Old Jan 27, 2013, 04:33 PM
Sky_Captain is offline
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
Originally Posted by Sky_Captain View Post
I forgot to ask, How would the plane run on the stock prop with a 3s prop?
So.... I'm guessing it will fly fine on the stock prop with 3s lipo. Makes sense since its propped out of the box to withstand 4s.
Sky_Captain is offline Find More Posts by Sky_Captain
Old Jan 27, 2013, 06:21 PM
mustflynow2 is offline
Find More Posts by mustflynow2
The Sequel
mustflynow2's Avatar
Australia, VIC
Joined Sep 2011
Sure you wont damage anything but your rpm will be down, hence airspeed so you got to ask yourself will it pull along well enough to keep it from loosing altitude? Will probably fly but...Small wing area high wing loading, poor glide ratio, so it sinks, that prop is important to keep it up, including the pitch speed, hence fast plane, that is the idea isn't it?
We flew last night, my friend with the moray, with what we think now is a bent alloy prop adaptor for the ntm motor, so he could only cruise around or would get bad vibration, ( only one flight) so was on the elevator all the time cos it would sink at low airspeed.
I think the best flying plane I have seen here is the 6s version of olllians. Question is what is his props rpm? Up over 20,000?
Speed depends on pitch speed, and drag, doesn't really matter how you get there so long as the prop speed is up and the drag is down.
mustflynow2 is offline Find More Posts by mustflynow2
Old Jan 27, 2013, 06:36 PM
jstoll is offline
Find More Posts by jstoll
cant leave things stock
jstoll's Avatar
United States, KY, Lexington
Joined Feb 2007
I flew my stocker around the first few times on 3S and it was fine... launched full throttle and probably flew around at about 55mph not a rocket but it climbed well and flew well above stall
enjoyable but a little boaring
take care
JAK
jstoll is offline Find More Posts by jstoll
Old Jan 27, 2013, 09:38 PM
zooplane66 is offline
Find More Posts by zooplane66
Joined Jan 2013
Best prop for this battery
http://www.hobbyking.com/hobbyking/s...dProduct=19121
I ordered two of these... best prop to match it for speed and run time??
Thanks!
zooplane66 is offline Find More Posts by zooplane66
Old Jan 27, 2013, 10:25 PM
jstoll is offline
jstoll's Avatar
Joined Feb 2007
the stock prop is what works best with 4S for speed and run time
buy a few APC 7X6 you are going to break them :-)
take care
JAK
Thanks!
Old Jan 27, 2013, 10:50 PM
jstoll is offline
jstoll's Avatar
Joined Feb 2007
I put in a HK 60-70 amp speed controller and separate BEC in while I wait for my wing to come at the end of the week I did this in prep for adding a higher KV motor that will pull more amps
the stock 40 amp ESC has the same command set as a turnegy plush so if you want to know how to set timing and whatnot print off a sheet for a plush controller
I pulled the shrink off of the stock 40 today after running the 8X8 on 4S to see if the fets had floated at all and they did seem pretty strait ... I wasent pushing it the whole time though
have a great week
JAK
Old Jan 28, 2013, 07:00 AM
Flying is Freedom
Annandale, VA
Joined Jul 2007
take care
JAK
take care
JAK
Thanks guys, I appreciate the input.
Well... I'm wondering if I made a mistake with this plane. I bought it to be a replacement for my Formosa and wasn't really looking for a speed demon. Thank goodness I haven't got rid of it yet, because it looks like I may want to keep it.
I haven't flown my Moray yet so I guess that's the best way to find out. Can't wait to get some good weather when I'm not so busy so I can test it.
Old Jan 29, 2013, 09:28 PM
jstoll is offline
jstoll's Avatar
Joined Feb 2007
I want radar or doppler on the 6S bird that thing looked fast....
JAK
Old Jan 29, 2013, 10:22 PM
dbgood is offline
Find More Posts by dbgood
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
Thanks!
I run on my Moray,4S 1800TP,Cam prop 7x7...dopplered 97-98 flat!
Great combo
DB
dbgood is offline Find More Posts by dbgood
Old Jan 30, 2013, 08:52 AM
jstoll is offline
jstoll's Avatar
Joined Feb 2007
db... where did you get the prop? not seeing many options...
take care
JAK
Old Jan 30, 2013, 10:13 PM
dbgood is offline
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
take care
JAK
JaK,
I got the Aeronaut camprop 7x7 ,from Espritmodels..
Just checked quanity they have 10 left.
Let me know if you found it bud?
DB
Old Jan 30, 2013, 11:54 PM
jstoll is offline
jstoll's Avatar
Joined Feb 2007
thanks man
I did get a couple of APC 7X8 but I doubt they will be that good
I also have a 1800KV 35X36 motor coming thats supposed to be good to about 850 watts http://www.hobbyking.com/hobbyking/s...dproduct=26486 that should be fun :-) Im looking forward to flying this weekend :-) my new wing will be here tomorrow
take care
JAK
PS have you found these props to be strong? with landings?
Old Jan 31, 2013, 12:17 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
if u want to fly it on 3's try the 8x8 or a 9x7.5 , just look out for the dreaded torque roll
chuck.
chas650r is offline Find More Posts by chas650r
Old Jan 31, 2013, 12:31 AM
dbgood is offline
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
thanks man
take care
JAK
Hi JAK,
I have many flights with the aeronaut camprop 7x7,i didnt break any!
I will fly this weekend in Upstate Ny 27degrees,but im a diehard,
im gonna bring my Moray,and my RareBear,both are 4S,but the RareBear
will take the Moray easy,both are alot of fun!
keep in touch,
DB
Old Jan 31, 2013, 12:40 AM
dbgood is offline
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
Thanks!
Aeronaut camprop 7x7 i run with 4S,IceLite 50.
For Sale NIB Dago Red Sport Pylon bevers01 Aircraft - Electric - Airplanes (FS/W) 2 Aug 21, 2012 02:06 PM
Question sport, pylon, f3a.. what are all the catagories and what do they mean? flybybob Beginner Training Area (Fuel) 3 Jun 30, 2012 10:10 PM
New Product JCX-M6 Flight Controller for RC Airplane RC Model Plane FPV Fixed-wing Airplane wenney2009 FPV Talk 3 Jun 19, 2012 05:10 AM
Sold Fantrainer Sport Scale RC Ducted Fan Jet Airplane Plans junieb Aircraft - Electric - Jets (FS/W) 0 Jun 04, 2007 06:44 AM
