Old Sep 25, 2012, 03:52 PM
Mikep0011 is offline
Find More Posts by Mikep0011
United States, FL, Miami
Joined Aug 2011
Question
Where to purchase Optical Kill Switch
New to gassers and wanted to know if someone can recommend a decent Optical kill switch and where to buy? I'm going to be installing it on a DLE 20cc. Also when I install it would it be my primary cutoff or would it be better to shutdown through throttle as primary?
Mikep0011 is offline Find More Posts by Mikep0011
Old Sep 25, 2012, 04:42 PM
SrTelemaster is offline
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
I've always used the throttle trim to set idle speed & then it can be used to shut down the engine.
K.I.S.S.
SrTelemaster is offline Find More Posts by SrTelemaster
Old Sep 25, 2012, 05:40 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
You should always have your throttle properly setup so that you can kill the engine either way. Killing the engine with the ignition kill switch is a good idea, reason being that if you kill with the throttle the capacitor is still charged in the CDI ignition. If someone carelessly flips the prop the plug could still fire one time resulting in a kick back. Not common, but possible.
Since you're talking about 20cc powered models, you may want to consider the advantages of an IBEC such as this one. http://www.tech-aero.net/Home.
The largest gassers I fly are 30cc, and for an everyday beater a 20cc powered. All using an IBEC. With a 20cc model you can run one 2300mAh A123, or comparable LiFe pack to provide plenty of flying time. The IBEC has an adjustable regulator to drop the voltage down to the level needed for an ignition module designed around 4 cell Nimh.
Good luck,
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Sep 25, 2012, 07:12 PM
ahicks is offline
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
I like having the ability to kill with the throttle, but in practice, use the optikill switch the vast majority of the time. One of the bigger advantages of a switch like this is in the event the receiver looses it's signal, or you shut off the radio forgetting to turn off the flight pack? The switch will shut down the power to the ignition in any instance where there is no longer a signal coming from the receiver.
Rcexl OptiKill switch is pretty popular, great buy bucks spent for bang received. 20 bucks or less, here's a good source:
http://www.rcextremepower.net/ignitions.html
ahicks is offline Find More Posts by ahicks
Old Sep 25, 2012, 07:45 PM
Joined Aug 2011
Good Info. Thanks alot for your quick response.
Old Sep 26, 2012, 02:41 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I bought the 20 dollar one from these guys
http://www.valleyviewrc.com/estore/e...-switches.html
kerwin50 is offline Find More Posts by kerwin50
Old Sep 28, 2012, 05:52 PM
edwin1 is online now
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
$18 at Bad Brad Graphics, Rcexl. I'm using two of them right now. Scroll down a little to find it.
Edwin
http://www.badbradgraphics.com/photo_16.html
edwin1 is online now Find More Posts by edwin1
Sold PB Kill switch, Hpi Bajs 5b Kill switch. ronzer Cars - Trucks and Parts (FS/W) 0 Sep 11, 2012 05:43 PM
For Sale 3ea Smart Fly optical kill switch Lappster Aircraft - General - Radio Equipment (FS/W) 0 Jul 26, 2012 09:24 PM
For Sale Smart Fly Optical Ignition Kill Switch rcbirk21 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Aug 31, 2010 11:19 PM
Discussion Using XPS with Fiber Optic Kill Switch... Al Czervik Xtreme Power Systems 8 Aug 02, 2007 04:15 PM
