Old Oct 08, 2012, 08:00 PM
03svtsnakevert's Avatar
USA, TX, Copperas Cove
Joined Jul 2010
Originally Posted by sky_captain View Post
03svtsnakevert
nice flight report. Good info. So where exactly did you wind up with the cg for better flight characteristics? I will be running 3s so i guess i will have to move my battery more forward. A pic of where you put yours would be great.
I get mine this wed but won't be able to maiden until this weekend, weather permitting.
Description:
03svtsnakevert is offline Find More Posts by 03svtsnakevert
Old Oct 08, 2012, 08:30 PM
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
Thanks03svtsnakevert
So if that's the 4s 1600, I''m guessing I could put a 3s 2200 in the same place.
Could anyone please tell me the weight of the stock 4s 1600mah battery?
I won't have one because I bought the Rx ready from Bananahobby that doesn't come with one. But I'm happy about that because it was cheaper and I don't plan on flying with 4s anyway.
Sky_Captain is offline Find More Posts by Sky_Captain
Old Oct 08, 2012, 08:41 PM
Joined Jul 2010
The weights are as follows:
4s 1600 ---- 5 7/8 oz or 168g
4s 1300 ---- 5 1/8 oz or 145g
3s 2200 ---- 6 5/8 oz or 188g
So same place would be maybe a little tail heavy move it slightly fwd of where the 4s is
Old Oct 08, 2012, 09:39 PM
olllian
olllian's Avatar
United States, AZ, Chandler
Joined Nov 2011
Update!
Hey guys just got my plane in the mail today. This plane looks sweet the epo is supper stiff and nice. The wing is rock hard and dont need to upgrade the wing spars. Over all this plane looks like a DF/Funfighter winner. I will keep u guys posted when its ready to fly! Some pix to check it out.
P.s The plane is together with 4 screws no glue and its comes with a screw driver how sweet is that =)
olllian is offline Find More Posts by olllian
Old Oct 08, 2012, 09:41 PM
Joined Jul 2010
Hold on tight bro if you spool it up in the house...lol
I too was impressed at the stiffeners used throughout the fuse and wing...your gonna love how it flies
Old Oct 08, 2012, 09:42 PM
olllian
olllian's Avatar
Joined Nov 2011
Originally Posted by 03svtsnakevert View Post
Maidened it today!!!!
Well I can tell ya, it is................................FAST!!!!
1st flight:
Not quite enough throttle and very twitchy on take off...aileron roll left right left inverted right left and then got up enough speed to be rock solid...ailerons have decent authority and great speed!! had the CG set up at 50mm which is their front number...flew tail heavy here...landed it a little hot but it handled it well...very tough little plane...had all surfaces set at 100%...too much elevator throw which causes a violent roll if you pull hard elevator
2nd flight:
more power on take off and rewarded with a very uneventful hand toss take off...I cut the elevator down to 75%...better on elevator authority but still a hard pull to full deflection results in a hard roll out...again really enjoying the speed of this inexpensive bird...the motor sounds AWESOME!!!! I used a higher c lipo (30c) and it was only slightly warm after a 3 min flight...this lipo is a 1300 mah and not the 1600 I was initially flying with (both are 4S)...I moved this one fwd and it seemed a little more close to balance...still slightly tail heavy but not nearly as twitchy.
3rd flight
again more power on take off and it was on rails...no troubles now...reduced elevator to 65% and even better meaning I can pull a little tighter loop now but it will still roll out on hard elevator pull..so be cognizant of that...used the first lipo after only putting 700 mah back in so I didn't quite make 50% on initial flight although it was slightly tame on the first flight...this flight I wrang it out a bit....I don't know if said this already but this thing is FAST...really enjoy it...I moved the original battery a little further fwd and it still climbed a bit but I had a better feel for the bird here...landings were good all day...little hot but no damage to this tough little bird...the 20c lipo was very warm upon removing it from the plane...which tells me that the C rating at 20 is too light for this little bird.
Great power
watch your CG...the manual has it a 50-60...I set it at 50 and it seemed tail heavy on its first flight...50 was the 1600 4S moved all the way back...I moved it slightly forward and noted better flying characteristics.
I would recommend at least a 30C-40C lipo for this bird...my 30C only came back slightly warm after a spirited flight.
Hope you guys enjoy yours! I will be flying this little hot rod for a while now...can't wait to fly my rifle!!
two thumbs up!!!
Thx for the heads up!
Old Oct 08, 2012, 09:48 PM
Joined Jul 2010
No prob...like I said it was fun to fly
Old Oct 10, 2012, 09:38 PM
olllian
olllian's Avatar
Joined Nov 2011
What amps are u pulling with the stock setup on 4s? I am going to madien mine tomorrow!
Old Oct 10, 2012, 09:51 PM
Joined Jul 2010
I don't know...don't have a meter...just remember plenty of throttle on take off
Old Oct 12, 2012, 07:41 AM
Flying is Freedom
Annandale, VA
Joined Jul 2007
Thanks and ouch the 3s 2200 is heavy compared to the 4s 1600. I'm surprised.
I think I will have to use a smaller 3s. I will use your 4s weights to find a good 3s match.
Old Oct 12, 2012, 07:45 AM
Flying is Freedom
Annandale, VA
Joined Jul 2007
Ollian,
I have several planes that are go together that way, it is getting more common. I love it and it makes it easier to repair in the evet that you need a new wing.
Old Oct 12, 2012, 08:03 AM
Joined Jul 2010
Wondering how the maiden went ollian
Old Oct 12, 2012, 11:44 AM
To Have & To Hold
Percivale's Avatar
Joined May 2010
Updates/Videos pls
Percivale is offline Find More Posts by Percivale
Old Oct 12, 2012, 12:30 PM
Joined Jul 2010
I'll try to get a vid the next time I take her out
Old Oct 12, 2012, 03:33 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
Hey guys,
I got my plane today. I'm very happy with the build, nice quality.
Just need to change the esc connector, weigh some of my batteries and pick the right one. I have some 3s 1550mah and 1600mah. I will see if they are close to the weight of the sock 4s that you guys have.
For Sale NIB Dago Red Sport Pylon bevers01 Aircraft - Electric - Airplanes (FS/W) 2 Aug 21, 2012 02:06 PM
Question sport, pylon, f3a.. what are all the catagories and what do they mean? flybybob Beginner Training Area (Fuel) 3 Jun 30, 2012 10:10 PM
New Product JCX-M6 Flight Controller for RC Airplane RC Model Plane FPV Fixed-wing Airplane wenney2009 Video Piloting (FPV/RPV) 3 Jun 19, 2012 05:10 AM
Sold Fantrainer Sport Scale RC Ducted Fan Jet Airplane Plans junieb Aircraft - Electric - Jets (FS/W) 0 Jun 04, 2007 06:44 AM
