US, I'll almost certainly have to stock it as an option in fairly short lengths. I don't have any plans to stock, or modify servos at this time.
Yes, there will certainly be a way to mount it to the current UAP1 damper plates. That's how I'll test it, though I probably don't have a worthy camera.
I've ordered from Parker Steel, though it's not cheap. They certainly are fast and efficient though. Of course only in America can you order metric tubing by the foot
What you see in the picture is this pot:
http://www.digikey.com/product-detai...502C-ND/222782
It was chosen because it has a nice long shaft that happens to be the right size for bearings. It's 5k ohms because "someone" said that was what his pots were. I notice now that the external pot Servo City left on my modified servo is 1500 ohms, but I'm not sure if the value matters much. I've never looked at the circuit, but I'm betting it's just a voltage divider, and it won't matter what the value is.
As Hansen mentioned, 32 and 90.
Cheers,
Rusty
Site Sponsor
Old Oct 10, 2012, 08:34 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
This is pretty exciting. I had 10mm square clamps already and have some 10mm alu tubing on the way but think I will wait until Rusty finishes his up. He always thinks it out and does a nice job Seismic nice job on your original too. I was ready to turn some parts on the lathe and do some milling after reading your first post. I have always been curious about backlash in a gimbal setup so figured it was time to build one and see what it was all about.
edit to ask: What torque range do the servos need to have? I have some low end small digitals that track great and maybe one of their bigger brothers might work for this.
pug398 is offline Find More Posts by pug398
Old Oct 10, 2012, 11:43 PM
AMA 46133
Hawaii
Joined Feb 2003
>> Seismic nice job on your original too.<<
Thank you.
>>I have always been curious about backlash in a gimbal setup so figured it was time to build one and see what it was all about.<<
If you use a high ratio belt drive backlash is really not much of an issue. The main issue if flexing of the gimbal if it is not rigid enough. Mostly on the tilt axis. Then the other is the backlash of the servo if you don't use a good quality one.
>>edit to ask: What torque range do the servos need to have? I have some low end small digitals that track great and maybe one of their bigger brothers might work for this.<<
I found that the stronger the better without sacrificing speed. You don't need those .06 second transit time like the ones for the tail rotor of a singe rotor helicopter. However some where in the low teens will be nice. As far as torque I like those 300 to 400 ounce inch monster. That's just over kill. Generally 200 ounce inch will be just fine.
Old Oct 11, 2012, 10:17 AM
pug398 is offline
VA
Joined Nov 2009
Thanks for the info. Sounds like the 48 oz digitals that I have are a little small but the larger model will do 300+ oz. Looks like +/- 45 degrees of travel so that should be plenty for me. Know absolutely squat about the AP part so this should be very interesting.
Question Can you make Embedded Pictures show up with Show Attachments in this Thread? Richard N Site Suggestions / Complaints 4 Sep 04, 2012 01:03 PM
Help! Can you tell me what make and model this car is? KiTCyclic Electric Power Cars 25 Aug 14, 2012 11:41 AM
Careful! Always make sure you clarify functional condition prior to agreeing to buy!!!!!! -= GYRO =- Trader Talk 84 Jun 15, 2012 01:06 PM
Help! Is there any gimbal stabilisation unit out there that can do camera lock? hexa Multirotor Talk 9 Apr 17, 2012 06:46 PM
The new momie hopperz f/d channel rc you can make a full functional micro plane saab2fast Scratchbuilt Indoor and Micro Models 10 Dec 16, 2004 07:43 PM
