Old Nov 03, 2012, 02:35 PM
03svtsnakevert is offline
Find More Posts by 03svtsnakevert
03svtsnakevert's Avatar
USA, TX, Copperas Cove
Joined Jul 2010
Originally Posted by olllian View Post
Be carful i herd that plane is hard to launch. i almost got it a wile back!
Naw should be a breeze
03svtsnakevert is offline Find More Posts by 03svtsnakevert
Old Nov 03, 2012, 04:29 PM
Quadmad is offline
Find More Posts by Quadmad
Joined Jul 2012
Originally Posted by 03svtsnakevert View Post
You will enjoy it sir...I'm putting together a rifle now
I did look at the rifle in my local HS i didn't like the quality of it the composite fuse was badly layed up
Quadmad is offline Find More Posts by Quadmad
Reply With Quote  (Disabled)
Old Nov 06, 2012, 04:01 AM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
Originally Posted by Quadmad View Post
so i brought one thanks to you guys
Haha I told you that you would get the bug
I hope the dog is still going strong with the new powerplant have you run it on 5s?
catch up soon Buddy
Adrian_M is offline Find More Posts by Adrian_M
Old Nov 06, 2012, 02:53 PM
Quadmad is offline
Joined Jul 2012
I hope the dog is still going strong with the new power plant have you run it on 5s?
I hope to catch up soon
Hi Adrian how you doing, the dog is still going. running only on 4s I'm too scared to go to more cells it's plenty fast as it is after seeing yours on 5s
I might have to pick your brains again for a decent power setup for this plane
I still have the Scorpion 3026-1900Kv I brought from you on my trip Down under might go good on 4s
Old Nov 09, 2012, 04:57 PM
PlaneView is offline
Find More Posts by PlaneView
United States, NC, Clayton
Joined Jan 2012
Hey guys. I have read through the thread nothing i have tried has worked.
I CAN NOT GET THIS THING TO NOT DIVE LEFT!
I have added 1 oz of lead to the back. Its cg is great.
I have added some right aileron and still diving left..
I have launched at 1/4 and also half throttle.
Launching holding the top of the plane and throwing at 40-45
Should i add a weight to the right wing?
Any help guys.
Thanks Trey.
PlaneView is offline Find More Posts by PlaneView
Old Nov 09, 2012, 05:34 PM
Sky_Captain is offline
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
Have you checked the thrust angle of the prop/motor?
Sky_Captain is offline Find More Posts by Sky_Captain
Old Nov 09, 2012, 06:47 PM
YellowJacketsRC is online now
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Check that the wings are not warped.
Check that the main wing is in line with the stab
Check to see that the ailerons are not warped.
Check to see that the elevator is even and not warped
Check your motor thrust line. It should be pointing slightly to the right.
Have you been able to fly at all, or are you still just trying to launch?
YellowJacketsRC is online now Find More Posts by YellowJacketsRC
Old Nov 09, 2012, 06:48 PM
QDRevenger is offline
Find More Posts by QDRevenger
QDRevenger's Avatar
New Zealand, Auckland
Joined Jun 2011
Breeze indeed My Rifle, running a HET 1W-30 on 3S, 73.4A, 781.7W launches easy. Just give it a good hard thow about 10 - 15 degrees, i launch at half throttle. Scrubbing off all the speed for the landing is the hardest thing. Get plenty of spare props . Good luck with the rifle.
Ok, I got myself a Moray, thanks to Adrian for pointing it out and and taking advantage of the free shipping.
I've left mine reasonably stock, only changing out the ESC. I'm going to use some 2250mAh 65C 4S Nano-Tech lipo's, little on the big side, but the smallest I have on hand. They fit in easy enough and balanced with the battery hard up against the tray.
Description: Name: IMG_0995.jpg
Description: Name: IMG_0996.jpg
Description: Name: IMG_0993.jpg
Description:
Static figures 31.8A, 478.7W with the stock 7 x 6 prop.
Hoping to give it a maiden today, I will keep you all posted. If I get a second flight, I willl try a 7.4 x 7.7 pylon prop, I think the stock motor should handle that ok.
QDRevenger.
QDRevenger is offline Find More Posts by QDRevenger
Old Nov 09, 2012, 07:29 PM
Joined Jan 2012
t
Looking at the plane with the nose pointing towards yourvface. It is slight right
Yes i did manage to mantain flight for about 30 seconds. Was trying to trim it.
Old Nov 09, 2012, 07:41 PM
They Call him Dead!
Joined Jul 2003
What is slight right? Are you saying the nose points to the right when you are looking at it with nose pointing at your face?
If so then your thrust angle is whack!
The motor should point slightly to the left as you look at it with the nose pointing to your face. It should be pointing to the right if you are sitting in the cockpit looking forward.
Old Nov 09, 2012, 07:58 PM
Joined Jan 2012
Damn. Good to know man.
Afterbre looking making sure it level,plumb. It seems to have a very very and i mean very slight turn to the left.
Old Nov 10, 2012, 12:03 AM
They Call him Dead!
Joined Jul 2003
Should be the other way. I don't have the model so I can not tell you how far right. But should be a few degrees right thrust...
Come to think of it, this being a ready to fly model, the right thrust should be built into the fuse as well as the motor mount so that the back of the spinner plate lines up with the front of the firewall so that there is a small, but even gap all the way around between the spinner plate and front of fuse. Is this gap consistent on yours?
If it is consistent, then is your fuse crooked?
Old Nov 10, 2012, 12:25 AM
yellowcolorado is offline
Find More Posts by yellowcolorado
United States, LA, Metairie
Joined Feb 2009
For those of you who have the dogfighter and have this plane, which one would you say is better in terms of quality?
yellowcolorado is offline Find More Posts by yellowcolorado
Old Nov 10, 2012, 07:39 AM
Joined Jan 2012
Its perfect....well seems to bem I adjusted a few things and going to go see if it mad a difference. Thanks
Old Nov 10, 2012, 09:22 AM
They Call him Dead!
Joined Jul 2003
Which works best, 1/4 or half throttle? I know neither WORKS, but which is best? If 1/4 works better that would support the thrust angle theory.
Can you hand launch with NO POWER at all? Just throw it as hard as you can with nose level or just slightly pointing down. See if you can get a decent and straight glide out of it. If so, this supports thrust angle issue....
For Sale NIB Dago Red Sport Pylon bevers01 Aircraft - Electric - Airplanes (FS/W) 2 Aug 21, 2012 02:06 PM
Question sport, pylon, f3a.. what are all the catagories and what do they mean? flybybob Beginner Training Area (Fuel) 3 Jun 30, 2012 10:10 PM
New Product JCX-M6 Flight Controller for RC Airplane RC Model Plane FPV Fixed-wing Airplane wenney2009 FPV Talk 3 Jun 19, 2012 05:10 AM
Sold Fantrainer Sport Scale RC Ducted Fan Jet Airplane Plans junieb Aircraft - Electric - Jets (FS/W) 0 Jun 04, 2007 06:44 AM
